Skid Plate Time!!!
Discussion in '1st Gen Tundras (2000-2006)' started by wcooperider3rd, Aug 31, 2020.
  1. Aug 31, 2020 at 10:03 AM
    wcooperider3rd
    wcooperider3rd [OP] New Member
    Wayne
    2005 Tundra Double Cab Sr5 4.7L RWD
    Alrighty, so I was hella frustrated one day, and managed to strip 2 thread holes for the skid plate. Y'all know what imma have to do? Is there a nut plate I can replace? Or am I gonna have to tap and die this hoe? Took two bolts stripping to realize this.
  2. Aug 31, 2020 at 10:06 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    if the hole was stripped then tap and die.
    If the welded nut let go on the other side you might be able to get a nut on there but it would be better to drill the hole a bit and use a nutsert. I did that on one of mine.
    wcooperider3rd[OP] likes this.
  3. Aug 31, 2020 at 3:52 PM
    Professional Hand Model
    Hand Protectors
    I used self tapping roofing screws with the little rubber/metal washer on mine when the OEM holes/Screws went to crap. Zipped them in equidistant new locations. Been about 5-6 years and holding strong. Just be careful you use 3/4” or shorter or you’ll tap a fluid line from the transmission.
  4. Aug 31, 2020 at 3:56 PM
    Hand Protectors
