shady mechanic or dumb luck
Discussion in '2nd Gen Tundras (2007-2013)' started by chance03, Aug 23, 2020.
  1. Aug 23, 2020 at 8:15 AM
    chance03
    chance03 [OP] New Member
    Hey everyone. so 2 weeks i took my truck in to have the passenger side cv axle replaced cause the boot was cracked and spraying grease. a few days ago i noticed it was leaking oil from the same new cv axle seal going into the case. Took it back to the shop and the mechanic said he never touched the seal and didn't replace cause it wasn't leaking and it was totally unrelated to his work and just random that the seal blew a few days after his work and is refusing to replace without full payment calling it a "new" job. Is he correct in its just dumb luck or shady as fu#$
  2. Aug 23, 2020 at 8:26 AM
    Pyrite Tundy
    Pyrite Tundy New Member
    If the seal is leaking after the job, then the mechanic might have damaged it. Depending on the type of shop, ask to speak to someone of authority/owner. It doesn't take long to swap out the seal. The mechanic is trying to make a quick buck...again. Shady AF.....my opinion.
    JoshuaA, Black Wolf and GODZILLA like this.
  3. Aug 23, 2020 at 8:28 AM
    18" TRD Off Road Wheels
    X2
  4. Aug 25, 2020 at 5:03 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Too much of a coincidence.
    GODZILLA likes this.
  5. Aug 25, 2020 at 7:22 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
  6. Aug 25, 2020 at 7:30 AM
    X4, Very shady.
  7. Aug 25, 2020 at 7:36 AM
    Even this would be a slam dunk case for Judge Judy......
    FWD Tundra likes this.
  8. Aug 25, 2020 at 8:15 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I think your title covers both options for the mechanic: shady or dumb fuck.
    Dude should've replaced the seal when he did the CV, regardless if it was "not leaking before". It's a seal, it's not usually deemed reusable.
    mtntop, nuclearlemon and GODZILLA like this.
  9. Aug 25, 2020 at 5:54 PM
    Longtimecoming07
    Longtimecoming07 New Member
    Rick
    2012 Toyota Tundra
    They need to pay for that. I would wipe it off to make sure it’s not just residue
  10. Aug 25, 2020 at 5:59 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Definitely shady.
    I had a mechanic replace the clutch on my 4Runner and the next day I noticed that the Tcase seal was leaking. Took it back, he never admitted they did anything, but replaced all the seals and fluids free of charge.
    bleach likes this.
  11. Aug 25, 2020 at 6:46 PM
    Longtimecoming07
    Rick
    2012 Toyota Tundra
    That’s the way it should be if it wasn’t like that before fix it now if you have a radiator replace and your brakes go metal to metal Different story lol
  12. Aug 25, 2020 at 7:10 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    Having a shop is hard sometimes cause your dammed if you do and dammed if you don’t.
    Ok so we don’t know how many miles are on that tundra that axle seal rubber could of already been hard but that was his responsibility to check that but if you include it in the job From the start some customers might think your nickel and dimming them to death But anything can break on older vehicles He could have snapped off a lug stud broke a ball joint bolt you never know and who’s fault is that? He didn’t rusted It on their it’s a tough business dealing with vehicles and customers.
    I had a situation where a customer came in for Transmision flush on a 1997 Dodge Caravan we lifted the van and her passenger strut fell off broke the axle and snapped the brake hose my tech didn’t see it cause the button to lift the van was on the driver side her whole strut tower was rusted out omg what a nightmare completely not our fault she was so upset called the cops on us we ended up installing a new axle new brake hose bleeding the system she didn’t pay for the trans flush and she sued us that her vehicle was driving fine before it came in and we had to pay for the strut tower repair I’m happy I’m out of the business.
    I would repair an axle seal under warranty anytime that’s easy seal is maybe 10 dollars and the techs are already in the shop and hopefully keep a customer happy so he can come back
  13. Aug 25, 2020 at 11:40 PM
    FWD Tundra
    Washington
    You are right about that, it is a tough business, trying to keep customers happy.
  14. Aug 26, 2020 at 4:35 AM
    slongo
    slongo New Member
    2017 Tundra in Barcelona red
    Side Steps - bed cover - matte black splash graphics
    I had a shop for over 13 years and yes it is VERY tough ! People want everything cheap but they also demand perfection and those 2 things just dont go together ! I have changed hundreds of axles over the years and I have NEVER changed a seal unless it was cut or sliced by accident while doing the job . If it didnt leak right away after the job it was probably just coincidence but a good business man would make right on the repair anyway its just good customer service
    773_eddie likes this.
  15. Aug 26, 2020 at 8:56 AM
    chance03
    truck only has 35k miles on it. it started happening about 2 days after repair. its leaking so bad i had to put an oil catch under the truck for a few days. When asked to fix the problem he quoted me 18 days at full price and if i wanted i could leave at his shop so i didn't have oil in my driveway! Seriously? That is not the right answer. Needless to say he is NOT my mechanic anymore.
  16. Aug 26, 2020 at 11:27 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Why would anything leak at only 35K miles. Sounds like something a warranty should cover.
  17. Aug 26, 2020 at 3:23 PM
    chance03
    It’s a 2011 that sat for 6 years
  18. Aug 26, 2020 at 3:25 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Even if it sat it shouldn't have gone bad unless there's something I don't know.
  19. Aug 26, 2020 at 4:01 PM
    sf319
    sf319 New Member
    Utah
    It's definitely got to be tough. My experience with my mechanic was always great. He was always honest and straight forward with me about any repairs, even down to explaining exactly why or why not to do a repair. I didn't know what to expect when I took the 4Runner back, he looked at it and just took care of it. I wish I still lived close by, I would probably still use his shop when I didn't feel like doing the work myself.
