Shackles ??
Discussion in 'Suspension' started by 559trdTundra, May 6, 2022.
  1. May 6, 2022 at 7:12 AM
    559trdTundra
    559trdTundra [OP] New Member
    After installing 295/70/18 tires & bfd wheels, I notice my truck runs a little bumpy on the highway, I don’t feel it much on the small roads but it’s not a smooth ride like when it had the stock tires & TRD Pro wheels, I herd that upgraded shackles can help stop the car from that bumpy ride ??
    Or what can I do to help stop the bumpy ride,? Thanks
  2. May 6, 2022 at 7:16 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    RAS, Roadmaster Active Suspension helped smooth mine out. What air pressure are you running?
  3. May 6, 2022 at 7:34 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Your firmer/harder ride is due to the fact that you moved from the stock standard load tires, to E load tires. Completely normal and part of the price you pay when installing larger tires on a Tundra. What are you running for air pressure in the 295s?
    1lowlife likes this.
  4. May 6, 2022 at 3:24 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Coachbuilder shackles most certainly cut down on bed bounce tremendously.
    Aside from that they are an absolute work of art!!
  5. May 6, 2022 at 9:23 PM
    559trdTundra
    That’s what I herd, which one of the coachbuilder shackles would I need if I want to remain stock TRD pro height or maybe just 1” lift in the rear?
  6. May 8, 2022 at 7:51 AM
    Black
    You’ll want the +1 it gives just over a 1/2” of lift in the rear.
    I have the Falcon leveling system which gives the same height as the TRDPro up front.
    The Coachbuilder +1s give a very slight rake which is perfect in my book.
    jeffw6236 likes this.
  7. May 8, 2022 at 8:31 AM
    34KING18
    34KING18 New Member
    2020 Quicksand CrewMax Tundra
    @Black where did you get the yellow bulbs for the fog lights? Or is that a vinyl overlay? Looks very good
  8. May 8, 2022 at 12:09 PM
    Black
    Diode Dynamics SS3 Sports
    Great output and visibility.
    34KING18[QUOTED] likes this.
