Sound from front end
Discussion in '2nd Gen Tundras (2007-2013)' started by Jbrose4x4, Dec 12, 2019.
  1. Dec 12, 2019 at 7:00 PM
    Jbrose4x4
    Jbrose4x4 [OP] New Member
    2011 Toyota Tundra RW
    Hi i am new to this page, i have a 2011 Toyota Tundra RW. About a year ago I had to use 4x4 to get out of a muddy yard and since then the drivers side front end has felt funny. It has been slowly getting worse, I have checked the wheel bearing for play and everything is tight. At about 20 to 30 mph when I first drive it in the morning I get a womp womp womp sound along with a vibration feeling in the steering wheel that goes along with the womp womp sound, it defininetly seems to be changed by the speed of the vehicle. After driving for a bit it still has the same sound but not as bad. About a week ago I was stopped at a traffic light with a turn to the left and when the light turned green and i started to go there was a big pop from the front end that I could feel as well as feel in the steering wheel. Any help I can get is much appreciated, my wife and i are about to make a trip up north in less than a month and want to make sure the truck isnt going to break down on us. Thank you
  2. Dec 14, 2019 at 9:37 AM
    Jbrose4x4
    Can anyone help
  3. Dec 14, 2019 at 9:44 AM
    bryand
    bryand New Member
    Alabama
    2010 4.6L 2wd DC Black
    Bilstein 5100
    Did you check the ball joints when you checked the wheel bearing? I was having some similar issues (though not as loud), my upper ball joints were shot. I changed the arms last weekend and it's improved a lot though I need to look at the rest of the front end.
  4. Dec 14, 2019 at 10:56 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Cv axle failing?
    NWExplorer likes this.
  5. Dec 14, 2019 at 11:34 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Sounds like a CV
  6. Dec 14, 2019 at 12:16 PM
    ajax1
    ajax1 New Member
    2012 black trd limited modded up
    Tires, suspension, bumpers, soft topper
    Cv axle or ball joint , being that you heard loud pop when turning that would be my guess
    ZappBrannigan likes this.
  7. Dec 14, 2019 at 10:51 PM
    Jbrose4x4
    Thank you guys for the responses! Is there anyway to check the axles? I checked the seals and they looked good, but is there any other check to do on them?
  8. Dec 14, 2019 at 11:05 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Jack up the car and yank on the axle. There shouldn’t be any play.
  9. Dec 15, 2019 at 12:20 PM
    Jbrose4x4
    One side at a time or would both sides at once be better?
  10. Dec 15, 2019 at 1:43 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    One at a time is just fine
  11. Dec 15, 2019 at 3:03 PM
    Jbrose4x4
    Thank you guys for all the help, I will make sure to check that tomarrow morning and post my findings.
    Luckydog likes this.
  12. Feb 5, 2020 at 6:11 AM
    Jbrose4x4
    Just an update, so i took the truck to toyota and they said I had a bad wheel bearing so i had them replace them both and nothing has really changed. They said the balljoints were fine and the cv axles were good. Any possiblilty it could be the front diff?
