Smallest lift to run 35x12.5R18?
Discussion in 'Suspension' started by 2010toytundra, Sep 18, 2020.
  1. Sep 18, 2020 at 7:52 AM
    2010toytundra
    2010toytundra [OP] New Member
    Icon stage 1 Lift
    I already bought 35x12.5R18. What is the smallest lift I can use without rubbing?
    Prostar 190 and YardBird like this.
  2. Sep 18, 2020 at 7:59 AM
    Bob and Sean492 like this.
  3. Sep 18, 2020 at 8:01 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    3 inches. You need to pay specific attention to wheel offset- search here for more info. You will also probably be removing front, maybe back flaps and massage the fender liner a bit. Could need bumper spacers or BMC depending on wheel offset. All the info and details on doing that can be found by searching the suspension and wheel/tire forums here.
    Bob and Tundra234 like this.
  4. Sep 18, 2020 at 9:46 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
  5. Sep 18, 2020 at 11:13 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Sep 18, 2020 at 11:22 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    6 inches unless you want to start cutting some metal behind the front tires. (BMC) With a 6 inch lift I still had to melt some plastic in front of the tires with a heat gun.
    snowman19 and Prostar 190 like this.
  7. Sep 18, 2020 at 12:40 PM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    Im running 35x12.5x20 Yokohama MTs with only a 3” spacer up front. Like frichco said, its all about offset. Ive got TSS wheels with 1.5” spacers which brings the offset to around +25. Had to remove all mudflaps, heat and mold the fenderwell and i also trimmed and rolled the outside bottom edge of the bumper ends about a 1/4”. It still rubs the BM a little at full lock in reverse but not enough to damage the inside knobs of the tire.4B2E91EB-A84F-4BFA-B2A9-0DFF44C721E9.jpgFA2BF105-0206-4FEB-AF77-7EE4C71F9AD1.jpg
  8. Sep 18, 2020 at 2:58 PM
  9. Sep 18, 2020 at 3:15 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    3/1 with a CMC 35x12.50x20 clear no problem.
    snowman19 and KLLVMDCL like this.
  10. Sep 18, 2020 at 3:21 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
    toyofan87 likes this.
  11. Sep 18, 2020 at 3:40 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  12. Sep 19, 2020 at 11:04 AM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    Super clean. You running spacers right?
  13. Sep 19, 2020 at 11:17 AM
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Yep 1.25 spidertrax
  14. Sep 19, 2020 at 2:32 PM
    Welcome from Ohio
  15. Sep 19, 2020 at 7:45 PM
    jsquared22
    jsquared22 _________________
    2018 White Tundra Platinum
    Another welcome from SoCal.
  16. Sep 22, 2020 at 5:27 PM
    2010toytundra
    Icon stage 1 Lift
    Thanks for the welcomes and the info.
    I am getting Icon springs that should lift the front 2.5 inches which should level out the truck.
    Do you think that will be enough to avoid rubbing with my 35x12.5R18's?
  17. Sep 22, 2020 at 5:33 PM
    hhenry_
    hhenry_ New Member
    Bay Area Ca
    08 tundra crewmax
    I have a 2 in leveling kit up front only and I don’t rub anymore. I have 35x12.50x18 Toyo open country RT. I had to take out the mud flap and move up the black plastic up just a little bit
