Skid plate and lift question
Discussion in '2.5 Gen Tundras (2014-2021)' started by madmatt, Jul 15, 2019.
  1. Jul 15, 2019 at 5:16 PM
    madmatt
    madmatt [OP] New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    Ok guys and gals, I want to buy and put on a trd pro skid plate. I’m also going to be doing a lift in the near future. Is there a magic amount of lift that I can do and still keep the trd pro plate, or do I have to remove the plate with any lift at all? I’ve been reading posts about people having to remove their plates because they lifter their truck.
    Also anybody have a pro plate laying around that they want to get rid of? :)
  2. Jul 15, 2019 at 5:56 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I think that it is not so much how high you lift but what kind of lift you go with. If you are doing a suspension lift (coilovers & UCAs) then you should be able to keep the pro skid. If you go with a bracket lift then this replaces the crossmember and then the pro skid may not work.
    joonbug likes this.
  3. Jul 15, 2019 at 6:00 PM
    TylerDurden311
    TylerDurden311 Paper Street
    2018 Tundra CM
    nlaroy likes this.
  4. Jul 15, 2019 at 7:07 PM
    madmatt
    Ocala Florida
    Thanks is for the replies!
  5. Jul 15, 2019 at 7:10 PM
    TheBeast The Beach
    the trd pro plate is so so. You should look into a more solid one from an aftermarket company imo.
    Black Wolf and Pinay like this.
  6. Jul 15, 2019 at 9:40 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    If you do a diff drop it won’t fit unless you do a spacer kit
  7. Jul 15, 2019 at 10:26 PM
    rallypanam
    rallypanam New Member
    2019 Doublecab Limited 4x4
    No issues with TRD skid plate with my icon stage 9.
  8. Jul 16, 2019 at 12:08 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    TRD Pro plate is a pain in the ass...don’t waste the money.
    Black Wolf likes this.
  9. Jul 16, 2019 at 9:40 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I did a 3"/2" lift with a 1" front axle drop. I did have to make custom 1" aluminum spacers for the TRD skid plate to get it to fit properly. but when you look at it you cant even tell they are there. You will need a couple of longer bolts also.
  10. Jul 16, 2019 at 12:11 PM
    rallypanam
    Kind of agree, I would not have ordered my truck with one... but it was in the lot with it, so it works for now. I may upgrade at some point, we’ll see.
  11. Jul 16, 2019 at 12:50 PM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    I'm curious to here why you think it's a PITA?
  12. Jul 16, 2019 at 6:06 PM
    Crunch527
    Iowa
    Mounting hardware and design. The TRD skid is designed to touch the frame, with no gasket material...never a good idea...even with the proper hardware and install procedure, the damn thing still made a bunch of racket. I had to get rubber material to go between the frame and the skid plate...there is a thread on this.
    Also, if it ever has to come off, the hardware is critical...and if the tech at the dealer or who ever is working on it (Indy shops wont know the specific hardware mounting details) doesn’t reinstall all the hardware, it will make noise. I had to go and make new aluminum spacers because the dealer tech didn’t reinstall all the hardware...of course it was too late to go back once I figured it out, not to mention it took me removing the plate to figure it out. Toyota wants $90 for the hardware...WTF?
    So there you go...save your $350+ bucks...and for oil changes, add a door to your stock plate (there is a thread on this too) and be done.
    Oh, if I hadn’t thrown my stock one out I’d swap them and sell the TRD skid.
  13. Jul 17, 2019 at 8:53 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    I already have the RCI skid (haven't had time to installed it yet) so I was just curious to know what was so bad about the TRD Pro skid plate? Thanks for the info.
  14. Jul 17, 2019 at 6:37 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    What is the TRD skid plate made out of steel or aluminum? I know RCI has a steel one and alumunim one just can't decide which one to get? Also does the RCI come with mounting hardware?
  15. Jul 18, 2019 at 7:09 AM
    TylerDurden311
    2018 Tundra CM
    Yea the RCI comes with hardware and there should be a selection for a spacer kit if you have a differential drop.
  16. Jul 18, 2019 at 7:16 AM
    TXTundra2722
    2015 Black Tundra
    The aluminum from RCI is thicker than stock. If your going to bash your truck and actually drag it over rocks then you want to go steel. Aluminum is for general purpose off roading
  17. Jul 18, 2019 at 7:19 AM
    TylerDurden311
    2018 Tundra CM
    I went with the steel...It was cheaper and figured it would take more of a beating then the Aluminum.
  18. Jul 18, 2019 at 7:54 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    pull steel gas tank engine trans an A frame
  19. Jul 18, 2019 at 12:37 PM
    airgunner
    N-KY
    2015 DC MGM TRD
    I was going to get the steel version because it was cheaper and I figured it would withstand more abuse. If I lived out west that's what I would have done but I'm in the rust belt and I don't do any kind of hardcore off roading so I went with the aluminum version for the weight savings and rust resistance.
    TXTundra2722[QUOTED] likes this.
  20. Jul 19, 2019 at 3:29 PM
    Crunch527
    Iowa
    You made the right decision!
  21. Jul 19, 2019 at 4:39 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    So do the normal spacers that come with the diff drop work on the trd skid plate
  22. Jul 19, 2019 at 4:45 PM
    TylerDurden311
    2018 Tundra CM
    The differential drop spacers are for the front diff. You would need separate spacers to lower the skid because the differential is lower.
    Tundyfundy likes this.
  23. Jul 19, 2019 at 4:48 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    No mine came with 3 other spacers to use on the screws that attach the stock skid to make room for the drop. Was going to put it on my Pro now that my platinum is gone.
  24. Jul 19, 2019 at 4:50 PM
    TylerDurden311
    2018 Tundra CM
    Ahh... Id imagine if it bolts up in the same place the spacers would be fine.
  25. Jul 19, 2019 at 4:50 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    It’s this kit
  26. Jul 19, 2019 at 4:53 PM
    TylerDurden311
    2018 Tundra CM
    It looks like there saying that with a pro skid plate it may need modifications.. I would call toytec and ask. They are pretty helpful.
  27. Jul 19, 2019 at 8:16 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    The RCI aluminum skid is no thicker than the aluminum Pro skid.
    The pros that off-road for a living and run races like baja and do the hardest core rock crawling usually use aluminum skids.
    Aluminum does not rust and weighs less than steel.
    I have not ever had noise or fit problems with my aluminum pro skid. I’ve added shims to the front struts and had the back hardware off for adding the RCI transfer skid, still no problems.
    The access door for oil changes is really nice. Both have these.
    If you are able to get a better price on the RCI, that would be a reasonable reason to get it.
    Just a few thoughts...
    .2$
    Myhobbes25 and JimboSlice413 like this.
