Shock confusion and help
Discussion in 'Suspension' started by Darren509, Jun 14, 2018.
  1. Jun 14, 2018 at 5:59 PM
    Darren509
    Darren509 [OP] New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    So i have read hundreds of posts on shocks and to be honest I kind of got lost with too much information. To break it down, I have the regular trd with yellow and blue shocks and cant stand them. Ultimately Im fairly positive the trd pro set up would make me happy but it seems they are too hard to find or too expensive for my taste. My shocks are too stiff and Im looking to replace with something for a mostly daily driver on road with lots of trips to the feed store and occasionally towing. I just want a reasonable upgrade that dosent jolt me every bump I hit. Its a truck and I know it handles like one but what is the ideal set up for this? Thanks for answering shock question number 10 billion !
    ColoradoTJ likes this.
  2. Jun 14, 2018 at 6:04 PM
    3” or less? Eibach, BOSS, Radflo, King, Old Man EMU etc.
    4x4_Angel, ColoradoTJ and Sunnier like this.
  3. Jun 14, 2018 at 6:47 PM
    Darren509
    Darren
    Dayton NV
    Thanks. But I am looking for more of a personal opinion on which one of the many brands available will feel softer on the road than what I have already. Lower on the budget scale as well.
  4. Jun 14, 2018 at 6:52 PM
    Nick T
    Nick T New Member
    Nick
    Bilstein 6112 will be closest to a PRO ride on a budget. Lots say add a rear sway bar to smooth out the rear.
    15whtrd and Sunnier like this.
  5. Jun 14, 2018 at 6:55 PM
    Darren509
    Darren
    Dayton NV
    Is that with the 5100 rears also?
  6. Jun 14, 2018 at 6:59 PM
    Nick T
    Nick T New Member
    Nick
    5100, 5160 although i have read the 5160 don't hold up well... on a budget, i would get the 5100 and sway bar plus 6112 for the front.
    Or cruise craigslist for a set of trd pro... although that has dried up since no new pro have been sold in a year.
    Sunnier likes this.
  7. Jun 14, 2018 at 8:39 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Is it your shocks or coils and leafs?
    If you add weight to the bed does it feel better? If so I'm guessing the stiffness your feeling is the leaf springs. Idk how to test the front. The shocks control more of the rebound I believe anyway.
    Also just as a quick, free, possibly fix....what PSI are you running in your tires?
  8. Jun 14, 2018 at 8:44 PM
    Gotta pay to play.
    ColoradoTJ and MatthewPTguy like this.
  9. Jul 8, 2018 at 9:10 PM
    Darren509
    Darren
    Dayton NV
    I made the decision to use Bilstein 5100 front and rear. I only had time to mount the rears so far but they are a huge improvement so far. Im not sure yet if I will use stock height yet on the front or not but Im not sure if your supposed to use shims on the front for factory height or only if you go more?
    4x4_Angel and Pudge like this.
  10. Jul 8, 2018 at 9:17 PM
    Pudge
    CT
    If you decide to go higher using the spring perch adjustment...I would go with the lowest possible but you dont want stuff so probably stick with stock ride height. I used 5100s on my Tacoma on the middle setting and they did ride rough. Any time you compress the springs like that it'll be stiffer, even with better shocks.
    Shins are to add as little more height, or can be used on one side or the other to level out any side to side unevenness. Tacomas were known to sit almost and inch lower on drivers side.
    I liked the rear 5100s more than the fronts, probably because I used the fronts to compress my coil springs
  11. Jul 9, 2018 at 4:09 AM
    Professional Hand Model
    Hand Protectors
    Go with some Monroe Coilovers Premiums. Should hit your price point and satisfy your ‘cushy’ desire on the road.
  12. Jul 9, 2018 at 7:22 AM
    Darren509
    Darren
    Dayton NV
    Thanks, but I wasnt looking for a cushy ride, just shocks that didn’t biunce my coffee cup out of the holder got a few more miles in and so far the 5100 are a night a day difference over the stock. Look forward to putting the front pair on
  13. Jul 9, 2018 at 2:57 PM
    Hand Protectors
    I read your OP and saw ‘too stiff’ so recommended something soft. Thats what she didn’t say! I have the 5100’s and like them. They are a bit stiff IMO.
    HighDesertSurfer likes this.
  14. Jul 9, 2018 at 3:06 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I have radflo 2.5 front and boss rear using the toytec kit. Way more plush than stock.
  15. Jul 9, 2018 at 3:23 PM
    Darren509
    Darren
    Dayton NV
    Yeah, it is really hard to judge what we all mean with trying to describe the way our shocks react. The 5100 are stiffer in all reality buy they absorb the bumps alot better by not letting truck actually move as far. I should have chosen a better way to describe what I was thinking
  16. Aug 6, 2018 at 6:58 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Bilsteins are stiff for 2 reasons, preload and their digressive valving. If your not a fan, get a shock thats valved progressively.
    T-Rex266 likes this.
  17. Aug 6, 2018 at 4:24 PM
    Hand Protectors
    Yeah bud. I like the Billys. Their just different from what I had before. They tow and handle weight in bed really well, I’m discovering. Seems like it rides smoother with weight. Without weight they’re stiff and ‘sporty’ feeling.
  18. Aug 6, 2018 at 4:50 PM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    2018 White SR5 5.7 4x4 TSS Tundra
    I had 5100s on my old truck. They were set for max lift on the front end and that was a mistake, the rebound was crazy. I felt like the rears were too stiff too. Personally, I would go another route if I made a decision to get different shocks on my Tundra. Talk about making your teeth chatter.....
  19. Aug 6, 2018 at 5:02 PM
    Hand Protectors
    This was why I was hesitant on going full height up front and just went one click up. Getting that rebound from coil loading didn’t sound fun. I carry some extra weight of about 400lbs with bigger tires, side boxes, and a few other items. I like them overall. Its always an experience trying new stuff.
