Stacked ground wires
Discussion in 'General Tundra Discussion' started by trayday, Mar 17, 2017.
  1. Mar 17, 2017 at 12:40 PM
    trayday
    trayday [OP] New Member
    Oregon
    2015 limited CM 5.7
    I stacked the ground wires behind the air box on top of each other. Could a double stack ground cause electrical issues? Everything electrical in my dash will intermittently stop working including the traction control.
  2. Mar 17, 2017 at 12:55 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    It could. Look into a ground bar / block
  3. Mar 17, 2017 at 2:55 PM
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
    Take it apart and make sure that there is a good ground and no paint is left behind. I'm betting that will cure the issue. Mercedes puts multiple grounds on one stud.
    trayday[OP] likes this.
  4. Mar 17, 2017 at 3:41 PM
    trayday
    Oregon
    2015 limited CM 5.7
    Its real tight, ill give that a shot. Its been 30k miles with the double ground and just started happening a few weeks ago.
  5. Mar 17, 2017 at 7:08 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Stacking a few ground eyelets is fine as long as all surfaces are clean of paint or corrosion, and it is tight. Well, within reason anyway, I wouldn't add a high amperage ground wire (like a high power amp, or inverter) to a body ground connection at all, but for anything 30A and under you'll be fine.
    I'm going to say that your instrument cluster issues are an unrelated problem.
  6. Mar 18, 2017 at 10:27 AM
    trayday
    Oregon
    2015 limited CM 5.7
    Thanks, this what the dealer was saying was the cause of the problem. Just wanted to get others opinion before i go take the truck back and complain of the 300$ I was charged last time i was in.
    NewImprovedRon likes this.
  7. Mar 18, 2017 at 3:44 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    2019 Silver Sky Platinum Crew Max
    Bed Rug, Tonneau cover, Window visors, Console organizer, Weather Tech's
    So 2 things... 1st as others have said stacking grounds or using a "common ground" is ok. You could cause some issues if say you had different voltages or combining ac and dc to the same spot. 2nd i see you have the Hypertech speedo calibrator that very well could be the cause to your issue. I got mine installed and about 5 months later it just decided to stop working. Every light on my dash was on and i had no tach or speedo. I almost got it towed to a different Toyota dealer but decided to give the other one a chance first. Called their parts guy the next day and he said i know exactly whats wrong with it. Ill have another calibrator here tomorrow for you. Sure enough he was right.
    trayday[OP] and NewImprovedRon like this.
  8. Mar 19, 2017 at 10:35 AM
    trayday
    Oregon
    2015 limited CM 5.7
    Ill disconnect the calibrator for a bit and see if the problems still arise.
  9. Mar 19, 2017 at 6:40 PM
    Juanjoolio007
    Oregon
    cool. If thats not it hope you find it.
    trayday[QUOTED][OP] likes this.
