shimmy in toyota tundra
Discussion in 'General Tundra Discussion' started by jr123, May 14, 2020.
shimmy and vibrations in steering whel in Tundra 1794
  1. 2
    1 vote(s)
    100.0%
  2. 2
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. May 14, 2020 at 12:18 PM
    jr123
    jr123 [OP] New Member
    2019 tundra 1794
    Hi is there a problem with toyota tundra with shimy and vibrations in steering wheel
  2. May 14, 2020 at 12:28 PM
    Jim LE 1301 Camaro Lover, SSEM # 11
    No
    Maybe you have a wheel out of balance. Hit any potholes?
    Cpl_Punishment likes this.
  3. May 14, 2020 at 1:41 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    If it happens during braking, probably a warped rotor. If during normal driving and speed- you may have a wheel/tire than needs to be balanced. Check for those things first....if neither one of them move on to potential worn suspension/steering components.
    Most often is a wheel balance or warped rotor. Not sure why, but based on reading here and my experience, Tundras seem to be sensitive to both wheel balance and rotor issues.
  4. May 15, 2020 at 10:53 AM
    Fuumanstu
    Fuumanstu New Member
    Stuart
    San Diego CA. via Hickory Corners Michigan
    2017 SR5 Texas Edition
    Wheels, Tires, LED Projector w/ Mesh Grill, Running Boards, Color Matched Box Topper
    Hey guys, I had this start on mine about a month ago 2017 SR5 ... took it in to my local dealer ( Larry H. Miller Lemon Grove CA. and the tech verified that the caliper pins were dry. This he explained caused the pads to "lightly rest" on the rotor heating them and warping. I had mine still under warranty... they pulled and cleaned/greased the caliper pins resurfaced the rotors and slapped a new set of pads. I'll see how long this lasts.... warped rotors sure are frustrating for sure.
    Ely010606 and Black Wolf like this.
  5. May 15, 2020 at 3:11 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Guys in the rust belt?...They just worry about being able to remove the pins when the time comes. :sawzall::bananadead::welder::censored: :santa:
    Did the tech also have a recommendation on how often you should come in to "get your pins greased"?
  6. May 15, 2020 at 5:26 PM
    Fuumanstu
    Stuart
    JohnLakeman nope, he didn’t. I’m figuring I’ll be greasing my own pins after the warranty runs out on a routine as needed break job anyway.
  7. May 15, 2020 at 5:52 PM
    JohnLakeman
    The story is blarney. You were going to need a brake job anyway, and he provided a story. I will need to be convinced that pads "lightly touching" the rotor will ever cause a rotor to warp. Disc brake pads are ALWAYS lightly touching the rotor; disc brake pads do not retract, they are just not being forced against the rotor. Now, I could believe improper torqueing of lug nuts with an impact wrench could get it done.
    The Service Repair Manual does not call for any lubrication of the front pins (just the messenger here). It does call for lubricating the rear pins with a lithium soap based glycol grease and torqueing to 65 ft-lbf. The reason for that is the rear pins have rubber bushings. Lithium soap base glycol grease is special only in that it will not deteriorate rubber parts like mineral oil greases. Other available products, like silicone based grease, are equally "special" in not consuming the rubber parts.
    Frankly, I wouldn't worry about lubing the pins, except as maybe a futile attempt to reduce corrosion. As I said, no lube is specified for the front pins.
    classiccat and Ely010606 like this.
  8. May 15, 2020 at 6:28 PM
    Fuumanstu
    Stuart
    I’m at 20,000 miles went in with a shake, The Blarney Stone said he greased the pins. Changed pads (old ones measured at 8mm) and resurfaced the rotors. Also did a Tire rotation. No more shimmy at speed 65-70 nor while breaking. I sure hope this pig doesn’t warp rotors every 20,000 miles. image.jpg
    Ely010606 likes this.
  9. May 16, 2020 at 5:10 AM
    JohnLakeman
    The tech's best intentions may also have built in future trouble with tire rotation. Best advice after a shop tire rotation would be to jack up each wheel, loosen the wheel lugs, then use a good torque wrench to retorque the wheel nuts to specified torque in 2-3 steps using a "star" pattern.
    Over-torqueing or uneven torqueing of the wheel lug nuts, which also clamp the rotor against the wheel hub, can distort the rotor disc surface. It is particularly important to match-mark rotors and reinstall them back in the original position when doing brake work. Steering wheel "shimmy" or "pulsing" is caused by mechanical "run-out" of the rotor face. Run-out of the disc surface can be measured with a dial indicator mounted on a magnetic base. Allowed "run-out" on Tundra front rotors is about 0.002" (thickness of copy paper). The effect of run-out is for the rotor disc surface to "wobble" as it rotates. Resurfacing the disc surface removes the wobble, but it also removes material thickness making the rotor more prone to distortion in the future.
    At least they didn't charge you for the service.
    Ely010606 and Cpl_Punishment like this.
