Squeaking, groaning noise when turning steering wheel... ???
Discussion in '1st Gen Tundras (2000-2006)' started by avgguy, Nov 26, 2018.
  1. Nov 26, 2018 at 10:46 AM
    avgguy
    avgguy [OP] New Member
    Craig
    2000 Tundra 274K Original
    2000 4.7
    This doesn't happen all the time, or at least didn't before. Tie rods, ball joints ? No idea what is causing this. Sounds hideous.... is actually much louder than video.
    Tried posting video but it's too large... will redo and try to post after while.
  2. Nov 26, 2018 at 10:50 AM
    Casper421
    In the woods
    06 DC
    Have you checked the power steering reservoir if it’s empty?
    You can only upload videos via YouTube.
  3. Nov 26, 2018 at 10:56 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Mine squeals too. The PS is full.
    avgguy[OP] likes this.
  4. Nov 26, 2018 at 10:57 AM
    Casper421
    In the woods
    06 DC
    Is your steering rack leaking?
  5. Nov 26, 2018 at 11:02 AM
    avgguy
    Craig
    Good question... no drips on driveway. PS reservoir fluid level is right at line of COLD MIN.
    You guys are so good on responses . Thanks a lot. I hope I can help someone.
  6. Nov 26, 2018 at 11:11 AM
    Casper421
    In the woods
    06 DC
    I would visually check the rack for any leaks. Is the PS fluid dark in color? If so, I would start by flushing the system and see if that helps.
    15whtrd likes this.
  7. Nov 26, 2018 at 11:21 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    My '17 makes a groan when I turn hard left. Like, a U turn or pulling out of the driveway. Would love something useful to shake out of this thread!
  8. Nov 26, 2018 at 11:58 AM
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    There is a rubber boot on the steering shaft beneath the brake pedal,pull that back and grease it up,it was quite noisy on mine!
  9. Nov 26, 2018 at 3:12 PM
    Professional Hand Model
    Hand Protectors
    Last time my steering made noise (like a rahh, rahh, rhahh when turning hard) I had a shop do the full flush and refill with new DEXIII Fluid. Since then, no noises. I now regularly do the turkey baste suck and refill to keep things fresh.
    That fresh DEXIII keeps the seals and pump lubed nicely. Hope this helps.
    15whtrd likes this.
  10. Nov 26, 2018 at 3:39 PM
    avgguy
    Craig
    This noise is coming from under the hood... on the inside of the left wheel assembly.
  11. Dec 20, 2019 at 7:25 PM
    Job
    Job New Member
    Jon
    2001 tundra fed 4.7
    Intake exhaust
    It’s the bushing that wraps around the rack and clamps with 2 bolts. It’s on the left side. Mine makes an awful creaking noise that sounds like a ball joint or a arm bushing is groaning or creaking. My bushings were pretty beat up from my rack moving(I’ve had 33”s on for 40k of 185k miles and starting replace things) I swapped in Urethane ones and the groan changed quite a bit but still there. Rack was bad(slow and tight at both ends) so I replace it with oem rack from Cardone which already had bushings with tubes in the center pressed in. It’s installed, my rack moves around and sounds like a total pos. Horrible if I’m breaking in a turn or hit a bump. Not sure if I’ll shim it to squeeze the rack a bit harder or what. Going to ask the alignment shop. I could replace the oem bushings with my urethane set but would surely void the warranty... What to do??
  12. Dec 22, 2019 at 12:06 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    mine did this and was the lower ball joint. Maybe have someone turn the wheel with you at each front corner to listen?
  13. Dec 22, 2019 at 6:18 PM
    cammiller
    cammiller IG: cameron.a.mi
    Cameron
    Sulphur, Louisiana
    2004 Toyota Tundra Limited Phantom Grey Pearl
    Kicker speakers, Pioneer AVH-2550NEX Head Unit, DynaMat, LED Dash Conversion
    My 2004 is showing the same symptoms after a rough ride off-road (truck actually left the ground and slammed back down). Have a mechanic friend who owns a 2001 and he said it’s lower ball joints. Ordered a set Wednesday and they come in tomorrow. I’ll probably get to the install Thursday or Friday, and will flush the powered steering system at the same time. I’ll be happy to post pics and results if y’all would like.
  14. Dec 22, 2019 at 6:57 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Stupid question,
    What kind of control arms do you have?
  15. Dec 23, 2019 at 5:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Are you kidding, We love pics that may help future DIY's :pccoffee:
  16. Dec 23, 2019 at 6:06 AM
    Hand Protectors
    Pics and solutions we love!
    cammiller[QUOTED] likes this.
  17. Dec 23, 2019 at 7:52 AM
    cammiller
    Cameron
    Sulphur, Louisiana
    I just have the stock upper and lower control arms. No mods on suspension or power/drivetrain here yet. But I have a list of things I want to do. I’ll be happy to post pics and write ups! I’ll let y‘all know when I get the project done.
