Spod plug through firewall.....help please.
Discussion in '2.5 Gen Tundras (2014-2021)' started by CorsoTundra, Feb 19, 2020.
  1. Feb 19, 2020 at 7:30 AM
    CorsoTundra
    CorsoTundra [OP] This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    So, I'm about to install my 700-Tun Spod and I need advice on getting the harness's white plug though the firewall (for the second time......I F'd it up on last attempt). Has anyone done this? Any tips? I thought about drilling a 1" hole through the bottom of the big rubber grommet, very slowly, as low as I can away from the big mess of wires going through there. Thanks in advance.
  2. Feb 19, 2020 at 7:33 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Does the other end have a smaller connector? If not, take some pics of the wire config, de-pin it, tape it up, shove it thru and re-pin it.
    ElNopal likes this.
  3. Feb 19, 2020 at 7:40 AM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    get a partner and a flat head screw driver, stick the flat head between the out edge of the grommet and the fire wall and push towards the center of the grommet, have your buddy feed the harness thru, pull the flat head out and the grommet will seal around the harness. thats what I did 4 years ago when I installed mine.
  4. Feb 19, 2020 at 7:56 AM
    CorsoTundra
    North GA
    Other end is larger.
  5. Feb 19, 2020 at 7:57 AM
    CorsoTundra
    North GA
    That may work. Thank you.
  6. Feb 19, 2020 at 8:13 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    mark the wire positions on the connector, de-pin the wires from the connector and wrap in electrical tape. then push thru the firewall, repin the wires into the connector.
    That looks like the one that goes behind the sunglasses holder, but its been a couple years since I did mine.
  7. Feb 19, 2020 at 9:51 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    That's a standard Molex connector. Take a picture of the back of the connector noting wire locations. Then take a small or Jeweler's flat blade screwdriver. One wire at a time push from the rear of the connector and insert the jeweler's screwdriver in the front. This should depress the locking tab and then pull the wire and pin out from the rear of the connector. Hope this helps
  8. Feb 19, 2020 at 9:56 AM
    CorsoTundra
    North GA
    Thank you for all the suggestions. :thumbsup:
  9. Oct 8, 2020 at 10:37 AM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    soooo, I'm about to do this job. What did you end up doing?
  10. Oct 8, 2020 at 10:51 AM
    CorsoTundra
    North GA
    I cut a slit in the firewall rubber grommet from the top about 2" or so, reached my hand up to pull the rubber down a bit and while the connector (taped up nice and tight with electrical tape) was in my hand as well, I started to slowly feed the connector through the slit I made until there was enough showing in the engine bay side where I could pull the rest of the loom through.
  11. Oct 8, 2020 at 10:56 AM
    TundraPHX
    Jared
    Thank you. I'm excited to get going
    CorsoTundra[OP] likes this.
  12. Oct 8, 2020 at 10:57 AM
    CorsoTundra
    North GA
    Welcome
  13. Oct 8, 2020 at 11:02 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I tried for about 3 hours to depin the connector and only got 1 or 2 wires out so I just cut the damn cable :) I had a bunch of other wires going through the firewall already so getting a connector through there wasn't going to happen.
    cowboyjack likes this.
