Shifter feels like molasses
Discussion in '1st Gen Tundras (2000-2006)' started by Redstart, Sep 7, 2019.
  1. Sep 7, 2019 at 5:55 AM
    Redstart
    Redstart [OP] New Member
    2005 Tundra SR5
    When my 2005 Tundra SR5 sits for more than a week. The next several times I drive, putting it into gear, the shifter feels like molasses. There is resistence. It does shift, but not smoothly. After a few days it returns to normal shifting. Any ideas what is causing this?
  2. Sep 7, 2019 at 8:32 AM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    When was the last time you did a flush on it?
  3. Sep 7, 2019 at 8:36 AM
    Redstart
    2005 Tundra SR5
    I have not had it flushed. Do you think that is what is needed?
  4. Sep 7, 2019 at 8:39 AM
    Padj
    Denver, Colorado
    Are you the original owner and how many miles?
  5. Sep 7, 2019 at 9:06 AM
    Redstart
    2005 Tundra SR5
    Its got 130,000 miles and I am not the original owner. I bought it 2 1/2 years ago.
  6. Sep 7, 2019 at 11:09 AM
    Padj
    Denver, Colorado
    I would definitely start with that. It may never have been done.
  7. Sep 7, 2019 at 11:12 AM
    Padj
    Denver, Colorado
    Plus it gives you an opportunity to see what the fluid looks like coming out. Do you have a magnetised pan?
  8. Sep 7, 2019 at 11:12 AM
    15whtrd
    15whtrd Mr. Blonde
    No flush. Drain and refill. That’s what I’ve been told.
  9. Sep 7, 2019 at 4:34 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    x2.
    Especially with the mileage stated.
    Maybe filter change too but no power flush.
    15whtrd[QUOTED] likes this.
  10. Sep 7, 2019 at 10:50 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    How could a drain fill fix this shifter issue?
    Seems like your shifter linkage is getting corroded when not used or something along those lines.
    Couldn't see how old transmission fluid could cause this issue.
  11. Sep 8, 2019 at 3:06 PM
    Padj
    Denver, Colorado
    Let's not be tearing the transmission apart just yet. Plus if it is corroded there will be evidence in the flush.
    15whtrd likes this.
  12. Sep 8, 2019 at 3:43 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Agree with this but also think a drain+fill is always a good idea. I would do that as part of routine maintenance. I'm not convinced it's going to solve this issue though.
    15whtrd likes this.
  13. Sep 8, 2019 at 4:09 PM
    Padj
    Denver, Colorado
    I agree with you that it will probably not fix his issue, but it would be my first step in the diagnostic process.
    15whtrd likes this.
  14. Sep 8, 2019 at 4:22 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Is it the actual shifter if it's a manual transmission, or are you talking about how the automatic transmission shifts after you start moving? If it's the actual shifter, it's because the lubricant in the mechanism is degrading and becoming thicker. My Mother-In-Law had a Toyota pickup back in the 80's. She called and said it was almost impossible to shift. It was a standard transmission with the shifter on the floor. I hosed it down with a good cleaner and then lubricant and it was like new. You didn't mention whether you have a manual or automatic, but in either case all you may need to do is clean the linkage (there may be a cable involved if it's an automatic) and relube everything. Having the transmission serviced (fluid and filter change) is a good idea, but don't let them talk you into a flush. Flushing an automatic transmission is a recipe for disaster. Opinions on this vary, but I've seen too many transmissions that require a replacement or rebuild after a flush.
  15. Oct 18, 2019 at 3:23 PM
    Professional Hand Model
    Hand Protectors
    I posted this a while back after having my panels off doing some other work. I reused the factory grease which looked like it pushed itself to the sides (of contact/slippage points). Just wiped the OEM grease off the sides and reinstalled it back where it should be. Smoovvee! 2002 Tundra Automatic 4.7
  16. Mar 6, 2020 at 4:34 PM
    Jmransom
    Jmransom New Member
    I have this same issue, however mine sat for a few weeks and now it won't shift out of park. I've checked all fuses. Replaced the brake light switch since I had it all opened up anyways. I disconnected the cable from the trans side and it moves fine. Cleaned and Lubed up the shift arm on the trans but I can't get it to move. Any suggestions??
  17. Oct 15, 2021 at 3:46 PM
    Meilix4
    Meilix4 New Member
    Put vehicle up on ramps and wire brush the linkage/cable on transmission and spray with PBlaster. Spray some WD down interior shifter assembly. It should free up.
    Toyoda Tundra likes this.
  18. May 5, 2023 at 8:30 AM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Reviving this. I don't quite have enough grease off to the sides. What grease would be recommended here? Should not be petroleum-based since there is plastic involved, right? Maybe the same thing I use for brake slide pins?
  19. May 5, 2023 at 11:24 AM
    Jack McCarthy
    Jack McCarthy I’ve got my eye on you.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    PHM has faded from the ether and no longer visits Tundras.com due to being banned. I would probably use a PTFE synthetic grease like SuperLube. Just my two cents.
    KNABORES likes this.
  20. May 5, 2023 at 3:29 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Oh no, where did that all play out?
    Good idea about the SuperLube. I think that I have some kicking around somewhere too.
  21. May 5, 2023 at 4:10 PM
    Jack McCarthy
    Bill
    North of Boston
    You’re late to the party Hal, that happened back in the summer of 2022 I believe. It was due to making inappropriate political comments from what I was told.
  22. May 5, 2023 at 4:15 PM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Truck hasn’t needed work so I haven’t stopped by
    Now that the warm times have come, I’ll be sure to stay on top of the gossip.
    w666 and Jack McCarthy[QUOTED] like this.
  23. May 6, 2023 at 8:47 AM
    shifty` Egg Raid On Mojo
    Ooof, my man only stops by when his truck needs work. Suddenly now, we all feel so used. :rofl:
  24. May 6, 2023 at 9:00 AM
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    lol darn it
    Let me emphasize that it has been winter and I can only work on it outside then.
    As a treat, perhaps you can enjoy pinpointing the exact moment my old power steering pump exploded in this short video from a couple of months ago:
    https://vimeo.com/807527834
    I love this thing. Just need to figure out the rust on one of the cab corners. Looks like Toyota has those body panels back in stock so I might actually be able to deal with it at a reasonable cost.
