Spacers... Yay or Nay?
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, May 8, 2019.
Would you run spacers?
  1. Absolutely not-Just start cutting instead
    16 vote(s)
    41.0%
  2. Yes, depending on the type
    23 vote(s)
    59.0%
  1. May 8, 2019 at 8:18 AM
    FirstGenVol
    FirstGenVol [OP] Recovering mangler
    East TN
    2002 AC TRD 4x4 V8
    Looking for some feedback on spacers. Some say they have run them for years without issue and others say "stay away".
    Let's hear it.
  2. May 8, 2019 at 9:00 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Nah. I'd just run a different offset wheel. spacers are just another point of failure.
  3. May 8, 2019 at 9:08 AM
    Casper421
    In the woods
    06 DC
    I ran spidertrax on my 4th gen 4runner for 8 years with absolutely no issues.
    I would stay away from the cheap no-name brands though.
    Sunnier, escuzi_me, khens12 and 4 others like this.
  4. May 8, 2019 at 9:10 AM
    Marty McFly
    Morty McBoonJug
    I had that dilemma also. I wanted to keep my PRO wheels but wanted a more aggressive stance. I think spacers will work with no issue if you get the right ones, but i didn’t want to take the chance so I got new wheels
    marbleville likes this.
  5. May 8, 2019 at 9:17 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    +1 FPNI
    Blueknights75 likes this.
  6. May 8, 2019 at 9:19 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I've run them for years no issues, knock on wood. Just think of them as part of your normal routine maintenance schedule. When you get an oil change, re check the torque, extra 15 mins and done.
    MrAristo likes this.
  7. May 8, 2019 at 9:20 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What are some good options for our trucks? One person said to make sure you get spacers that are "hubcentric".
    Boerseun likes this.
  8. May 8, 2019 at 9:25 AM
    MSbowhunter48
    MSbowhunter48 New Member
    2011 White Tundra Rock Warrior Edition
    Fat Bob’s 3/1 Leveling kit Rock Warrior Wheels 317/70R17 Cooper AT3 XLT
    BORA and Spidertraxx are the only two I would order from. Both are hubcentric and lugcentric. I have 1” bora spacers and have no issues.
    Sunnier, escuzi_me, andy9743 and 3 others like this.
  9. May 8, 2019 at 9:31 AM
    Berdine
    Binghamton, NY
    Definitely hub centric ones
  10. May 8, 2019 at 10:13 AM
    Casper421
    In the woods
    06 DC
    I’ve only personally run spidertrax so that’s what I’ll recommend. Bora and All-Pro seem to have good reputations as well.
    You’ll be completely fine running wheel spacers. I may end up running some small ones in the front due to frame rub.
  11. May 8, 2019 at 10:26 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think you answered my next question. I wasn't sure if it would look funny if I only ran them up front vs all 4. Seems like the only reason to do it in the rear would be for looks.
  12. May 8, 2019 at 10:29 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I would only use tham if I had clearance issues with the UCA. Then I would look into wheels to resolve the issue ASAP. I personally don't want my track width any wider or to look like one of those twats that have the wheels sticking way out and never get offload because they can't fit the trails. :crapstorm:
    Black Wolf likes this.
  13. May 8, 2019 at 11:04 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    3rd gens really don't fit the trails regardless.. :stirthepot:
  14. May 8, 2019 at 11:42 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've been trying to tell you man!
  15. May 8, 2019 at 12:40 PM
    Casper421
    In the woods
    06 DC
    Darkness[QUOTED] likes this.
  16. May 8, 2019 at 1:19 PM
    Berdine
    Binghamton, NY
    I'm running these, ran the same ones on my wrangler for 2 years. I had Bora on my 07 tundra
    Check this out at Amazon.com ECCPP 5x150mm hubcentric Wheel Spacers 5 lug 4x 2 inch 5x150 to 5x150 110mm for 2008-2016 Lexus LX570 2008-2016 Toyota Sequoia Tundra Land Cruiser with 14x1.5 Studs https://www.amazon.com/dp/B06W2KWQMY/ref=cm_sw_r_other_apa_i_iMZ0CbGSDEAWF
  17. May 8, 2019 at 1:32 PM
    smy
    smy New Member
    Would need to pay attention to the total offset of your wheels after the spacers are on. Too much of an offset would put a lot of strain on the wheel bearings.
  18. May 8, 2019 at 3:51 PM
    Professional Hand Model
    Hand Protectors
    Nega Nay Nay Bae Bae.
    Too much leverage on the system.
    marbleville and ethan1911 like this.
