Size of door tweeters?
Discussion in '1st Gen Tundras (2000-2006)' started by Nopper1, Mar 16, 2020.
  1. Mar 16, 2020 at 12:09 AM
    Nopper1
    Nopper1 [OP] New Member
    2001 tundra limited
    Im looking to upgrade the sound system, I got the speaker size but what size are the tweeters on the door?
    Rica25 likes this.
  2. Mar 16, 2020 at 6:05 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    Not exactly sure of the size, but I got a quote from James at Tech12volts for JL Audio C1-650's for all four doors.
    They come with the the JL Audio C1 Tweeters which are 3/4 in size. Mignt try reaching out to James he would know for sure.
  3. Mar 16, 2020 at 9:19 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I installed Kenwood Component speakers and the tweeter fit perfectly after removing the Kenwood tweeter mounting hardware/grill and just use the naked tweeter. It will take you about a minute to pop off the factory tweeter cover on the door and take a look or measure the stock tweeter. Pic from Crutchfield showing the stock tweeter.
  4. Mar 16, 2020 at 3:34 PM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    That ain't where my tweets are. They're in the doe.
    Darkness likes this.
  5. Mar 16, 2020 at 10:21 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    OP, 3/4 to 1 inch tweeters is pretty much the norm. Just get yourself a nice 6.5 inch component set within your budget. I mean it's not like your door is going to have 6.5 inch tweeters. LOL
    10TundraSR5 likes this.
  6. Apr 22, 2020 at 8:34 AM
    Climbcovey
    Climbcovey New Member
    Indianapolis, IN
    2019 Tundra Platinum
    K & N filter, TRD Exhaust, TRD sway bars, 3/1 Leveling kit, 285/55 R20 BFG TKO's, Fuel Rims, RAS helper springs, Bushwacker DRT flares, center console safe, Interior pocket limers (red trimmed).
    Weadjust, What model of kenwood speakers did you go with? And are you satisfied. I have the "JBL" 6 speaker system, found out the hard way after my speakers disinegrated from age that the speakers are toyota specific (pair with the stock amp). I replaced the head unit & speakers, epic fail, sounded like crap. Returned the speakers and have been a 1 speaker system for a year. Now looking to pull the amp and wire straight from the new head unit. Looking for "drop in" component speakers with good sound... Unless any of you have found a correct ohm speaker to work with the JBL system that doesnt cost $400 each (OEM Replacement)
  7. Apr 22, 2020 at 10:36 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    So did you just join to ask questions or are you going to say hi and introduce yourself a little and show us your truck?
    Many of us are happy to help, but try, just try to use the search function first.
  8. Apr 22, 2020 at 12:01 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    In the front doors I used Kenwood KFCP510PS Component Speakers. I went with these speakers because they have a inline crossover so I wouldn't have to mount a crossover in the door and Crutchfield website said 5.25" was the correct size to use. I bought the speakers from Amazon. A 6" or 6.5" would also have fit in the front doors after doing the install. I have been pleased with the sound. I installed Rockford Fosgate P16 Punch 6" 2-way Full-Range speakers in the back doors.
  9. Apr 22, 2020 at 2:30 PM
    Climbcovey
    Indianapolis, IN
    Wow Toyotaholic, Quarantine must be getting to you. Do I detect a little pent up frustration and hostility? If you must know, I intend on posting pics and updating my profile, Just haven't had the time. Being a Firefighter /EMT and a Trauma Nurse in the ED, I have found myself quite busy working 2 jobs and 36 -60 hrs of overtime each month since December. I had searched the forum when I joined in November (when my speaker problem started) There was a little info. As well as 1 full write up on utilizing the existing amp. However, Not to many people voice specific model numbers and satisfaction with all the different setups. Since this was a New thread as of last month, I though I would inquire with weadjust his opinion. I apologise that you had to read my thread or question, and that you felt obligated to respond in such an exasperated way. Perhaps you should try yoga...https://youtu.be/Dkk9gvTmCXY
    Weadjust, Thanks for the reply. I also have considered a set of 6 3/4 set of Kickers I found back in November.
    https://www.bestbuy.com/site/kicker...nes-pair-yellow-black/6333347.p?skuId=6333347. Just afraid to pull the trigger, still doing research and deciding if I really want to rewire the system and add extra components which when all said and done would cost the same as buying stock replacements... And.. this is soon to be my "work truck". Got my eye on the 2020 or 21 Taco.... If this overtime continues. I truly appreciate the info. thanks again.
  10. Apr 22, 2020 at 5:57 PM
    weadjust
    weadjust New Member
    Tupelo, MS
  11. Apr 22, 2020 at 6:01 PM
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
  12. Jul 10, 2021 at 10:36 PM
    Nopper1
    2001 tundra limited
    Thank you all. Much appreciated!
  13. Jul 11, 2021 at 8:23 AM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    These came with the mids I bought for the front doors. I just pulled the OE tweeters and screens out.
