Sequoia head light questions
Discussion in '2nd Gen Tundras (2007-2013)' started by Jeffro22, Feb 29, 2020.
  1. Feb 29, 2020 at 5:28 AM
    Jeffro22
    Jeffro22 [OP] New Member
    2013 platinum crewmax 4x4
    Stock headlights have been bugging me and I keep trying to find a good replacement but Keep going back to the sequoia lights.
    Been looking at some used ones and see a lot listed with either broken or repaired tabs. Is that a big deal for the install? And do they seem to break easily?
    also- I see base and platinum models listed. Which ones are the better looking ones to go with? I have a platinum tundra but swapped out the grill to a rock warrior
  2. Feb 29, 2020 at 5:36 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I held out for lights with all tabs intact.
    The difference in trim is a black panel on the side & small thin piece around the side & under the lights & silver in those areas. I ended up with one of each and never see it. I Had forgotten about it until this post.
    Screen Shot 2019-08-21 at 7.40.11 AM.jpg Screen Shot 2019-08-21 at 7.40.02 AM.jpg
  3. Feb 29, 2020 at 7:17 AM
    Jeffro22
    Thanks! Yeah. I can’t really make out the difference. Trying to convince myself to spend that much money on headlights
  4. Feb 29, 2020 at 10:53 AM
    e30cabrio
    I love them.
  5. Feb 29, 2020 at 11:17 AM
    TheBeast The Beach
    They are very nice but $$$. The new Morimoto XB headlights are a great choice as well for almost half the cost.
  6. Feb 29, 2020 at 11:44 AM
    SouthWestGA
    SouthWestGA New Member
    Also there are Alpharex lights which are nice. They are about $350 a set. I have those in my wife’s Sequoia
    TheBeast and omgboost like this.
  7. Feb 29, 2020 at 12:04 PM
    e30cabrio
    Aren't the Morimotos 900? I paid 1200 and change for mine (including the harness), they need no set up, no adjustment and are OEM (the harness is p&p and looks OEM).
    I had 400.00 aftermarkets I had to deal with adjusting, the neon tube was dim and they were just not right.
    If you take your time you can find the headlights on eBay for under 600 each.
  8. Feb 29, 2020 at 1:11 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    They are expensive, but one of my favorite upgrades, and I’ve done a lot over the last couple years.
  9. Feb 29, 2020 at 4:53 PM
    TheBeast The Beach
    best if you can find used but still adding harness plus body panels and painted to match truck color add up.
    morimotos can be found for 760 ish when shops have sales.
    tnbndr likes this.
  10. Feb 29, 2020 at 5:31 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Got these off of eBay from user headlampsamerica for $440 per light. They are refurbished but in like new condition. U/filthytundra and I both got them and had a very good experience. Comparatively any aftermarket light really doesn’t compare to fit/finish and drastically changing/updating the second gen IMO
  11. Feb 29, 2020 at 5:54 PM
    Jeffro22
    I saw those but wasn’t sure if it was a complete light. Is it plug and play?
  12. Feb 29, 2020 at 6:36 PM
    Mattyc
    Matthew
    NY
    Not stock
    You need the harness from xrunnerdude67 from on here and also the sequoia filler plates for under the lights. Then it’s plug and play. 30 minute install. Works and looks like it came from the factory.
  13. Feb 29, 2020 at 7:34 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Grill information por favor.
    Do you have a daytime pic of it?
    Maxi13 likes this.
  14. Feb 29, 2020 at 9:36 PM
    airosey
    East TN
    It’s made by Enve Grilles
  15. Feb 29, 2020 at 10:05 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Damn!! Is that your ride?!
    airosey[QUOTED] likes this.
  16. Mar 1, 2020 at 3:20 AM
    airosey
    East TN
    It is!
    Y0TA PR0[QUOTED] likes this.
  17. Mar 1, 2020 at 8:33 AM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    That’s a f**king sweet ride! :muscleflexing::muscleflexing::thumbsup:
  18. Mar 9, 2020 at 4:54 PM
    Jeffro22
    Got everything ordered. Need to paint my fender extensions and then hopefully do the install
  19. Apr 13, 2020 at 6:54 AM
    Jeffro22
    got it installed. Pretty happy with the upgrade. As most already know, the harness from xrunnerdude is first class. Very nice work.
    Got my driver side "refurbished " headlight from headlights america off Ebay (Got back $50 bc one of tabs broke in shipping), and got lucky on a low priced passenger side from a private seller that looks really good.
    looks like this upgrade is getting a little more "affordable" -Still a lot of money
    I am at $765 for both headlights, $110 for harness, $99.27 for fender extensions, and $8 in color match paint
    TheBeast likes this.
  20. Apr 13, 2020 at 8:09 AM
    ccress83
    ccress83 Be A Good Human
    Colin
    Cleveland Ohio
    2011 Tundra CM TRD Off-Road Limited
    AFE Dry Drop in Filter, Morimoto XB LED Fogs , LED Taillights, Morimoto D2S retro w/profile HI-Lens LED Brights, 3/1 LRO Level, Dirty Deeds 8', TRD Rear Sway Bar,
    I wish someone would make a regular light shaped like the new seqouias so you had the option to retro fit. I would be on board with that.
  21. Apr 13, 2020 at 9:36 AM
    TheBeast The Beach
    the new Morimotos XB when on sale ($720 ish shipped) are a great alternative to the Sequoias imo. I went with them instead of sequoias.
    Plus 5 year warranty.
  22. Apr 14, 2020 at 5:27 PM
    Maxi13
    Maxi13 GuttenTight
    Montucky
    2020 Cement Sr5 TRD OR
    Nudding yet
    This is a great mod! My filler panels are ready so plan to do the install this weekend. I also bought refurbished off ebay and they look great.
    I bought a platinum by mistake so have one for sale, wanted the non chrome but as stated here it's a very small difference and they both look great.
    Will post photos when done!
  23. Apr 14, 2020 at 7:40 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    I am another vote for OEM sequoia LED.
    I accidentally “back doored” my way into a good price from a light vendor. I applied a coupon code that was not supposed to work but it did. They quickly called me and offered me a discount but not as much as the original coupon was for but a deal non the less.
    I painted my own fillers and grill and got the harness from xrunnerdude67 and I was good to go.
    morimotos are nice and hopefully they worked out the kinks that one user was having in here when he got them very early, maybe he was doing R&D for them but he got a bad leak in one during his first rain storm
  24. Apr 14, 2020 at 7:47 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
  25. Apr 15, 2020 at 6:31 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Damn, they look so good.... Which vendor did you use if you don't mind me asking?
  26. May 27, 2020 at 1:46 PM
    GTABurnout
    GTABurnout New Member
    Whats the preferred vendor for the filler panel?
  27. May 27, 2020 at 2:22 PM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    Now that is one Bad-Ass Tundra! Good on You Sir!
  28. May 27, 2020 at 2:56 PM
    ZenkiS14
    ZenkiS14 New Member
    2012 Tundra TRD Rock Warrior
    I am working through mine right now. Truck is getting the front end fixed, and doing the 18+ conversion in the process. Just need my Xrunnerdude67 harness, and I should be in good shape! Hoping to have it all done by next week.
  29. May 27, 2020 at 5:08 PM
    Jeffro22
    I got mine from sparks Toyota since I was able to pick up. I would check with Roman though
