Southern Maryland sandblast and undercoat locations?
Discussion in 'North East U.S.' started by Resnov1913, Mar 27, 2021.
  1. Mar 27, 2021 at 2:59 PM
    Resnov1913
    Resnov1913 [OP] New Member
    Southern Maryland
    2021 4x4 Tundra (mine) , 2023 TRD Offroad 4Runner, 2018 TRD Offroad (spouse)
    Sorry if has been asked before, however I did not have luck finding it if it does. I live in southern Maryland and the service manager at our dealership mentioned getting the rust cleaned off the frame and coated before the rust becomes a problem.
    They do not do that at the dealership, anyone do this and have suggestions?
  2. Dec 28, 2021 at 9:09 AM
    Fallingblock
    Fallingblock New Member
    Southern MD
    2017 SR5 DC Tundra
    Did you ever find a location for this? I am interested as well for future reference.
  3. Dec 28, 2021 at 9:15 AM
    Resnov1913
    Southern Maryland
    We did, though going to have to look through our truck receipts to see where. I'll get back with you
  4. Dec 28, 2021 at 9:18 AM
    Fallingblock
    Southern MD
    2017 SR5 DC Tundra
    Much appreciated
  5. Dec 28, 2021 at 1:25 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    removing the rust and painting under there is a fine idea. Undercoating the truck is not. That is if the undercoat is anything other than paint, that rubberized undercoating will cause more problems than it is worth. Moisture will get trapped under it, in nooks and crannies, rusting from inside out before you notice it.
    So, remove the rust, spot prime and use some flat black paint as needed. If you need rust protection after that has been done, look into fluid film or a similar coating. They work great and won't cause the issues a typical undercoating will.
