Sourcing stock exhaust for 2012 DC
Discussion in 'Performance and Tuning' started by shakey_jake, Jun 2, 2021.
  1. Jun 2, 2021 at 5:42 PM
    shakey_jake
    shakey_jake [OP] New Member
    Jake
    Virginia Beach
    2012 Tundra 5.7 TRD 4x4
    6" lift. 35s on 20s
    Anyone know what other years and models stock exhaust will be a direct fit to my 2012 5.7 4x4 DC?
  2. Jun 2, 2021 at 8:19 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007-2013 DCs will all be the same.
    2014 -up DCs should work but I would check part numbers.
  3. Jun 2, 2021 at 8:45 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    If I remember correctly, the 07-09 model is little different than the 10-13 model. The driver side pipe that bolts to cat on 07-09 is slightly longer than 10-13. But otherwise the same. A muffler shop could modify it to fit.
    Hbjeff likes this.
  4. Jun 2, 2021 at 9:04 PM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    dirty deeds deeds has a system for 07-09 and then 2010+... so that plus the length of the truck should determine which exhausts fit
  5. Jun 2, 2021 at 9:10 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    This is from one of the most popular aftermarket options, which in my mind should mean that all the stock systems after 2010 should bolt up to one another. So as long as you don't find a 07-09 you can source from either a crewmax, a double cab 6.5ft bed, or a single cab with the 8ft bed.
    dirtydeeds and shakey_jake[OP] like this.
  6. Jun 3, 2021 at 5:28 AM
    shakey_jake
    Jake
    Virginia Beach
    6" lift. 35s on 20s
    great info guys. Found a 2018 CM take off for free on the local FB forums.
    APalmTree likes this.
  7. Jun 3, 2021 at 7:11 AM
    APalmTree
    Brandon
    SW Washington
    Hard to beat free!
