Spyder lights
Discussion in 'Lighting' started by Grubblife18, Sep 13, 2017.
  1. Sep 13, 2017 at 3:56 PM
    Grubblife18
    Grubblife18 [OP] New Member
    2014 tundra limited
    6" readylift, rock star wheels on 33's and much more.
    IMG_4623.jpg IMG_4624.jpg IMG_4622.jpg This is my first post because I am new to the site so hope I did everything right. I installed Spyder led head lights and tail lights today. Very easy install. Plug and play and I got the grill of easily to. That's what was scary.
    CJ21, SullyMoto19, Backslider and 6 others like this.
  2. Sep 13, 2017 at 3:58 PM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    See? Easy peasy. :cheers:
    Kdgcng and GNTundra like this.
  3. Sep 13, 2017 at 4:03 PM
    Grubblife18
    2014 tundra limited
    Thanks. I appreciate the advice.
    smslavin likes this.
  4. Sep 13, 2017 at 4:13 PM
    Grubblife18
    2014 tundra limited
    Only bad thing was my battery went dead from testing and retesting them. ;);)
  5. Sep 13, 2017 at 4:16 PM
    edwin729
    edwin729 Tundra Life
    Edwin
    Arizona
    2014 White Tundra
    do the light bars in the headlights light up when drl switched to "ON"?
  6. Sep 13, 2017 at 4:21 PM
    Grubblife18
    2014 tundra limited
    Thanks I'll look into that.
  7. Sep 13, 2017 at 4:47 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Welcome from WI Jason! Here We Go Steelers!!!! :thumbsup:
  8. Sep 13, 2017 at 4:56 PM
    TheBeast The Beach
    looking good
    Grubblife18[OP] likes this.
  9. Sep 13, 2017 at 5:00 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    You're in trouble Now! It's going to cause a landslide of new mods you can do yourself!
    Kdgcng likes this.
  10. Sep 13, 2017 at 5:03 PM
    Kdgcng
    Kdgcng Rock steady
    Kyle
    2017 Magnetic gray tundra SR5 crewmax
    what he doesnt know is that this is going to be the beginning of a chain of mods!
  11. Sep 13, 2017 at 5:05 PM
    duece292
    Greg
    Green Bay, WI
    Jason, I can hear your wallet screaming from here :D
    Grubblife18[OP] and Kdgcng like this.
  12. Sep 13, 2017 at 5:16 PM
    smslavin
    Hudson Valley
    Some stuff
    yea, i left that part out. :cool:
  13. Sep 13, 2017 at 5:18 PM
    Grubblife18
    2014 tundra limited
    NewImprovedRon, Kdgcng and duece292 like this.
  14. Sep 13, 2017 at 5:55 PM
    Krappenschitz
    Krappenschitz New Member
    Eric
    Portland
    2017 Tundra Crewmax SR5 OR
    Trd pro grille, color match mirror caps, Magnum steps.
    Looking into Spyder lights myself. Do the headlights auto adjust or do you have to do it manually?
  15. Sep 13, 2017 at 6:36 PM
    You should add the HID converter for it too
  16. Sep 13, 2017 at 6:44 PM
    smslavin
    Hudson Valley
    Some stuff
    definitely. i did this. makes a huge difference.
    T-Rex266[QUOTED] likes this.
  17. Sep 14, 2017 at 4:23 AM
    Grubblife18
    2014 tundra limited
    I didn't add the hid converter yet but I might.
  18. Sep 14, 2017 at 4:25 AM
    Grubblife18
    2014 tundra limited
    They were already set
  19. Sep 14, 2017 at 4:26 AM
    Borgs
    Borgs New Member
    PA
    Auto. The leveling motors can be hooked up to the new Spyders. You have to be careful though, as they are not the easiest to remove from stock and install in the new Spyders.
  20. Sep 14, 2017 at 4:43 AM
    War Machine
    War Machine SSEM # 5 3MW
    I have the same ones. Yes they do.
  21. Sep 14, 2017 at 4:44 AM
    War Machine
    They are manual, but you can transfer the leveling motors from the stock ones into these. It was pretty easy.
  22. Sep 14, 2017 at 7:09 AM
    Literally a night and day difference. I used the @ToyTec Lifts one and have had zero issues.
  23. Sep 14, 2017 at 7:12 AM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    With the spyder bar light, is there a way to wire it so it's on with the drls? I'm thinking spyder, hid covert, switch back kit for yellow drl to white and bar light always on. Possible? Experts your opinions.....
  24. Sep 14, 2017 at 7:18 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Very nice. Sounds like you need to create your own build page.
  25. Sep 14, 2017 at 7:24 AM
    smslavin
    Hudson Valley
    Some stuff
    Not sure about the Spyders but I did something similar with my Recons. I don't have the factory DRLs so I took the wire for the bar light and used an add-a-fuse on the ignition circuit. Now, they are on whenever the truck is on.
  26. Sep 14, 2017 at 8:17 AM
    BakNBlk2014
    Donald
    Virginia Beach VA
    Thanks. I'm in a limited so just the u g l y yellow drl. Nice work around. May hit you up for some more info if I pull the trigger on these. Its these or the ba 2018 lights they are trying to harness up with the 14-17 models. Thanks again. Fan of your rig btw.
    smslavin[QUOTED] likes this.
  27. Sep 14, 2017 at 8:21 AM
    smslavin
    Hudson Valley
    Some stuff
    Mine is a Limited as well. I've kept the amber drl on. There's a post around here somewhere about how to disable that. It involves a small gray wire somewhere behind the leveling switch.
  28. Sep 14, 2017 at 8:23 AM
    BakNBlk2014
    Donald
    Virginia Beach VA
    Isn't there a switch back kit to Keep the turn signal but run white drl, or am I mistaken?
