Snapped a ball joint.
Discussion in '1st Gen Tundras (2000-2006)' started by Seina_Yamada, Jan 20, 2020.
  1. Jan 20, 2020 at 12:55 AM
    Seina_Yamada
    Seina_Yamada [OP] New Member
    2003 Toyoda Tundra SR5
    Here's an O sh** moment. Good news it happened when I was moving 2-3 mph vs 65-75.20200118_002207.jpg
  2. Jan 20, 2020 at 2:11 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    How old? how many miles? oem?
    KarmaKannon likes this.
  3. Jan 20, 2020 at 4:07 AM
    slixx1320
    slixx1320 New Member
    So. Ca
    This reminds me I need to put it on my "to do list".
    Glad nothing happened to you!
  4. Jan 20, 2020 at 4:11 AM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    Wow that’s nuts.. luckily you’re okay. Can you share any potential symptoms you felt in the ride leading up or was it unnoticeable?
  5. Jan 20, 2020 at 4:19 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Given you got that ride from Colorado and now in Alaska weather, I'd sure be under it checking what else is about to fall off !
  6. Jan 20, 2020 at 5:12 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Was it ever updated for the recall?
    All 3rd gen 4Runners, 2nd gen Tacomas, T-100s and 1st Gen Tundras had the recall for LBJs. ONLY use OEM parts, NAPA and other stuff fails in a few thousand miles and yeah having this happen going 50+ on highway could be deadly.
  7. Jan 20, 2020 at 5:13 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Without a close-up, it's hard to see any failure. The ball joint appears intact with a portion? of the mounting stud protruding. I can't tell if the nut has simply unscrewed due to missing cotter pin, or the stud has broken.
    If the stud broke at a thread, it's a fatigue failure. Probably started out as inadequate torque of the nut. If the stud has fracture plane(s), then it simply wasn't strong enough, which is hard to believe.
  8. Jan 20, 2020 at 5:52 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Other members have reported that these give little to no warning before they go. That's why many advise replacing them if you have a ton of miles on them.
    MrAristo[QUOTED] likes this.
  9. Jan 20, 2020 at 5:55 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I don’t see that my ‘06 had the recall done per the Toyota website nor is there any open recalls pertaining to anything outside the passenger airbag (for the 2nd time).
    Are we sure all first gen Tundra’s have a recall?
  10. Jan 20, 2020 at 6:28 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Dealer is always best choice, but I wasn't afraid to try Beck Arnley found on Rock Auto....on sale now for $30. I installed mine back in 4/17 and approximately 15k on them and our roads suck here, so much abuse. 2003 is it's own part # I noticed. Good luck on the small bolts, fire is always the best way. Oxy/Acetylene
  11. Jan 20, 2020 at 6:31 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    In general, some perhaps all 1st Gen's have had some form of recall that may or may not apply. In your particular case, there have been 12 recalls against 2006 Tundras according to the NHTSA. At the below NHSTA link are the 12 recalls for 2006 located toward the bottom of that page. One would have to check out each one to determine if it applies to theirs.
    https://www.nhtsa.gov/vehicle/2006/TOYOTA/TUNDRA/EXTENDED%2520CAB/RWD%252FAWD#recalls
    Take for instance the LBJ Safety Recall it appears you are mentioning, the below LBJ pdf, shows which VIN numbers are affected.
    abcinv[QUOTED] likes this.
  12. Jan 20, 2020 at 6:35 AM
    Professional Hand Model
    Hand Protectors
    A common (good) theme I read about when these LBJ’s fail is that the speeds at failure are in the 2-3mph range.
    MrAristo and Darkness like this.
  13. Jan 20, 2020 at 7:44 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    That's why it never happens to black Tundras, black Tundras skip that speed range.
    :militarypress:
  14. Jan 20, 2020 at 11:31 AM
    Seina_Yamada
    I'm gonna pull and replace today at that time I'll do an autopsy and provide better pictures. At least its warm today around 15-20 degrees =)
  15. Jan 20, 2020 at 12:30 PM
    Aerindel
    Aerindel New Member
    Montana
    Nice!
    If you don't break stuff your not driving to your full potential.
    bmf4069 likes this.
  16. Jan 20, 2020 at 2:57 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    you don't know?
    revtune and BlackSheep like this.
  17. Jan 20, 2020 at 10:11 PM
    Seina_Yamada
    It doesn't look oem, but I'm not sure. I got the tires changed in October, and there was no issue. I'm replacing with a duralast kit till this spring/summer I have a left and right set coming from Toyota now.
    Toyokuhl[QUOTED] likes this.
  18. Jan 21, 2020 at 3:44 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    If it doesn’t look or indeed isn’t OEM then you could possibly have an entire different problem altogether; previous owner installation. I’d be weary not replacing the other side if they look the same.
  19. Jan 21, 2020 at 5:28 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Colorado isn’t hard in vehicles at all. The only rust you’ll see is from someone moving here from a rust state.
    speedtre likes this.
