Self Installed 3M paint protection kit
Discussion in '3rd Gen Tundras (2022+)' started by DuellChet, Sep 2, 2023.
  1. Sep 2, 2023 at 7:53 PM
    DuellChet
    DuellChet [OP] New Member
    2023 Tundra Limited
    Leer XL Cap
  2. Sep 2, 2023 at 8:12 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    The cost is the skilled labor - prep work, install and curing. If you got the clean space to do it and consider your time free then you could technically fuck it up a few times before it was a waste of time.
    Post the part number or source of the kit!
    Blufin likes this.
  3. Sep 2, 2023 at 8:34 PM
    DuellChet
    2023 Tundra Limited
    Leer XL Cap
    Sixty9Four20 likes this.
  4. Sep 3, 2023 at 5:44 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    I was tempted to do it myself because the stealership wanted to charge 2K and also disclosed it won't be perfect...? Really 2K for something your not positive you can do it properly? Ya, ok next....
    I ended up getting it professionally done with Xpel PPF entire front end headlights and all with 2' on the hood and back window w/ 20% ceramic for $1,400.
    Well worth it, one and done.
    The key component next to being good at it is the environment,it has to be like a "clean room" no dust negative pressure room I mean fcking spotless.
  5. Sep 4, 2023 at 4:08 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    I watched someone install on a completely flat smooth hood and realized it requires experience. When you consider all the contours on our hoods I wouldn’t try that as a first experience.