  19. May 8, 2019 at 4:00 PM
    My 2nd gen does...
    Sunnier likes this.
  20. May 8, 2019 at 4:00 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    This brings up a good point. We need to know what your plans are. What is your current backspacing? What size tire did you decide on? What are you looking to avoid rubbing on?
    Too much total backspacing and you'll hit pinch weld real bad.
  21. May 8, 2019 at 4:15 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    That's a myth.
    No more leverage than having wheels with say a +20 offset, which is a common aftermarket wheel. Whether the whole wheel move the offset or the combination of the wheel and spacer move the offset, the leverage on the system is exactly the same.
    In fact it reduces the leverage, because OEM is +60, which means it is further from centered on the wheel than with the spacers. i.e. more torque moment on the bearings.
    Sunnier and Cacoleman2014 like this.
  22. May 8, 2019 at 4:22 PM
    Hand Protectors
    Just to be sure I understand. I think I read you comparing spacers vs. aftermarket wheels with offset. Are you also comparing the leverage ‘myth’ against wheels designed for the vehicle (OEM) vs. spacers/aftermarket offset wheels?
    Sunnier likes this.
  23. May 8, 2019 at 4:27 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I wouldn't call it a myth. The added stress on bearings is dependent on how far out or in the wheel is, and the realistic increased or decreased distance from center isn't likely to destroy bearings quickly, but calling it a myth is saying it doesn't happen. Wear will happen faster but not as exaggerated as some think. Once you get into aftermarket wheels and big tires, that's all something you've accepted. I plan to eventually run a wheel with 3.5" backspace which is close to what a stock wheel with 1.5" spacers becomes.
    I've never run spacers for my own comfort, less chance of problems. Lots of people run them trouble free but I prefer not to gamble.
    FirstGenVol[OP] and Black Wolf like this.
  24. May 8, 2019 at 5:03 PM
    Berdine
    Binghamton, NY
    It's the same as running a wheel with the same offset
  25. May 8, 2019 at 5:11 PM
    turboser91
    turboser91 New Member
    Fresno
    06 DC 4x4
    6" RCD lift
    I'm currently using Spidertrax spacers with the TRD pro wheels and no issues. Just torque them to spec and check every time you do a tire rotation and you should be fine.
  26. May 8, 2019 at 6:59 PM
    Boerseun
    Ferdie
    Sarasota Florida
    I agree. What I meant by myth is that it is not a true statement to say that :" spacers are bad for your bearings, get aftermarket wheels if you want your wheels to stick out" which is usually what the discussion on spacers are about. People want their wheels to stick out a little more without having to buy new wheels. So same offset is same offset = same potential damage to bearings.
  27. May 8, 2019 at 7:07 PM
    Boerseun
    Ferdie
    Sarasota Florida
    Yes, that is what I said. People add spacers in lieu of buying new wheels with different offset. If the spacer gives the same new offset as the new wheels would (my +20 example) then the moment (force x distance) on the bearings are the same. Then I added the comparison of that setup with OEM wheel (+60) and noted that +60 is actually further from the center (more or less where the bearing is) than the aftermarket/spacer wheel, so the OEM might actually put more stress on the bearing than the aftermarket/spacer wheel.
    I am not trying to argue with anyone - just stating the facts. It is a little more complicated; we can go measure the distance that the bearing is behind the mounting surface of the wheel etc. but that is the basics of it.
    Darkness likes this.
  28. May 8, 2019 at 7:36 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The bearings on a first gen are tucked in pretty far when compared to the mating surface of the wheel on the hub/disc. This is probably why the stock wheels are deep on the offset, it's to bring the wheel center inward.
    We're on the same page @Boerseun
  29. May 8, 2019 at 7:48 PM
    CrewMaxT
    CrewMaxT New Member
    Alberta
    2018 CrewMax SR5
    Ran BORA spacers on my old Tacoma for years. Did a fair amount of wheeling with it to. Never had an issue, just checked the torque every time the wheels were off. I’m planning on putting 1-1.5” on the tundra at some point. I’ve got replica pro wheels and I’d like them to be more flush with the fenders.
  30. May 9, 2019 at 5:48 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think you're asking me? I'd like to fit 285/75/17. I found one guy on the Gram that fit these on his AC but he used spacers all around. He didn't have to do any trimming with the spacers. If I go with a 17" wheel I'll get the SCS Stealth 6. If I decide to stick with 285/75/16 then I'd go with the Stealth 6 again but BS would reduce from 4.3 to 3.5" which may help.
