sr5 heated mirrors to tow mirrors swap
Discussion in '2nd Gen Tundras (2007-2013)' started by SalsaTheTundra, Sep 12, 2020.
  1. Sep 12, 2020 at 2:53 PM
    SalsaTheTundra
    SalsaTheTundra [OP] New Member
    jd
    Birmingham, Alabama
    2008 Salsa Tundra Double Cab SR5 5.7
    Ubar led headlights K&N filter +50HP
    Hey, I ordered the tow mirrors for my 2008 sr5 double cab. It had the small mirrors with heat and power adjust. I unmourned them and the connectors for the tow mirrors with just heat and turn signal are different. I cut the connector off the stock mirror because it looked like i could swap the connectors and it would plug. i’m pretty sure i messed stuff up and so any info would help. part numbers, wiring diagrams, ETC
  2. Sep 12, 2020 at 4:01 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    They should of been the same. Tow mirrors are the same from 2007 till now
  3. Sep 12, 2020 at 4:02 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Did u get the power fold tow mirrors? Those are the only two options. Power fold or manual.
  4. Sep 12, 2020 at 7:05 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    They are manual fold. I think they’re aftermarket. let me post a link https://www.ebay.com/itm/353176612016
  5. Sep 12, 2020 at 7:33 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    The plugs should have been the same?
    I did the same swap, I went from power heated manual fold to towing mirrors and they plugged right in and even the led parking/turn lamps worked. Plug and play
    SalsaTheTundra[OP] likes this.
  6. Sep 15, 2020 at 8:02 AM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    i wish they were the same. but they weren’t i’ll grab a pic when i get out to my truck this afternoon.
  7. Sep 15, 2020 at 10:35 AM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    here’s the connector
  8. Sep 15, 2020 at 12:22 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    Did you buy oem Toyota tow mirrors?
    Let’s see a pic of the plug too.
    In my experience all mirrors share the same plug. But if you are adding features you did not have before you would have to run additional wires. Like if you add puddle lights or power fold option.
  9. Sep 15, 2020 at 12:25 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    Never mind, I see they are aftermarket.
    I know for a fact the OEM plug in. I have a 13 and swapped in some oem 08 tow Mirrors no issues plug and play
  10. Sep 15, 2020 at 12:25 PM
    SalsaTheTundra
    jd
    Birmingham, Alabama
    l
    I don’t think they’re oem. i got them on ebay. I am adding the orange marker on tow mirrors that weren’t on the sr5 mirrors
  11. Sep 15, 2020 at 12:56 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    I understand you are adding the amber LED running lights and turn signals.
    OEM sport mirrors have the same plug as OEM tow mirrors and the amber running lights and turn signals function like OEM
  12. Sep 15, 2020 at 1:09 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    The mirror side plug looks as it should. What does the truck side harness look like?
