Should I replace my factory brake controller?
Discussion in 'Towing & Hauling' started by Tundraplatinum, May 29, 2017.
  1. May 29, 2017 at 6:09 PM
    Tundraplatinum
    Tundraplatinum [OP] New Member
    2016 Platinum CM
    So I've read all the posts about the factory controller on my 16 and seems everyone is mixed on it. So I've towed my 7500lb travel trailer all last summer about 4000 miles. most of the time it seems o be working but sometimes seems like it doesn't want to stop. I have heard that you should be able to lock up your trailer brakes with full gain is that true? mine do not lock up. Do I stick with factory or do I get a p3?
  2. May 29, 2017 at 6:15 PM
    gosolo
    Ray
    NW Oregon
    If you're not getting consistent braking from the controller get one that is consistent before you or someone else gets hurt.
    driverdog likes this.
  3. May 29, 2017 at 6:25 PM
    Tundraplatinum
    2016 Platinum CM
    not sure that its not consistent, just don't know if replacing it will make it better or not?
  4. May 29, 2017 at 6:48 PM
    gosolo
    Ray
    NW Oregon
    What were the circumstances when you felt that you had inadequate braking?
    @ColoradoTJ has considerable experience with trailering, perhaps he may offer some advice.
  5. May 29, 2017 at 7:02 PM
    Tundraplatinum
    2016 Platinum CM
    It's when I need to stop quicker. Maybe just not possible to stop that much weight. Just seems like it could be better if I switch to electric over hydrolic it stops better but jerky not smooth at all. I know my brakes are not hydrolic just trying different settings.
    I was hoping for some input from Coloradotj or anyone else who has experience with both factory and aftermarket controllers
  6. May 29, 2017 at 7:04 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    On my 17 sr at the beginning of my trip is weak..so. I heat up the pads my manually triggering the brakes a couple of times the braking power comes back..is not just the controller the pads can get crystalized and reduce efficiency..
  7. May 29, 2017 at 7:31 PM
    LML 3500HD
    I'll reply later, but your brakes should be smooth whether it be electric or hydraulic .
    I will say this, I was pushed through an intersection under emergency braking once with my old truck. Lucky for me it was just to try and stop for a rellow light.
    Trailer brakes should stop you very easily. If they are not, something is wrong and should be addressed at your earliest convenience.
    Tundraplatinum[OP] likes this.
  8. May 30, 2017 at 4:53 PM
    Tundraplatinum
    2016 Platinum CM
    I was hoping someone that has changed out factory controller for aftermarket would chime in. I think I'm gonna order a p3 and install temporarily to try out. If it's better than oem I'll order the esp panel for it
  9. May 30, 2017 at 5:34 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    I am one who gave up on the factory IBC, installed a Prodigy P2 ( because that;s what I had in my Dodge and have in my 2015 Tacoma. Removed the factory unit, enlarged the hole in the panel, and used industrial velcro to hold the Prodigy in place. The factory IBC appears to be a time based controller and the Prodigy is inertia based, and works like a brake controller should. The cable for the P2 is a 3017 and plugs into the cable removed from the back of the IBC.
  10. May 31, 2017 at 2:22 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    @Tundraplatinum based on what you are saying, I would immediately switch to an aftermarket brake controller. I swapped mine out a few weeks ago and it was probably the best mod I've made to my truck.
    I installed a P3 with the ESP panel.
    [/URL
    My factory IBC couldn't adequately or safely stop my camper to my satisfaction under normal driving conditions and it only weighs 2,800 lbs (dry weight). I can't imagine how dangerous it would have been trying to stop something much larger in an emergency situation.
  11. May 31, 2017 at 2:59 AM
    Tundraplatinum
    2016 Platinum CM
    Thanks guys. Ordered p3. Going on another trip 9th so I'll report back then
  12. Jun 5, 2017 at 4:36 PM
    Tundraplatinum
    2016 Platinum CM
    So I got my p3 few days ago, got my esp mount today. Popped that thing in there in like 5 minutes but now my dash says check trailer brake controller see dealer. My truck is 16 platinum, is there a easy fix for this?
  13. Jun 5, 2017 at 5:04 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    unhook the battery, I left mine disconnected for like 20 minutes, error message gone
  14. Jun 5, 2017 at 5:29 PM
    Tundraplatinum
    2016 Platinum CM
    will do, thank you
  15. Jun 5, 2017 at 5:29 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    X2 on p3. Mine works very well pulling a 9300lb trailer and having the gain set at 10. You don't want your trailer breaks to lock up under full gain though from what I understand.
  16. Jun 6, 2017 at 3:33 PM
    Tundraplatinum
    2016 Platinum CM
    Battery disconnect solved error messages. Now wait till Friday's trip to niagara falls to see how it works
  17. Jun 9, 2017 at 5:48 PM
    Tundraplatinum
    2016 Platinum CM
    3 and half hours to Canada today. P3 definitely better than factory. But gain is all the way up still doesn't lock up wheels. brakes on trailer are self adjusting and trailer only 1 year old. I know they say adjust to right before wheels lock up?
  18. Sep 22, 2017 at 10:05 PM
    Katoomon
    Katoomon New Member
    Great Basin
    2016 SR5 Silver Sky DC
    TRD wheels, Dicoverer AT3's, pop-lock tailgate, 6112/5100 Bilsteins, Leer shell (lock wired to tailgate), Bedrug, GPS mod,
    Take another look at the P3 manual, in addition to the gain setting there are 3 boost settings. This is very useful for trailer unloaded/loaded scenarios and perhaps for your situation.
  19. Sep 23, 2017 at 2:57 AM
    Tundraplatinum
    2016 Platinum CM
    On the way back home from that trip the brakes started really working good had to keep lowering the gain setting I've done a few more trips and brakes work amazing.
    Only thing I can figure is my travel trailer has automatically adjusting brakes I think the factory controller wasn't applying them enough for them to adjust themselves
  20. Oct 29, 2017 at 7:26 PM
    jdg1982
    jdg1982 New Member
    New Roads, LA
    2017 Magnetic Gray Tundra SR5 4x4
    May be a dumb question, If I’m replacing the factory brake controller, can I install the P3 into the same spot that the factory one was in or do I have to buy the panel also?
  21. Oct 30, 2017 at 3:29 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    I enlarged the opening of the IBC panel so the Prodigy would fir, then used some industrial velcro on the bottom of the prodigy and the bar of the dash to hold it in place.
    I got a 2018 a few weeks ago, and the IBC works great as the earlier model should. Set up is different with choices of electric and electric over hydraulic, and o to 5000 pounds and over 5000 pounds. The bar graft is progressive not all or none. World of difference.
  22. Nov 1, 2017 at 5:04 PM
    Players 2014 Tundra
    Players 2014 Tundra New Member
    Jon
    2014 Tundra SR5 5.7 V8
    P3 Brake controller
    Do you think the 2018 IBC will work with my 2014 Tundra or will the software not be compatible? I know i can change out the trim panel to install the Factory controller just not sure if it will work in my truck.
  23. Nov 1, 2017 at 5:18 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    My guess is that the 2018 will not work because the user interface in the dash display is entirely different along with the controls on the steering wheel. The unit in the dash looks the same.
