Sequoia remote programming
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by Angel pino, Nov 11, 2021.
  1. Nov 11, 2021 at 9:12 PM
    Angel pino
    Angel pino [OP] New Member
    Angel
    Sequoia platinum 2011
    Saludos a todos, alguien me podrá orientar recientemente adquiri una toyota sequoia platinum 2011 y tengo una duda ya que en el dealer que la adquirí no me entreagaron un control remoto o mando a distancia, compre por Amazon el contro que le corresponde al vehiculo, he intentado programar segun los tutoriales de YouTube pero la sequoia no entra en modo de programacion, quiero saber que puedo hacer o si la unica opcion es llevarla a la toyota que segun me dicen es muy costosa la solucion, gracias espero orientacion por pate de los integrantes del foro, solo tengo 5 dias con ella y utilizo la llave para abrir y cerrar, quisiera utilizar el control, tengo entendido que este tipo de vehiculo enciende desde afuera con el control, gracias de nuevo
  2. Nov 11, 2021 at 9:19 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Greetings to all, someone will be able to guide me recently I acquired a toyota sequoia platinum 2011 and I have a question since the dealer that I acquired it did not give me a remote control or remote control, I bought the control that corresponds to the vehicle through Amazon, I have I tried to program according to the YouTube tutorials but the sequoia does not go into programming mode, I want to know what I can do or if the only option is to take it to the toyota that according to they tell me the solution is very expensive, thanks I hope for guidance from the members from the forum, I only have 5 days with it and I use the key to open and close, I would like to use the control, I understand that this type of vehicle starts from the outside with the control, thanks again
    NWPirate and Sunnier like this.
  3. Nov 11, 2021 at 9:20 PM
    Sunnier
    Sunny
    San Diego, CA
    Lo siento. Yo no sé.
  4. Nov 11, 2021 at 9:22 PM
    Sunnier
    Sunny
    San Diego, CA
    Bob, you’re awesome, translating this! I’m motivated to figure this out. I’ll phone a friend I know this happened to, and see if there’s an answer apart from the dealership.
    Bob[QUOTED] and NWPirate like this.
  5. Nov 11, 2021 at 9:26 PM
    Angel pino
    Angel
    Gracias, de vedad agradezco la ayuda
  6. Nov 12, 2021 at 7:29 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    ¡Bienvenidos de Alabama! ¡Alguien de aquí debería poder ayudarte!
