So what suspension are you running
Discussion in 'Suspension' started by frogger, Jul 19, 2016.
  1. Jul 19, 2016 at 10:28 PM
    frogger
    frogger [OP] just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    I've been wanting to lift my 08 mild though like 2-3 in. Any advise on good kits? Brands? Etc..
  2. Jul 19, 2016 at 10:42 PM
    All about $$$ and where you plan on taking your Tundra. I have the Old Man Emu coil overs/rear shocks that I got from ToyTec. More than good enough for my use and within my budget. Some folks use spacers to get a mild lift. Fine if you don't off road a lot or ever. There are so many brands. You will get a lot of responses here. I recommend calling ToyTec. They are locted here in CO. Experts on Toyota suspensions for all budgets. Give them a call, tell them your budget, what you are looking for as lift. They won't sell you something you don't need. They will recommend what you want for your use. Here is their info:
    T-Rex266 and bandit like this.
  3. Jul 19, 2016 at 10:49 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    Fox 2.5 coilovers w/ remote resi's and fox 2.5 triple bypasses up front with the Mazzulla Long travel kit. It only lifted my truck about 3 inches technically....
    frogger[OP] and T-Rex266 like this.
  4. Jul 19, 2016 at 11:06 PM
    Yeah, that's a mild 3" setup. You're one of guys here that's doing some serious Sh*t with your Tundra suspension. I can't imagine how good the ride is. You can actually haul some serious ass at a fast clip without breaking something. (I guess if you get too much air something can always break. heh heh) I can't wait to see when you are done. Off road mag cover shots for sure.
    Ardnut and bandit[QUOTED] like this.
  5. Jul 19, 2016 at 11:15 PM
    bandit
    bandit New Member
    Duh Tundra
    Its a conservative 3 inch lift ;)
    The ride is absolutely incredible. Hands down, i've never rode in anything as smooth as this in any facet.
    I'm certain I'll break something very soon! haha
    OOOOH there's a goal! That would be pretty cool for the truck to be on the cover of a magazine! #lifegoals
  6. Jul 19, 2016 at 11:26 PM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Kings all the way around!
    T-Rex266 likes this.
  7. Jul 19, 2016 at 11:26 PM
    A good example is my OME's. This past weekend I was able to reasonably go at a fairly good clip trying to keep up with this FJ that I stupidly let go ahead of me on the Kingston Peak JP trail. Stupidly because I instantly had to eat his dust. I was able to keep up until I hit a 2' bump (for lack of better words) that I didn't see because of the dust and my front end got a little air. Not much air, but enough to slam down pretty hard. I stopped and took a look and all was good. Nothing bent or broken. The OME's aren't built for a lot of that kind of shit. I know my limits. I slowed a little after that incident :cookiemonster:. I may upgrade again at some point in a few years. All about $$$
    That being said, the OME's are apparently pretty tough. I don't plan on doing the the air born thing again. At least not on purpose. The ride was great though. Way different than OEM KYB's/TRD 4600's. The new Bilstein C/O setup looks to be real good too. Either setups are worth the money unless you want to go full monty and go for Fox's or King rebuildables which can add up $$ quickly.
    Ancient1 and bandit like this.
  8. Jul 20, 2016 at 5:42 AM
    frogger
    Stephen
    Louisville Ky
    too much to list
    Those bad boy's cost a lil jack
  9. Jul 20, 2016 at 5:48 AM
    frogger
    Stephen
    Louisville Ky
    too much to list
    The last good place we had for trails shut down due to neighbors on the damn street (that is in the middle of nowhere) complaining because of "mud on the street on the weekends", from guys leaving was a place called "Dirty Turtle". I just normally go off in the woods now a days on my dad's land
  10. Jul 20, 2016 at 5:53 AM
    I just purchased the Bilstein 6112 front shock/spring kit and the rear 5160 Bilstein shocks. Look into that.
    frogger[OP] likes this.
  11. Jul 20, 2016 at 6:01 AM
    frogger
    Stephen
    Louisville Ky
    too much to list
    Thanks I will look into that. Are you happy with the set up? How many inch lift?
  12. Jul 20, 2016 at 6:45 AM
    Not sure yet if I like it yet. Should be here next Monday.
    Everything I have read and talked to people said it it a 100% improvement.
    Lift is up to 2.5
