Spring compressor
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kblood, Dec 28, 2021.
  1. Dec 28, 2021 at 7:34 AM
    Kblood
    Kblood [OP] New Member
    2017 SR5 Tundra
    I’m changing my struts from stock to 5100 bilstein struts/shocks. I only have a macpeherson spring compressor I’m wondering if that will work on the factory springs or do I need to get a bigger spring compressor?
  2. Dec 28, 2021 at 7:49 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I don't recommend doing it. Find a shop. I went down that road and severly regretted it. Still ended up spending the money to have a shop do it.
    I will NEVER go down that road again. Thank goodness I didn't maim myself.
    Tundra-in-Cement likes this.
  3. Dec 28, 2021 at 7:53 AM
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    Yea should work just fine, that’s what I used earlier this year. Helps if you have a friend, but totally do-able on your own. Just take your time and make sure everything is where it needs to be.
    Hoff and Kblood[OP] like this.
  4. Dec 28, 2021 at 8:01 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    HulkSmurf14, 1UP and Kblood[OP] like this.
  5. Dec 28, 2021 at 8:17 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I used 4 total of the o'reilly rental ones on each spring, it worked, but it is a bit scary. I'd definitely use something more stout, but other than that it's not too terrible of a job.
  6. Dec 28, 2021 at 8:24 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  7. Dec 29, 2021 at 5:07 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
  8. Dec 29, 2021 at 6:21 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
  9. Dec 29, 2021 at 7:54 PM
    Welcome from NY.
  10. Dec 29, 2021 at 8:10 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Please just pay a shop that bill and have them do it. A broke jaw or nose or reconstructive surgery is not worth it. Those kits don't even properly fit the giant wire diameter of our springs.
  11. Dec 29, 2021 at 8:19 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    the old widow makers. I’ve swapped all of my 5100’s using those. All bent up and foreboding. I was very careful not to stare down the barrel of those things once compressed.
    BlueCrushSC16 likes this.
  12. Dec 29, 2021 at 8:35 PM
    Chip_Tundra
    Chip_Tundra New Member
    Get yourself one of these, learn how to use it, or just pay a shop to do it for you. Doesn't matter if others had success with cheap tools. Don't risk your life and get it done the right way.
    AggiePhil likes this.
  13. Dec 29, 2021 at 8:36 PM
    parkerbows
    Jack
    1. I disagree that the one I posted is unsafe at all, but that's my opinion
  14. Dec 29, 2021 at 8:47 PM
    They are all unsafe. Or at least only as safe as the operator. Your storing a massive amount of energy in a small space. Dangerous indeed.
    AggiePhil and alb1k like this.
  15. Dec 29, 2021 at 8:51 PM
    parkerbows
    Jack
    Ok I agree they can all be unsafe if not done correctly. I will just say it was extremely easy and felt very sturdy doing mine. Actually felt stupid after thinking it was gonna be sketchy
  16. Dec 29, 2021 at 9:01 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I have pondered this a few times…..for the limited amount of times that I will be changing my shocks, I MUCH prefer to pay a local shop to do this job work for me. I can install them and save the labor costs after they do the springs and still get the satisfaction of knowing I saved some $ on that part of it. I have a friend who tried to do this himself and had one of the cheaper tools. Almost literally took his face off. Swore to myself I would never attempt it after that.
    JuanTon21 and alb1k like this.
  17. Dec 29, 2021 at 9:05 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Wood clamp safety back-ups for the win. :thumbsup: :eek:
    Kblood[OP] and HulkSmurf14 like this.
  18. Dec 29, 2021 at 9:09 PM
    parkerbows
    Jack
    At that point I would just let them do the whole job, since u need an alignment after also
  19. Dec 29, 2021 at 9:13 PM
    shawn474
    MoCo, Maryland
    i like to wrench and find it therapeutic to be out doing stuff like that. More for my peace of mind than anything else……and often saves a few dollars. Takes longer and pisses my wife off sometimes but maybe that’s part of the appeal
  20. Dec 29, 2021 at 9:17 PM
    parkerbows
    Jack
    I hear that
  21. Dec 29, 2021 at 9:18 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Someone else posted in another thread that they bought one similar to this for around $100. Well worth it. Don’t use the rental ones. I did that twice, didn’t get hurt, but still feel stupid twice.
  22. Dec 29, 2021 at 9:27 PM
    Dalandshark
    Northwest
    Eibach Level LIft
  23. Dec 30, 2021 at 7:54 AM
    HulkSmurf14
    2014 Tundra Limited
    $1000 gofundme program will get me one...otherwise, garage tactics must perform...
  24. Dec 30, 2021 at 8:59 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Yup. Did mine with widow makers. You have to be confident and careful in what you're doing compressing the spring evenly as you go.
    Rodtheviking likes this.
  25. Dec 30, 2021 at 9:10 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    2017 Limited Crew TRD, Ironman Pros with JBA uppers. Prinsu rack. RSI, RCI sliders
    I bought two sets from Harbor Freight and used three of the screws to do mine, just go slow and NO impact gun. Lining them up properly is a pain though, pay attention to the top hat alignment.
  26. Dec 30, 2021 at 9:12 AM
    BlueCrushSC16
    Charleston, SC
    LOL. I used an impact gun. I like living life a little dangerously.
    HulkSmurf14 likes this.
  27. Dec 30, 2021 at 9:12 AM
    parkerbows
    Jack
    I found this a plus as far as lining up
    HulkSmurf14 and Sumo91 like this.
  28. Dec 30, 2021 at 9:16 AM
    Sumo91
    TN
    This. I love this spring compressor, not sketchy whatsoever, no bending or bowing. And compressed my springs with ease.
  29. Dec 30, 2021 at 9:19 AM
    parkerbows
    Jack
    Yeah I was very impressed with it. But I get people not trusting them, I just felt it was super locked in place and hardly any resistance cranking it down
    Sumo91[QUOTED] likes this.
  30. Dec 30, 2021 at 9:38 AM
    biebs96
    PA
    Those things scare me for sure.
    Find a local mechanic and I bet you’ll be happier.
    My shop swapped out my shocks with 5100s and uninstalled/reinstalled the entire assembly for $250. Worth every penny to me, and I am someone who is not afraid to tear stuff apart.
