Seller Says Lebra won't fit my DC 2006
Discussion in '1st Gen Tundras (2000-2006)' started by 2truckornot2truck, Aug 23, 2020.
  1. Aug 23, 2020 at 8:39 PM
    2truckornot2truck
    2truckornot2truck [OP] Aspiring Truck Guy
    Felix
    TX
    2006 Tundra DC SR5 V8
    None yet! Does steering wheel cover count? :)
    Hi Folks,
    Do you think this Lebra Front End Mask Cover Bra will fit? the Ebay site says yes, but the seller says no, so you get the following conflicting info for my truck for this item:
    I corresponded with Covercraft and told them my model and submodel, DC, everything. They said the one below would fit: It has the same part number as the ebay seller's:
    5588901a (The seller said he just adds the "a" for internal purposes. )
    From Shopping cart at Covercraft:
    LEBRA CUSTOM FRONT END COVER
    $116.00
    Part #: 55889-01
    For Vehicle: 2006 Toyota Tundra SR5
    Option: Access cab with flares
    Color: Black
    Quantity: 1
    Total Price: $116.00
    But the ebay seller insisted it is not for double cabs, which he calls extended. He has a nice deal on these. Does anyone have part 55889-01 on their 2006 DC? I am attaching the instructions from Covercraft for this cover. Could ebay seller be right and even if I order from Covercraft I am going to have issues? Since his price has a nice discount on it, was hoping to take advantage however - but not if it's won't fit.
    Here is my discussion with the seller on ebay in purple (in reverse chronological order)
    New message from: carcoverkingdom [​IMG](21,636[​IMG])
    Seller: the a is just a add on letter we use internally for our purposes. thans Lee
    Reply
    Your previous message
    Me: Darn. Ok your part number matches theirs : 55889-01. Except you have a “A” on yours. Let me know if you find out otherwise about it fitting the 2006 Tundra SR5 double cab.
    I take it yours has both top and bottom pieces as it says it’s a 2 piece. And in new condition. It’s a good buy seemingly.
    carcoverkingdom:
    Seller: i google this vehicle and believe the double is the extended cab. thanks Lee
    As far as I know there are 3 cabs: standard, acces, and double for the 2006. Only the double has 4 full size doors. Then they also made a step side variant. But mine is the regular fleet size bed.
    carcoverkingdom:
    thought double cab would be extended cab is that right?
    Me: Ok thanks. Yes it shows it up above. Sending screenshot.
    carcoverkingdom:
    Seller: description would be correct as it does not fit the double cab models. where do you see this in the look up as i do not see double cab listing. thanks Lee
    Me: Hello for this item
    Lebra Front End Mask Cover Bra Fits Toyota Tundra 2003-2006 03 04 05 06
    eBay days it fits my 2006 double cab SR5 Tundra. However the description says it will not.
    Which is correct? Thanks.
  2. Aug 23, 2020 at 9:12 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    That cover likely fits the access cab and regular cab trucks. The double cabs are a totally different beast with a taller body so the cover will not fit if it says it fits 03, because 03 never had double cabs.
    2truckornot2truck[OP] likes this.
  3. Aug 23, 2020 at 10:07 PM
    2truckornot2truck
    Felix
    TX
    Interesting! So the guy could be right then, and covercraft site incorrect. It’s confusing. Didn’t realize DC had a different size front end.
