Splicing together fogs question
Discussion in 'Lighting' started by hookdem, May 27, 2020.
  1. May 27, 2020 at 6:46 PM
    hookdem
    hookdem [OP] New Member
    Austin, TX
    I may have gone down a rabbit hole, and over thinking this...
    I got a C4Fab Hybrid bumper, powder coated and ready. And a light bar, and three sets of fogs to mount into it. I plan to wire the light bar to a dash switch. I plan to wire one set of SAE compliant fogs to my stock (existing) fog light control.
    And the other two sets, I want to wire together to a single dash switch. Partly because I only have three blanks to add switches to, and one of those is being saved for an air compressor install, so I’m left with two blanks for lighting switches. And partly because I don’t see a need to control them individually.
    So my question is this. Can I just splice together the two sets, to one wiring harness and run that one harness to a switch?
    In my quest to validate my assumption, I’ve been here for a few nights reading about light installs, wiring, relays, and sucked into naughty thoughts of SPOD and Switch Pros. I literally had SwitchPros in a cart awaiting payment... But. And that’s a hard But. I have enough blanks, and I already have the “OEM” switches, and I don’t plan on any additional accessories...besides maybe a winch, which wouldnt go on the switch pro anyway.
    So. If you’ve know the answer to the simple question, please save me from another night of reading, and more likely save me $600 and a wait for shipping of a switch pro.
    some considerations. The two fogs I want to control on one harness are:
    Rigid D Midnight pro @ 29watts
    Rigid SR-M Midnight pro @ 10 watts
    39w / 12v = ~ 3.25 amp draw
    the wiring harnesses for both these sets do not have a relay. I do however have a harness that I can use from a set of DXLs that do have a relay. The DXLs I plan to plug n play directly to the stock wiring.
    so what started as “I’ll just splice together the (non relayed) harness all willy hilly” turned into “well shit, should I use the relay harness instead...or is that relay too weak...or should I buy a relay and wire my own harness...or ooooh that SwitchPro is pretty...”
    surely, fogs can be spliced together. But what should I look out for?
    ...save me
  2. May 27, 2020 at 6:55 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    All I know is I have two sets of diode dynamic saw approved dogs hooked up to my stock fogs. I got a splitter and they work no problems.
  3. May 27, 2020 at 7:41 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    3.25amps isn't much draw. Stock replacement Sylvania halogen bulbs are 1.9amps though.
    Might be a good idea to run the relay. Or plug them in and you pop the fuse then you know it's a no go. Replace the fuse and use the relay.
  4. May 28, 2020 at 5:13 AM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    The splitter I used was $15 off Amazon. You can try it and if it doesn’t work than do what @GiantsFanDan said
  5. May 28, 2020 at 5:47 AM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    C1BBFDFF-C78E-4307-911A-85F2AD712126.jpg Duestch to 9006
    1lowlife likes this.
  6. May 28, 2020 at 6:28 AM
    Alexstundra[QUOTED] likes this.
  7. May 28, 2020 at 6:32 AM
    If you are running a harness from the battery to the dash, this is the splitter that you need. https://www.amazon.com/iJDMTOY-Y-Sh...hape+splitter+light+bar&qid=1590672465&sr=8-1 I run 2 sets of Rigid Duallys on mine with no issues. The splitter that @Alexstundra linked is for the fog light connector.
    Alexstundra likes this.
  8. May 28, 2020 at 11:43 AM
    hookdem
    Austin, TX
    @Tundra234 yup, I’ve had those in my cart but was waiting to see if that method would cause draw issues on the included rigid harness.
    @Alexstundra appreciate the responses, but yeah, I’m going from 2 fogs-rigid-harness-new dash switch
    So. I’ll just plug n play, if a fuse blows, I’ll go the route of a relay
    appreciate the help guys
  9. Jun 1, 2020 at 9:21 AM
    Sequoiar
    Sequoiar New Member
    tagged for follow
  10. May 17, 2021 at 1:43 PM
    Manfred
    Manfred New Member
    Manny
    Pennsylvania
    2010 Toyota Tundra double cab
    Ranch Hand headache, Bodyguard Traditional Extreme Front Bumper, Ranch Hand Rear Bumper, ICON struts and shocks - 3" lift. LED exterior light conversion. KC Off-Road LEDs on front bumper.
    Just out of curiosity, what did you end up doing? I have 2 6" KCs I want to add to my new bumper but not sure if I should add to the same switch as fog lights are on, or use a separate switch?
