Solved - FGT Dome Light Bulb DE3425
Discussion in '1st Gen Tundras (2000-2006)' started by bfunke, Dec 20, 2025.
  1. Dec 20, 2025 at 8:16 AM
    bfunke
    bfunke [OP] Tundra Curmudgeon
    South Carolina
    Dome light quit. It’s been somewhat intermittent for a while. Turns out the glue failed and the soldered wire came out. The OEM bulb is a 36mm festoon bulb 7W Toshiba. All the sites list DE3175 which is a 30 or 31mm 10W festoon bulb as the direct replacement. I can’t seem to find the same as OEM anywhere locally. The shorter bulb fits if you’re carefully to center it. Anyone know of a source for the correct 36 mm bulb?
  2. Dec 20, 2025 at 8:49 AM
    1lowlife
    1lowlife Toxic prick and pavement princess
    DADA
    THE GREAT STATE OF TEXAS
    On my 3rd Tundra 2005 DC 2014 DC 2026 CM Limited
  3. Dec 20, 2025 at 10:14 AM
    bfunke
    South Carolina
    I’ll check it out
  4. Dec 20, 2025 at 11:20 AM
    Upshot Knothole
    Upshot Knothole This space for rent.
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
  5. Dec 20, 2025 at 8:23 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
  6. Dec 21, 2025 at 9:44 AM
    bfunke
    South Carolina
    DE3425 is the correct size and light output. Thanks @1lowlife
    1lowlife likes this.
