Side Storage bags for Bed
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mks99, Apr 9, 2019.
  1. Apr 9, 2019 at 7:51 AM
    Mks99
    Mks99 [OP] New Member
    2019 Barcelona Red Platinum
    Being the overly thrifty person I am (my wife has a different term for that) I decided to try something different for storage in the bed. Tie downs, some gloves, hats and other stuff that I don't need regular or immediate access can go into these. I've seen the swing out storage but the $200 price tag each was more than I could justify right now. I just don't use a lot of this stuff all the time for that cost.
    As I was ordering new tie down rings for the bed from the surplus site some others have recommended I noticed these bags. Around $10 each plus shipping for the order. I also did get some of the cotton web straps to hang the larger bags.
    https://armysurpluswarehouse.com
    http://armysurpluswarehouse.com/military-issue-vehicle-cargo-tie-down/ $4 if you need them
    http://armysurpluswarehouse.com/canvas-bag-danish/ $10
    http://armysurpluswarehouse.com/military-issue-web-strap/ $2 each and two per Danish bag
    http://armysurpluswarehouse.com/vintage-military-german-bread-bag/ $13
    You can get about 4-6 of the small ratchet tie downs into the Bread Bag if you are neat and roll them up. A LOT more can go into the Danish bag. Its just one big compartment. The web straps simply just hang over the standard bed rail. I have a BAK Revolver but this should work with stock rails also. Obviously this is NOT WATERPROOF. Things seem to stay pretty dry under the BAK cover and with them hanging they should get air around them to dry of there is any moisture. You can see below that one large and one small bag fit easily on each side. Mix and match to your preference. The small bag just has some cheap spring clip type hooks on them and they clip into existing holes in the rails.
    So for about $30 per side with shipping you can get some pretty good storage available.
    Just thought I would share. :cool:
  2. Apr 9, 2019 at 7:58 AM
    That's bad ass! Great idea!
  3. Apr 9, 2019 at 1:19 PM
    drjohnson1483
    drjohnson1483 New Member
    Dave
    2016 Tundra Crew TRD Pro
    Great Idea. I have a tonneu cover and a bedslide, this is a great solution to add storage. Where did you get the brackets to hold the bed rail?
  4. Apr 9, 2019 at 1:47 PM
    AmericanBeast
    AmericanBeast New Member
    Jon
    2017 Bronze 1794
    I second that! they look so much better than the plates I have on mine
  5. Apr 9, 2019 at 1:58 PM
    Talkdirttome
    Talkdirttome Dad
    Jon
    So Cal
    2018 Silver Tundra CM 4x4
    Solid idea! I will be ordering these today.
  6. Apr 9, 2019 at 2:03 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I was too "overly thrifty" to get a sprayed on bedliner so I bought a Toyota bed mat like yours.
  7. Apr 9, 2019 at 3:50 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Great idea! Very versatile.
  8. Apr 9, 2019 at 4:24 PM
    Mks99
    The brackets are the standard "with rails" option on the BAK Revolver for mounting. Like I said, hanging the bags off the rail even in the stock position should not be an issue. The small bag just clips in and the larger bag straps should be thin enough to fit under any cover. (I think)
  9. Apr 9, 2019 at 6:45 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
  10. Apr 9, 2019 at 6:50 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    That's a great idea! Thank you for sharing.
    RoujePN likes this.
  11. Apr 9, 2019 at 8:05 PM
    RoujePN
    RoujePN New Member
    2019 Platinum CM 4x4 5.7L 1G3
    ^X2
  12. Apr 9, 2019 at 8:06 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Genius. I'm sold.
  13. Apr 10, 2019 at 8:37 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Subscribed. I gotta break down and get the BAK brackets and then do the Uni-Strut rail addition. It just pisses me off that BAK brackets are about $60.
  14. Apr 10, 2019 at 8:39 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Nicely done!
  15. May 7, 2019 at 6:08 AM
    bhuff92
    bhuff92 “Hi, I’m Rod and I like to party”
    Ben
    Columbus, Ohio
    2018 Charcoal Tundra SR5 Crewmax
    Iron Cross Front Bumper with Grille/Brush Guard.
    Great idea! Have a bunch of old mil-surp that I can use. Thanks for the tip!
  16. May 7, 2019 at 6:23 AM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Great idea! Thanks for sharing. Now I just need to get some rails for my bed.
