Shifting into 4X4
Discussion in 'General Tundra Discussion' started by Redd, Jan 13, 2020.
  1. Jan 13, 2020 at 9:12 PM
    Redd
    Redd [OP] New Member
    2016 Gray TRD Tundra
    None
    Got a question on shifting into 4X4 high....snowing here pretty much all day, not enough for 4X4 and snowing all night, going to need 4X4 tomorrow for sure. I'm in my driveway and have to back out AND I'm on a hill, so....can I engage into 4X4 in reverse while backing out of my driveway or do I need to be in Drive?
    Thanks
    Rica25 likes this.
  2. Jan 13, 2020 at 9:16 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    You can do it in reverse, neutral, drive
    4lo you have to be in neutral
    Aerindel likes this.
  3. Jan 13, 2020 at 9:18 PM
    MikenMike
    MikenMike New Member
    RACEtruck
    Anytime...sometimes it takes a shift from drive to reverse to engage...or vise verse
  4. Jan 13, 2020 at 9:21 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Engage it before you back out, be careful don’t switch to 4wd when the tires are slipping.
    Aerindel and Tundyfundy like this.
  5. Jan 13, 2020 at 9:21 PM
    Redd
    None
    Thanks guys...and thanks for not giving me shit on my lame question...had 4X4's since 81' and never had to think about one before.
    Tundyfundy and BravoDeltaRomeo like this.
  6. Jan 15, 2020 at 5:14 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    You'll get the hang of it in no time considering you are going to exercise the 4wd every month or so, correct ??
    Tundyfundy likes this.
  7. Jan 16, 2020 at 3:28 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    The 4 wheel drive sometimes takes a few rolls to get engaged. Sometimes a push on the gas or brakes is needed. I think you should engage it before you shut your truck off the night before if you know you’ll need it first thing. Get aquatinted with the system. There’s a little card in the visor that explains it all. Good luck! What tire pressure you running?
    Samoan Thor and 15whtrd like this.
  8. Jan 16, 2020 at 3:47 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I though this was a no go?
  9. Jan 16, 2020 at 3:54 AM
    Tundyfundy
    Bay Area, CA
    I’ve never heard that. If I go somewhere that needs 4 wheel drive I leave it in 4 wheel until it’s safe to shut it off.
    It’s a no go to have it engaged in areas that have good traction unless you’re going straight and not turning, in which case it’s fine. As long as he does it let’s say just before going up his hill at the end of the day.
  10. Jan 16, 2020 at 6:10 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    If I know I'm gonna need 4wd in the morning, I just lock it in the night before when I park. :notsure:
  11. Jan 16, 2020 at 6:37 AM
    Samoan Thor
    It’s perfectly fine, I was driving around in Arizona’s snowy and icy roads in 4hi. Left it in 4hi when I parked in deep snow for the next morning, you still have to take it slow. 4wd sends power to all 4 wheels but not the brakes, you go too fast and brake hard nothing will stop you once you start sliding neither 4wd or the best brakes.
  12. Jan 16, 2020 at 7:18 AM
    Elduder
    Elduder New Member
    Only issue with leaving it in 4wd would be if the actuator decides to go to shit and then your stuck in 4wd. That could happen at anytime though, but in my experience happens more when the actuators have long idle times.
    Drive or reverse doesn't make a difference, you can even put it in 4wd on the fly, up to 60 mph :eek2:, if I'm remembering correctly. Its all in the manual.
  13. Jan 16, 2020 at 12:13 PM
    Cpl_Punishment
    Cpl_Punishment Head on straight, mask on crooked
    Neil
    2020 MGM SR5 CM 4X4
    In my experience, you actually have to be rolling to shift into 4Hi. If you're stopped, the indicator will just flash.
    Tundyfundy and 15whtrd like this.
  14. Jan 16, 2020 at 12:27 PM
    Aerindel
    Aerindel New Member
    Montana
    2000 Tundra AC, SR5, 4.7 V8 4WD, 340k'ish miles, 2008 Sequoia, 220k Miles
    Being stuck in 4wd is a lot better than being stuck in 2wd!
    My truck has not trouble shifting in any situation as long as the actual shift happens below 62. I probably spend more time in 4wd than out of it.
  15. Jan 16, 2020 at 12:31 PM
    15whtrd
    15whtrd Mr. Blonde
    This is true. I’ve experienced it myself. The truck likes to be moving just a little bit at a minimum.
