Smart relay for Access Cab/Regular Cab trucks with DRL?
Discussion in '1st Gen Tundras (2000-2006)' started by shifty`, Sep 8, 2020.
  1. Sep 8, 2020 at 11:48 AM
    shifty` [OP] Our private little trip to hell
    While searching on my '06 Tundra at Diode Dynamic's site, it clearly says their CF18 isn't for Access Cab/Regular Cab trucks with DRLs. That would rule out at least my '06 and the '05 also I guess, both have DRLs, eh? I see their site saying the 01-18 Highlander, which had DRL through many years, is supported, so are Double Cab trucks. Maybe Tundra 05/06 uses a different pinout with DRL trucks or something?
    I want this product mostly for the smart-tap signal option, not for the hyperflash protection. Their FAQ suggestion of buying resistors to overcome hyperflash isn't helpful to achieve my goal. I'll probably call them shortly just to ask directly but had some other stuff to handle and thought I'd ask here first.
  2. Sep 8, 2020 at 2:10 PM
    Ok, got on the phone w/DD. Long story short: They say the pinout on the [AC/RC] trucks with DRL is supposedly different, thus their standard DD CF18 flasher won't work. They don't make a product with the correct pinout for the AC trucks with DRL, or so they say,
    I vaguely remember reading somewhere the trucks with DRLs have something like an 18-pin (or 16-pin) relay and non-DRL have a 6-pin (or 8-pin) relay, I'm bad with numbers so I might have the 8- and 6- swapped.
    There was also mention at other forums Toyota may have an adapter to convert from the higher-pin to lower-pin so you can use the DD product. However, I'll probably need to scour here, TS, TundraGeeks, and a couple other places to see if anyone else has done it, I guess.
    Oh well!
  3. Mar 21, 2021 at 7:39 PM
    912 @best_gen_tundra
    SWFL
    Reviving from the dead here...what did you end up discovering @shifty` ?
  4. Mar 22, 2021 at 5:41 AM
    No solution available to get a smart relay for [AC/RC] trucks with DRL as of January that I could find. DD guy mentioned they have no intent on creating such a product. To my knowledge, there's no solution for us folks with DRL, DD says the flasher socket is different # of pins, different footprint for DRL 1st gen trucks.
    Hopefully a solution comes one of these days ...
    912[QUOTED] likes this.
  5. Mar 22, 2021 at 10:27 AM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    912 likes this.
  6. Mar 22, 2021 at 10:30 AM
    They specifically told me this wouldn't work, the relay under the fuse box in DRL access cab/single cab trucks doesn't have the same multi-pin connector.
    I confirmed, my truck's connector doesn't seem to match the pinout and pattern of the CF18 product DD is selling, mine may have several extra pins, assuming I looked at the correct thing.
    Not sure what's up with your truck that makes it different from mine, unless you have a double cab instead of a single cab/access cab (which looks like is the case under your avatar)
    912 and Cummins3500[QUOTED] like this.
  7. Mar 22, 2021 at 10:31 AM
    Cummins3500
    Logan
    My bad I missed the access cab part. Mine is in fact a double cab. Disregard my above post. Thought I could help y’all out :bananadead:
  8. Mar 22, 2021 at 10:33 AM
    No worries. I got excited for a sec. Thought there may be a solution here :D
    Sucks this is different across two different body types of the same truck. But I guess that's the case with lots of stuff on the 1st gens ....
  9. Mar 22, 2021 at 12:12 PM
    SWFL
  10. Mar 22, 2021 at 12:14 PM
    SWFL
    Bummer about the AC trucks. I have seen a few posts in other forums about an adapter harness and slight change to the pinout that allowed it to work on some 4th gen 4runners, GX470, and maybe GX460 as well. I wonder if that might work for your AC?
  11. Mar 22, 2021 at 1:11 PM
    Cummins3500
    Logan
    @912 it’s that easy, hardest part is getting the oem relay unplugged lol
    @shifty` It’s blows my mind how much variance these trucks have. And the sequoias different from the double cabs even more
    shifty`[OP] and 912 like this.
  12. Mar 22, 2021 at 1:30 PM
    I mean, I'm open to any non-fire-hazard plug'n'play solution on the market. Personally, I don't want to dig through pinout diagrams and cobble something together without getting an electrical engineer involved. There's a reason those EE make the big $$ and companies charge a premium for products (usually)
    Easy way to tell: Find the flasher relay next to your fuse box/left of e-Brake pedal. Pull it. Does it look like this, with this footprint/pinout? If yes, you're golden. Order up!
  13. Mar 23, 2021 at 11:13 AM
    SWFL
    Looks like it should work! This is the flasher I currently have in my first gen:
    shifty`[QUOTED][OP] likes this.
  14. Jul 28, 2021 at 9:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    what style plug does the DRL use? the 4th gen 4runners had the DRL and non DRL flasher setup. but the difference was the non DRL uses a jumper harness to adapt the flasher to the DRL style plug. this harness may be usable for disabled DRL 1st gens.
    tvpierce likes this.
