Smart thermostats
Discussion in 'Off-Topic Discussion' started by 2010bigdog, Feb 3, 2019.
  1. Feb 3, 2019 at 8:29 AM
    2010bigdog
    2010bigdog [OP] New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    So I have a ECOBEE smart thermostat and I have noticed when it feels a little cold in the house I go to the thermostat and it says it set at 70 and it says its 70 so when I turn it up to 71 it kicks on and when I look at the actual temperature it says its like 2 to 3 degrees colder and it runs for a little bit til it hits the 71 degrees. Has anyone had this problem ?Looking to maybe switch to the NEST smart thermostat
  2. Feb 3, 2019 at 8:54 AM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    Have you looked into Honeywell Lyric thermostats? The dirty secret about nest is they come with a "lifetime" battery that lasts around 5 years. At that time you get to pick out another one. It could be the air circulating around the stat when you kick on the heat that causes the fluctuations. Did you seal the hole up behind the stat where the thermostat wire is? You will get mis-readings from the air coming through there as well.
  3. Feb 3, 2019 at 8:56 AM
    TheBeast The Beach
    I love my NEST !.. Costco runs sales on them from time to time.
  4. Feb 3, 2019 at 8:57 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Do you have the separate sensors that adjust temp for specific rooms?
  5. Feb 3, 2019 at 9:09 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I'm not an HVAC expert but I'm pretty sure all thermostats are going to have a 2-3 degree zone where it'll float the temp, that way you're not kicking on and off constantly. That said, I have two Nest thermostats, a second gen and a third gen, and had an issue where the second gen wall plate was heating up and throwing off the temp readings by about 7 degrees. That was a fun one. Nest support was quick to send me a new wallplate, though, and that fixed the issue.
    15whtrd likes this.
  6. Feb 3, 2019 at 9:14 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Have noticed this with regular tstat. I believe it is due to tstat placement/locatotion and air movement. The air is 70/70 at tstat, set point increased, air movement circulates and moves cooler air around tstat, then measures lower temps.
    Placement is key, builders install in places not always ideal.
  7. Feb 3, 2019 at 9:21 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I have separate sensors but did not link them yet
  8. Feb 3, 2019 at 9:25 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I did seal the wall behind it. the thing I don't get is it says 70 on the thermostat and it also says 70 actual temp but when I raise it 1 degree and the furnace starts running for about a minute and you check the actual temp it will say a few degrees lower. I know the smart thermostats will run a degree or two higher for example if I set it to 68 it might run til 69 or 70 then kick off so its not cycling so much but this seems like its stuck or frozen sometimes
