Spare Tire Pulley Lube
Discussion in '2.5 Gen Tundras (2014-2021)' started by TXMiamiFan, May 5, 2017.
  1. May 5, 2017 at 11:23 AM
    TXMiamiFan
    TXMiamiFan [OP] SSEM #3 and tractor extraordinaire
    Jose
    2016 White Crew Max TRD
    Has anyone lubed the pulley/chain that raises and lowers the spare tire? And if so, what did you use? I removed the spare to do the rear diff breather mod, and now that the spare is off, figured would be a good time to clean and lube moving parts. This one is particular looked like it could use some lubrication to keep it from sticking/rusting. Tried looking for other posts on this topic but didn't find one. Apologies if I just didn't look hard enough. What do y'all recommend for that? Thanks in advance.
    NewImprovedRon likes this.
  2. May 5, 2017 at 11:33 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  3. May 5, 2017 at 11:36 AM
    TXMiamiFan
    Jose
    Thanks. Wonder if this is the same type as what I use on my bicycle chains. Wonder if I cold use that too.
  4. May 5, 2017 at 11:39 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    im sure same stuff..
    lube is lube right? throw some KY jelly on that b*tch!!
    Law323 and joonbug like this.
  5. May 5, 2017 at 11:44 AM
    TXMiamiFan
    Jose
    Vaseline better, right? Keep water away vs KY.
  6. May 5, 2017 at 11:56 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That reminds me, I need to drop mine to make sure it's not seizing up. A spare that you can't get out from under your truck is pretty useless - I used to drop the one on the Taco when I rotated tires, to keep it free. I'll probably use aerosol Never-seeze in mine. Fluid film would be a good choice too.
    Years ago, I needed a torch to cut the chain for my spare off my '83 pickup. Glad I found that before I was way and gone and needed it.
  7. May 5, 2017 at 11:58 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, Vaseline works best... :D
  8. May 5, 2017 at 11:58 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    There ya go Phil!
    I'm sure roads take a toll on the under body in your region, Comifornia isn't bad.. other than all BS laws and regulations etc..
    joonbug likes this.
  9. May 5, 2017 at 12:04 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Not as bad here as other area of the country, like @Krezz 's stomping grounds. We have a fairly dry climate and shorter winter than average here. Still get enough salt and sand to cause issues though.
    Krezz and dcsleeper408[QUOTED] like this.
  10. May 5, 2017 at 1:00 PM
    No but i will now with some PB Blaster while i painted rear bumps waiting to dry
    dcsleeper408 likes this.
  11. May 5, 2017 at 1:54 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    The brine they throw on our roads is terrible for vehicles.
    AxelsHumanDad and dcsleeper408 like this.
  12. May 5, 2017 at 1:54 PM
    Good topic Jose. Hadn't even considered the possibility of corrosion problems and spare tire function.
    Wonder if a spray on graphite lube would work?
    Funny, I always test out the spare tire function on new vehicles to see how it works. The other day was the GMC testing. That was fun. I can tell you all one thing, I will be hunting CL for an aluminum wheel. I will say this, GM makes it tough to steal the spare.
  13. May 5, 2017 at 5:22 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Just spit on it a little Jose. Definitely works in a pinch.
  14. May 5, 2017 at 5:26 PM
    TXMiamiFan
    Jose
    Will keep that in mind if out in the woods :thumbsup:
    Pudge[QUOTED] likes this.
  15. May 5, 2017 at 5:50 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Krown rust protection, fluid film, transmission fluid or motor oil will do the trick if do it annually
  16. May 5, 2017 at 5:54 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Many lubricants and penetrating oils stay oily and leave a residue that will collect dust that cakes on and can actually cause failure. Your hi lift jack is an example of that. For the spare lift I would suggest something like chain wax, which I use to put on my dirt bike chains.
  17. May 5, 2017 at 6:08 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    X2
    4 flats in 9 months and I can tell everyone now...don't get a flat in a GMC
  18. May 5, 2017 at 6:14 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Work vehicle, 3ply tires, about 1500+ lbs in the back and washboard roads
