Spec d headlights install
Discussion in 'Lighting' started by Nickster513, Oct 2, 2018.
  1. Oct 2, 2018 at 8:15 PM
    Nickster513
    Nickster513 [OP] New Member
    08 tundra sr5 4.7 4x4
    Hey guys new here. I installed a set of speed d taillights simple plug and play. On my 2008 toyota tundra now I just got the headlights and installed them and followed their videos. And the halos and LEDs work. But they turn off when I turn on my low beam and they flash like the turn signal when they're on. I am thinking about wiring them to the parking light which only turns on and stays on when I'm on my second light option that illuminates my dash and taillights and then will also stay on with the normal low beam and high beam modes. My only concern is that the parking light might not make enough power to power the halos and LEDs has anyone installed these before and it seems like that's the way I should install them to have them on almost all the time. Thanks in advance
  2. Oct 2, 2018 at 8:20 PM
    Rica25
    Ricardo
    Tulare
    I did mine that way and has been fine for about 4 months now
  3. Oct 2, 2018 at 8:27 PM
    Nickster513
    So you hooked the halos and LEDs to the far side orange light (parking light) and it was all good? if so perfect! Thanks for the help
  4. Oct 2, 2018 at 8:30 PM
    Rica25
    Ricardo
    Tulare
    Well mine are not halos its LED strip but I'm sure very similar
  5. Oct 2, 2018 at 8:32 PM
    Rica25
    Ricardo
    Tulare
  6. Oct 2, 2018 at 8:32 PM
    Nickster513
    Perfect thanks I checked your truck out looks awesome! Lots of things that I want to do to mine aswell. After these I'm planning on tow mirrors. Subs or leveling kit not sure what first yet. For your leveling kit was it just the 5100 bilsteins or did you need extra parts? Or was it just the 4 shocks. And for sure the trd sway bar :).
  7. Oct 2, 2018 at 8:33 PM
    Nickster513
    Looks sweet too bad spiders are worth 600 here in Canada:/
  8. Oct 2, 2018 at 8:34 PM
    Rica25
    Ricardo
    Tulare
    5100 all four with high setting on front and half inch spacer from Toytec
  9. Oct 2, 2018 at 8:35 PM
    Nickster513
    If I didn't get the spacers would I just run the fronts on the medium setting? And just curious did you install it yourself?
    Rica25[QUOTED] likes this.
  10. Oct 2, 2018 at 8:36 PM
    Rica25
    Ricardo
    Tulare
    Yes all my self except alignment this was my second set of shocks or struts installed
  11. Oct 2, 2018 at 9:16 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That looks bad ass with those headlights and all that amber up front.
  12. Oct 2, 2018 at 9:33 PM
    Rica25
    Ricardo
    Tulare
    I need LED bar or hood spot lights
    Pudge likes this.
  13. Oct 2, 2018 at 9:35 PM
    Pudge
    CT
    I vote light bar in lower valance, keep it looking clean.
  14. Oct 2, 2018 at 9:41 PM
    Rica25
    Ricardo
    Tulare
    Lower are is 3 piece or should I cut the dividers to put one solid peace?
  15. Oct 2, 2018 at 9:48 PM
    Pudge
    CT
    Oh yeah forgot how those openings are broken into 3 areas. I think the openings are kind of rounded too, may not look good if you cut them. Maybe 3 separate smaller bars, or tuck one big one in behind so you don't need to cut anything. Those dividers will block some light but not much probably
  16. Oct 2, 2018 at 9:57 PM
    Rica25
    Ricardo
    Tulare
    Does anyone have some pics of this?
