Squealing noise in engine
Discussion in '2.5 Gen Tundras (2014-2021)' started by jfox, Jan 15, 2020.
  1. Jan 15, 2020 at 4:39 PM
    jfox
    jfox [OP] New Member
    Richmond VA
    2015 MGM Limited
    Hi folks, I have a 2015 CM Limited with 58,000 miles. Some days when it is colder upon starting I sometimes here a squealing noise that sounds like it is coming from the serpentine belt. Once it warms up it goes away usually after 10 min or so. Should I be concerned? I think others have had the idler pulleys replaced but normally not with this few miles. Any thoughts? Thanks!
  2. Jan 15, 2020 at 5:14 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Bad belt, one of the pulleys going, and/or bad tensioner. Check belt for any fluids on it too while you're there.
  3. Jan 15, 2020 at 6:09 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I had something similar, that turned out to be the bearings on the hvac blower motor. It is tucked up behind the glove box. It seemed to quiet down after running a few minutes. Mine was replaced under warranty. Hop in the passenger seat when you start it in the morning and see if that’s possibly where the noise is coming from.
  4. Jan 16, 2020 at 1:52 AM
    vanoss101
    vanoss101 New Member
    2015 SR5 Tundra DC
    Has the truck had any work where the serpentine belt was removed? Because it is possible to route the belt wrong and that will cause a squeal at start up. Only reason I know this because my dealer did it on my truck after a water pump job.
  5. Jan 17, 2020 at 3:12 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Power stering pump may make noise cause of the cold thick fluid. Mine makes a noise until it warms up.
  6. Jan 18, 2020 at 5:36 PM
    rodm1
    rodm1 New Member
    Had the same problem it whose moister when cold (freezing temp) on the belt system. I would go threw the car wash and only drive 2 miles home I would squeak for a few days after. Now I drive it 20 minutes to dry everything of and haven't had a problem since.
  7. Jan 20, 2020 at 11:52 AM
    jfox
    Richmond VA
    2015 MGM Limited
    Thanks all.
    No work done on it at all. In the 58K that I have had the truck, I have changed tires and break pads. The strange thing is today is one of the coldest it has been and it starting up with no noise whatsoever. I have the platinum warranty so maybe I will have the dealer check it out next time I am down that way.
  8. Jan 20, 2020 at 11:59 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I replaced my belt tensioner at 50k on my 2014 due to the squeaking noise. I don’t believe it will leave you stranded..just an annoying sound. If you do decide to replace it, it’s easy. I did mine in about 30 mins and I did not replace the belt..
    15whtrd likes this.
  9. Oct 31, 2021 at 9:04 AM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Bringing this back because I’m getting a bad squeal on my 2017 with 63k. New tensioner on order as it is coming from that side. A little disappointed I couldn’t get 100k miles on the OEM tensioner.
    AZTundra and HulkSmurf14 like this.
  10. Oct 31, 2021 at 10:01 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yeah, wait until you try an aftermarket one! It'll start chirping in under a year...same happened with mine...wasn't worth saving $40 to do it over again...buy an OEM one and knick it out...if these are the worst part of the trucks, I'll take it, albeit, annoying!
  11. Oct 31, 2021 at 10:12 AM
    AZBoatHauler
    So.Arizona
    I ordered a Dayco which my research tells me is the OEM part. Can you confirm your OEM ones were stamped Dayco?
    HulkSmurf14[QUOTED] likes this.
  12. Oct 31, 2021 at 10:19 AM
    HulkSmurf14
    2014 Tundra Limited
    Dayco sounds right...I'll dig thru my receipts...I can't see any markings as it's on the truck right now though...
  13. Nov 1, 2021 at 12:43 PM
    AZBoatHauler
    So.Arizona
    I swapped them this morning. Dayco is the OEM part. Unfortunately the squeal persists- sounds like alternator bearings.
    :annoyed:
  14. Nov 1, 2021 at 12:51 PM
    HulkSmurf14
    2014 Tundra Limited
    Damn!!! I wish you a speedy swap or modification!
    AZBoatHauler likes this.
  15. Nov 1, 2021 at 4:00 PM
    Rocko9999
    Rocko9999 New Member
    I have this. I thought it was P/S pump, belt, tensioner, a/c, etc. Got a mechanics stethoscope and found it's the alternator bearings.
    HulkSmurf14 and AZBoatHauler like this.
  16. Nov 1, 2021 at 4:19 PM
    AZBoatHauler
    So.Arizona
    I think I’ve confirmed the noise is coming from the alternator. Picked up a new one from the local dealership this afternoon - $450 after tax. :puke:
    Should have it installed later this week. I’ll report back.
  17. Nov 1, 2021 at 4:24 PM
    Rocko9999
    Yeah, pricey but the best route vs some junk auto parts option. Please do.
    HulkSmurf14 likes this.
  18. Nov 4, 2021 at 7:04 PM
    AZBoatHauler
    So.Arizona
    New alternator installed. Thought long and hard before pulling the old one because the pulley spun free and quiet by hand. Quiet as can be now with the new alternator.
  19. Nov 4, 2021 at 7:08 PM
    HulkSmurf14
    2014 Tundra Limited
    Yeeeeehaw! That feels so good! You pretty much have a brand new truck again after all the round things you've replaced! I'm glad it was the culprit and is fixed!
  20. Nov 4, 2021 at 7:30 PM
    AZBoatHauler
    So.Arizona
    Thanks. Me too. Earlier than I wanted but done is done.
  21. Nov 5, 2021 at 11:07 AM
    Rocko9999
    Awesome! Glad you got it fixed. How much if a PITA was swapping it out?
  22. Nov 5, 2021 at 11:12 AM
    AZBoatHauler
    So.Arizona
    Honestly it was not as bad as the horror stories I’ve read about. Went through the wheel well and had to take the PS pump off to get enough clearance. Definitely seems easier than pulling the fan, fan shroud and sway bar to pull it out the bottom. Roughly 4 hours start to finish.
