Sequoia running warm
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by Agilityguy, Jun 4, 2024.
  1. Jun 4, 2024 at 5:33 PM
    Agilityguy
    Agilityguy [OP] New Member
    Mark
    2012 sequoia
    2012 Sequoia 5.7 runs warm. (gauge sits about 2/3 way towards H). Already replaced thermostat, fan clutch, water pump, and radiator. Temp goes down to normal when rpm runs at least 2000. Help!!
  2. Jun 6, 2024 at 4:00 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Do you have something like Scangage II or other obdii plug in tool?
    That would give you an actual temperature reading to confirm maybe the gage is just a bit off.
  3. Jun 6, 2024 at 4:54 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
  4. Jun 6, 2024 at 5:02 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    You really need something more accurate than the oem gage to know temps precisely. I use Torque Pro app ($5 for apple or android).
    But getting past that for a moment - the fact that temps drops once RPMs increase tell me you have air blockage somewhere between AC condensor and radiator and or fan clutch issues. So check in front of them - between them and behind. Next possibility is a weak fan clutch - test it - does it Roar for a minute on startup?
    I don't think its your problem but was radiator cap replaced also?
  5. Jun 15, 2024 at 7:25 AM
    Agilityguy
    Mark
    2012 sequoia
    Gauge is working correctly. Replaced cap as well. It's got me stumped. I can drive around the neighborhood and it's fine. I get on the freeway and by the time I've driven 10-15 miles it has slowly worked up to about 2/3 towards hot. I can cook it down by dropping from 6th to 5 th which raises the rpm.
    138thBatista likes this.
