Spare tire flat
Discussion in 'Wheels & Tires' started by cujman, Oct 10, 2018.
  1. Oct 10, 2018 at 7:12 AM
    cujman
    cujman [OP] New Member
    2011 SR5 crewmax
    air bags, leer cap
    Anyone experienced this. I had this with both my 07 and 011 Tundras. Toyota does not put a warning sensor on the spare and dealers don't check the spare when servicing the vehicle. With both trucks I have been caught with a flat tire and then found the spare to be flat
    The Cujman
  2. Oct 10, 2018 at 7:17 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I guess that means , it is the owners responsibility to make sure it's not flat. Hmmm , that reminds me....
  3. Oct 10, 2018 at 7:26 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I better check mine. The Tacoma I had had sensors in all five. I just assumed the tundra did too.
  4. Oct 10, 2018 at 8:32 AM
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
    I've had the TPMS light come on and the dealer determined it was my spare on my 2013. That led to me dropping the tires on all 3 trucks and airing them up.
    jewsNbrews likes this.
  5. Oct 10, 2018 at 8:44 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I don't think there's a sensor in the spare on the Tundra. There certainly isn't in mine since it's not stock. Gotta love having onboard air for filling flats.
    joonbug, TheBeast, 15whtrd and 2 others like this.
  6. Oct 10, 2018 at 8:53 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Just had the opportunity to use my 07 spare don’t think it’s ever been looked at before the tire was dry rotted but had air and held it but the rim was so rusted the lugs wouldn’t stay tight
    Scored new spare from Craigslist off a 2016 never used $30
  7. Oct 10, 2018 at 11:06 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I had a flat on a rental Chevy Impala a few years ago and the spare wasn't totally flat but definitely needed air. On my truck I check the spare and the other 4 every time I change the oil. Twice a year I pull the spare, wash it, 303 the whole tire, fluid film the chain and winch and put it back up. A little preventative maintenance goes a long way.
  8. Oct 10, 2018 at 12:11 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    My Tacoma had a sensor on the spare which was nice.
    I dropped the spare (18" Michelin ltx ms2) on my tundra a few days after I got it. I flipped it over so the valve stem faced down for easy access to check it and fill it. I filled it to 45psi and it's still holding air last time I checked. I check when I change oil and or rotate tires.
  9. Oct 10, 2018 at 12:14 PM
    15whtrd
    15whtrd Mr. Blonde
    Mine was flipped valve stem down from the factory. Interesting
    NewImprovedRon and Pudge[QUOTED] like this.
  10. Oct 10, 2018 at 3:36 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    I didn't realize the gen 3 Tundras did not have a sensor in the spare. My 2006 Tundra had sensors in all five and when the low pressure light came on, it was usually the spare that had bled down to set it off.
    Pudge and jewsNbrews like this.
  11. Oct 10, 2018 at 4:31 PM
    Pudge
    CT
    Same here. Every year in Oct or Nov I would get the sensor alert, from the cold weather. I. Surprised our trucks don't have a sensor in the spare
  12. Oct 10, 2018 at 4:32 PM
    Pudge
    CT
    That's strange our trucks were different. Definitely makes sense to have it that way though.
    15whtrd[QUOTED] likes this.
  13. Oct 10, 2018 at 4:43 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Another surprise I discovered is the low threshold for the low pressure light to come on. I was just starting to work one morning and I saw the light on and worried I had a tire going flat. It turned out that the left front was at 28psi (placard says 30psi). Once I drove a bit to warm the tire up, the light went out. No puncture or other issues at all.
    I would prefer a 5psi threshold so that if the light goes on, there definitely is an issue. I now check my pressures more often (typically I have found with Michelin tires that they very slowly lose pressure over time, better than other tires I've owned).
  14. Oct 10, 2018 at 5:16 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Get a tire repair kit. I could do a tire repair on the side of the road in under 20 minutes.
  15. Oct 10, 2018 at 5:28 PM
    Professional Hand Model
    Hand Protectors
    Just had new tires installed. Asked them to do the spare tire change with the better of the removed (older) tires and they couldn’t find the key to drop the spare down. They did the last change 5 years ago, so now they need to buy a new key! $50 is the cost online.
    Btw, thankfully never had to change a spare on the 02’ in 17 years. Good to practice as others mentioned. Also, as others mentioned its good to grease the drop cable mechanism.
    Winters coming so be prepared for dropping tire pressures.
  16. Oct 10, 2018 at 6:10 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I normally flip mine over too so the valve stem is accessible. 3rd Toyota and all had stems up. Seems stupid to me.
