Should diff fluid changes be part of maintenance?
Discussion in '2.5 Gen Tundras (2014-2021)' started by theblacklines, Jan 4, 2026.
  1. Jan 4, 2026 at 12:45 PM
    theblacklines
    theblacklines [OP] Soli Deo Gloria
    2014 SR Inherited
    I inherited by dad's Tundra that was dealer maintained.
    I'm poor so I went to Take5 today and they checked the diff fluid - showed me the plug very black. I asked my mom if they've ever done the change at the dealer and she's never even heard of a differential.
    Looking it up on the toyota owner's site and I don't see anything about diff fluid changes. My dad took it to the dealer ever 3 months and he was one to just say yes to scheduled maintenance. But don't see any diff fluid changes, shouldn't this be part of the inspections/dealer maintenance?
    There are over 50 records on the site.
    Ponderosa_Pine likes this.
  2. Jan 4, 2026 at 1:00 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    I do it every 30K!
    Easy to do yourself.
    IsaiahCanada and Oey12 like this.
  3. Jan 4, 2026 at 1:14 PM
    theblacklines
    2014 SR Inherited
    What do you use? Do you jack the truck up? Do you do the front and rear? IS there more?
  4. Jan 4, 2026 at 1:21 PM
    theblacklines
    2014 SR Inherited
    Is there a maintenance thread I don't know about? the search feature isn't great on here.
  5. Jan 4, 2026 at 1:26 PM
    texasrho83
    texasrho83 Ye Olde Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  6. Jan 4, 2026 at 1:41 PM
    ARMYGREEN
    2014 CrewMax MGM
    I do Front, Rear and Transfer case every 30K.
    Mobil 1 75w90 sythentic for the front and rear 2.2 quart front, 3.8 quart rear.
    Washers Front
    fill 12157-10010
    Drain 90430-24003
    Washers Rear
    Fill 12157-10010
    Drain 12157-10010
    Ravenol 75w in transfer case 1.58 Quart off Amazon
    No Washers
    ColoradoTJ, 831mic, Bo13R and 2 others like this.
  7. Jan 4, 2026 at 2:39 PM
    Engineer83
    Engineer83 New Member
    2007 Tundra 5.7L
    Short answer is yes to the diff fluid changes. Have a 2007 Tundra with 137K. The rear diff fluid is just too easy not to change on a regular basis. Used 3.5 qts Valvoline full synthetic 75W90. If you tow a trailer, change it more often. The rear diff gets dirty fastest. I went 50K on the first fluid changes - rear and front were dirty and the transfer still pretty clean. Next change at 80K - rear was dirty but not bad. Next change at 120K - rear was dirty. Front diff done at 135K and oil was still clean. I agree with ArmyGreen that 30K is just good maintenance. None of my magnets have had more than very light metal dust on them.
    theblacklines[OP] likes this.
  8. Jan 5, 2026 at 4:16 AM
    WyoKC
    WyoKC "Work" truck...tows our TT
    2017 SR5 CM TRD Off Road Pkg. (Flex Fuel variant)
    Running boards, Tonneau cover, Extendable tow mirrors
    It's in either the owners manual or the maintenance & warranty book (I forgot which one has the maintenance schedule), but yes, do it every 30k; or 15k if you tow a lot.
    I suggest you look into this more because it doesn't make sense that your dad said yes to every service - and it IS in "the book" to service diffs, yet you can't find records of it being done. Dealerships never miss a chance to do a service and charge for it.
    AZBoatHauler likes this.
  9. Jan 5, 2026 at 4:46 AM
    theblacklines
    2014 SR Inherited
    Maybe I don't know how to read the receipts, but here are a couple screen shots
  10. Jan 5, 2026 at 4:57 AM
    Tripleconpanna
    2021 TRD PRO CM; 2011 SR5 SC'd DC; 2008 SR5 CM
    Look for Transfer Case Fluid, Differential Fluid (changes or drain and fills, etc...) Services
    I'd look for those service(s) to have been performed around 30k or 60k...
    It appears your father requested a brake fluid swap at 75k, so I can't imagine he didn't have the diffs and t-case done (if it's 4WD). If it's 2WD it would just be the rear differential that would need to be serviced.
  11. Jan 5, 2026 at 5:04 AM
    theblacklines
    2014 SR Inherited
    Yeah, looked for that at those intervals and didn't see anything. Perhaps it's just not on the owners site and the details might be in the paper receipts, which I also have. It's 4WD
  12. Jan 5, 2026 at 7:06 AM
    Xcumminsguy
    Xcumminsguy New Member
    NY
    2021 Tundra TRD Pro Crew Max
    Stock, with a few cosmetic mods.
    Definitely!!!
  13. Jan 5, 2026 at 1:21 PM
    Tripleconpanna
    I'd call the dealer(s) where the vehicles were serviced at and ask them as well. Plus, some dealer receipt summaries don't seem to list out the 'visit' in its entirety, so you may have to click on those links, etc. to find additional details or services provided...
    Another way to research is to make an account w/the Toyota Owner's website, which I believe will show service history as well although it may be an abreviated view...
    If your research isn't able to confirm or dispel the work, then I'd have them done when you can. As others have said, most of us do fluid swaps in the t-case and diffs every 30k. It should cost you about $600 for all (3) if you're paying someone for labor and fluids (give or take)...
    From there, I'd consider repeating that service every 30k (especially if you are towing), but many will do it every 50 or 60k :thumbsup:
    WyoKC likes this.
  14. Jan 5, 2026 at 1:59 PM
    theblacklines
    2014 SR Inherited
    I have screenshots from the Toyota owners site above.
    not much detail beyond what’s on the SS.
    I’m planning on doing it myself even though the oil is pricey $20 a quart
  15. Jan 5, 2026 at 7:31 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    I just did my 2008 again. I had been using Mobil 1 but this time I just bought 2 gallons on Valvoline Synthetic 75w90 for $55/gallon. Basically, takes 2 gallons to do my trucks front, rear, and transfer case. I usually just buy the crush washers off Amazon. There is a guy that sells them by the set. I buy enough to do 4 fluid changes each time I buy them. Never had an issue with them and have been using them for years. I know some newer trucks use something different in the transfer case.
  16. Jan 5, 2026 at 10:10 PM
    Tripleconpanna
    Yes, I'm not sure what year there was a change for the transfer case fluid type, but my 2011 and 2008 takes different fluid than the 2021. Make sure you check your owner's manual, etc...
    This is what I used in the 2021:
    Fluid: Ravenol Gear Oil MTF-3 75W (Ordered 2 liters, capacity 1.58qts)
    huntertn[QUOTED] likes this.
  17. Jan 6, 2026 at 12:20 PM
    jza80king
    jza80king New Member
    Edward
    Utah
    I just did front/rear diff and transfer case on my 2021. Look up "Tool Demos" on YouTube, the guy has a channel and walks you through all the basic maintenance you need. It's really not difficult to do, you will need to just buy a few tools to make the jobs easy, I bought a hand pump from Harbor Freight for $15. Check out the video below for the rear diff.
    https://youtu.be/XtBw29bA6ug?si=ievorWIUdzmUFBGl
  18. Jan 6, 2026 at 12:55 PM
    tundra1502
    tundra1502 2021 SX All Stock
    Pat
    2021 2WD SX Ext Cab All Stock
    None
    I don't know one fluid in any vehicle that isn't required to be changed at some interval.
  19. Jan 6, 2026 at 3:34 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    Just DIY, it's pretty easy and doesn't require any special tools.
    Also, the first Diff fluid change will be pretty nasty smelling and there will be metallic crap in it from the gears breaking in when the truck was new.
