Sensors
Discussion in '2nd Gen Tundras (2007-2013)' started by Sheley5160, Aug 6, 2018.
  1. Aug 6, 2018 at 11:24 AM
    Sheley5160
    Sheley5160 [OP] New Member
    Elizabeth
    2007 Toyota Tundra
    None
    Sensor that reads the oxygen intake when it initially starts up. Sorry lost the piece of paper with the info from diagnosis. Can someone help please. Need to replace it. Thanks so very much.
  2. Aug 6, 2018 at 12:06 PM
    koditten
    koditten New Member
    O2 sensor? There are more than 1. Who did the diagnosis?
  3. Aug 6, 2018 at 12:38 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That description is a bit too vague, unfortunately. I’m thinking MAF (Mass Air Flow) sensor because you said “initial start-up”, a condition where Air/Fuel ratio sensors (or O2 sensors) are not used, as they need to heat up to give a reading.
    If you can’t find that paper, maybe have the code(s) read again, and post the “P0_ _ _” code number here as well.
    koditten and Grumpy Uncle like this.
  4. Aug 6, 2018 at 12:42 PM
    Grumpy Uncle
    Pat
    CO
    2016 Black CM Tundra TRD Off Road
    I was thinking of the MAF as well. I have sloth like reflexes!
