Security Feature
Discussion in '1st Gen Tundras (2000-2006)' started by Joseph75, Apr 26, 2025.
  1. Apr 26, 2025 at 12:13 PM
    Joseph75
    Joseph75 [OP] New Member
    J
    2005 Tundra
    Does anyone have a security feature on a 1st Gen where you have to flash the high beams to start the truck? I have this feature which leads to the 2nd part of this. I recently replaced my burned out headlight with led headlights. The led lights turn on and both low and high beams work but my truck would not start because of the aforementioned feature. So I had to replace the driver side light with an incandescent bulb to get the truck to start but I would like to use led lights. Any suggestions?
  2. Apr 26, 2025 at 12:27 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  3. Apr 27, 2025 at 5:56 AM
    Joseph75
    J
    2005 Tundra
    Thank you. I will give that item a try.
  4. Apr 27, 2025 at 7:14 AM
    Yes. One of our Texas members ( @VR6T ) has that, alarm that was tied into the headlight. Aftermarket. He took a vacation (temp ban) and hasn’t posted since. I dunno if he ever tackled it.
  5. Apr 27, 2025 at 7:16 AM
    And if using LED lights, be sure to check the megathread/community info thread for important notes about making that upgrade, if you’re not already aware.
  6. Apr 27, 2025 at 7:41 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    2001 Tundra SR5 Access Cab TRD 4.7