  15. Jul 28, 2021 at 9:45 PM
    empty_lord
    05 rollover special
  16. Jul 30, 2021 at 1:33 PM
    SWFL
    My 05 double cab with DRL has the CF18 plug and the above SmartTep relay has been working great.
    Thanks for posting that relay adapter, I'm going to get one and try to on my wife's GX460! :cheers:
    empty_lord[QUOTED] likes this.
  17. Aug 25, 2021 at 11:22 AM
    When you say you have DRL, do you mean your headlight housings have the small teardrop-shaped DRL bulbs in the corner, like this? Or do you just mean your headlights have a DR: function where the low-beam turned on any time the truck was running, at like half-power? Curious to know.
    Would it help if I went under the dash and took a picture of the connector? If this adapter works for my truck, this would be so f'n awesome. The only two things I'm constantly thinking, "man, I wish my truck had this" are a convenience flash and being able to tap down on the windshield wiper stalk once to wipe the window.
    Curious, did you ever get a chance to test that adapter out on the GX460? If it didn't work, and you want to get rid of it, I'll kick you some bucks to ship it one state north.
  18. Aug 27, 2021 at 5:53 AM
    SWFL
    Hey man, I have both. I have the little corner parking lights inside the housings and I also have the DRL which turns on the main headlights at reduced power anytime the truck is running. I've disabled the DRL by unplugging the grey connector next to the battery FWIW.
    If you pull your flasher relay and take a pic of the top and the pins I can compare it to mine and the 460s. If it's the same size and shape as the DD smart tap, I bet it will work.
    I have the adapter here but haven't looked to put it in the GX yet. Been too busy with work. I'll definitely post up when I get it done tho! And of course if it doesn't work, I'll send it to you.
  19. Sep 1, 2021 at 3:08 PM
    I'm both damn glad you asked me to check and kicking my own ass right now for not looking sooner.
    Sure enough, Diode Dynamics is full of it. I definitely have DRLs, and I definitely have a 2006. I also definitely don't have the 15-pin or whatever they said my truck would.
    And just in time for a holiday weekend. Wonder if they'll be having any deals?
  20. Sep 1, 2021 at 3:15 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    When you refer to DRL are you referring to the small lights in the corner of the headlamps (teardrop ones) or the actual H4 headlamp bulbs lighting up at a 'low' brightness level (truck on, lights off)?
  21. Sep 1, 2021 at 3:18 PM
    The little corner lamps are on all the time. I assumed that was the DRL. I'm actually not sure if the main headlight is on at low brightness during the day.
  22. Sep 1, 2021 at 3:37 PM
    SWFL
    Looking at that relay, it’s the same as mine. I think when DD refer to ‘DRL’ they’re thinking of the amber running lights in 2nd Gen Tundra and 2nd Gen Tacoma which act as switchbacks from the factory. No FGTs had anything like that if I recall correctly. Anyway, I’m 99% sure the DD smart tap will work for you like it did for me.
  23. Sep 1, 2021 at 3:49 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    The corner ones are not DRL. It's a system that uses the headlamps at reduced output.
    From the owners manual:
    912 and shifty`[QUOTED][OP] like this.
  24. Sep 1, 2021 at 3:57 PM
    empty_lord
    05 rollover special
    Small corner lights in the headlights are the park lights
    shifty`[OP] likes this.
  25. Sep 1, 2021 at 5:22 PM
    Aaaaaaagghhhh! I just fell victim to the RTFM!!!
    assassin10000[QUOTED] likes this.
  26. Sep 1, 2021 at 5:23 PM
    Worst part is they jacked up the price almost 35%. Damn things are 80 now instead of 60. If they wouldn't have misinformed me at the start of this, I could've saved 20 bucks!!
    912 likes this.
  27. Sep 1, 2021 at 5:48 PM
    912
    SWFL
    I tagged them on IG when I installed the relay and someone wrote me a DM and thanked me for the shout out. Seems like a down to earth smaller company. Could always call them and ask for the $60 price and inform them of their mix-up.
  28. Sep 7, 2021 at 6:49 AM
    Turns out through the 10th of this week, they're offering 15% off with code LABOR.
    That gets it close enough to $60, despite these being on backorder, so I went ahead and pulled the trigger. Still cost me almost $80 bucks after ship, but I'm good w/it.
  29. Sep 8, 2021 at 6:59 AM
    912
    SWFL
    Be sure to post up some pics or vids when you get it. Pretty convenient piece of kit IMO!
  30. Sep 8, 2021 at 8:07 AM
    Cummins3500
    Logan
    Cool to see this mystery solved. I ended up ordering another from Amazon before the price increase. Diode dynamics was showing it out of stock on their website but the thing dropped shipped directly from them lol
    912 and shifty`[OP] like this.
