Spacer lift or No?
Discussion in 'Suspension' started by tmoore, Nov 13, 2019.
  1. Nov 13, 2019 at 5:11 PM
    tmoore
    tmoore [OP] New Member
    2016 Platinum CM
    I'm new here. I'm sure this subject might have been debated too much. I want to get the toytec 3/1 spacer kit. thoughts and opinions please. Thanks in advance
  2. Nov 13, 2019 at 5:13 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Depends on what you want to do with your truck. Pavement princess you'll be fine. Minor off roading you'll be fine but it'll be rough. If off road a lot youll want a suspension lift.
    StrmTroop29, nvrgvup444, Sas and 2 others like this.
  3. Nov 13, 2019 at 5:15 PM
    Several options available. I have a 3/2 and will be pulling it out soon and replacing it.
  4. Nov 13, 2019 at 5:18 PM
    tmoore
    2016 Platinum CM
    yea I'm not going to be off-roading. maybe the occasional muddy field going to check on my game camera. I know for sure, I'll be saving for the toytec boss kit
  5. Nov 13, 2019 at 5:22 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Save up for Toytec goodies. Forget about the toilet spacer puck. I'm in the process of spiffing up my 14. Patience is a virtue.....
    AZBoatHauler, jewsNbrews and saybng like this.
  6. Nov 13, 2019 at 5:33 PM
    tmoore
    2016 Platinum CM
    Pros and cons of the spacer kit?
  7. Nov 13, 2019 at 5:34 PM
    Aurora CO
    Preload coils......f**ks up ride....good for mall crawlers
    nvrgvup444 and jewsNbrews like this.
  8. Nov 13, 2019 at 5:36 PM
    tmoore
    2016 Platinum CM
    So the spacers will mess the truck up?
  9. Nov 13, 2019 at 5:37 PM
    Aurora CO
    No...I just despise spacer lift. "Looks good". Search function is your friend...
    jewsNbrews and Pinay like this.
  10. Nov 13, 2019 at 5:44 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Plain and simple it's a 5/10ths solution. As mentioned>>>>be patient and save your money to do it right.
  11. Nov 13, 2019 at 5:47 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    As said before, identify your use of the truck. Pavement princess you’ll be fine. Off-roading and not being careful, parts will likely break.
  12. Nov 13, 2019 at 5:48 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    Tundra234, jewsNbrews and Black Wolf like this.
  13. Nov 13, 2019 at 5:49 PM
    Aurora CO
    ^^^^^this^^^^^
    Pinay likes this.
  14. Nov 13, 2019 at 5:57 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Everyone's needs are different. Doesnt sound like you need a suspension lift, blocks/spacers will be fine. But as others have said, if you go to hard with it, stuff is apt to break.
    But...better to have and not need then it is to need and not have. Buy once cry once.
  15. Nov 13, 2019 at 5:58 PM
    tmoore
    2016 Platinum CM
    most definitely, more of a pavement princess but I might get the spacer kit just to fit my wheels and tires and then save for the ultimate or boss kit.
  16. Nov 13, 2019 at 5:59 PM
    tmoore
    2016 Platinum CM
    I agree with you there sir. I typically do that with most things I've built.
  17. Nov 13, 2019 at 6:00 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    1000's of spacer lifts have been installed.
    They are like a decent house brand drink - cheap and easy on the wallet
    1000's of suspension lifts have been installed
    They are like a good bourbon - time tested and worth the wait
    Listen to the people in the previous posts as they kinda know what they are talking about.
  18. Nov 13, 2019 at 6:05 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    My Tundra came with a 6” Rough Country spacer lift.
    Gutted out, put in ADS 3.0 bypass coilovers, new Deaver leaf springs and have been on loads of trails and rides smooth on pavement. Hell of a lot of dough, but it gets me off roading without worry and has great ride on Hwy.
  19. Nov 13, 2019 at 6:12 PM
    Aurora CO
    Spacers=upload_2019-11-13_19-7-23.jpg= water
    suspension lift= https://www.somethingbrewery.com/
    Pinay and nvrgvup444[QUOTED] like this.
  20. Nov 13, 2019 at 6:38 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Some people complain when a truck actually rides like a truck lol truth is that spacer lifts will show their true colors not only when you off-road but anytime you run over something unexpectedly or actually use your truck.
  21. Nov 13, 2019 at 7:19 PM
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    i have 3/1 pro-comp spacer lift and no change in ride .No preload of coils,spacer mounts on top of strut
  22. Nov 13, 2019 at 7:23 PM
    Aurora CO
    Spacer on top is better. The best way to do a spacer lift. Geometry still not the greatest. Diff drop?
    viha22[QUOTED] likes this.
  23. Nov 13, 2019 at 7:31 PM
    viha22
    viha22 MAGA
    WA
    Yes on a diff drop
  24. Nov 13, 2019 at 7:33 PM
    Aurora CO
    :thumbsup:
  25. Nov 13, 2019 at 7:59 PM
    tmoore
    2016 Platinum CM
    can I mount mine on top as well if I get the toytec kit? sorry for my lack of knowledge
  26. Nov 13, 2019 at 8:02 PM
    Mine rides stiff as a hay wagon on bumps and potholes. I cant wait until my kit come off.
  27. Nov 14, 2019 at 6:31 PM
    Spoolnms
    Spoolnms New Member
    Ryan
    2014 Tundra
    7" lift, 37x13.50r18, catback dual exhaust, intake, etc.
    I had the 6" RC spacer lift on my truck, and it changed the ride a little bit, but nothing dramatic (remember its a lifted truck!). Ive replaced the blocks up front and put the RC lifted struts and now the truck rides like stock, as well as gained another 1" of lift (settled).
