Replacing the seat belt retractor
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Apr 25, 2019.
  1. Apr 25, 2019 at 5:37 AM
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    So I looked around the forums for a bit and couldn't find anything to help me. I would like to replace the seat belt retractor on both driver and passenger. Neither of them seem to retract at all anymore.
    This is obviously a safety concern, and I need to do this right because I know how important seat belts are. While I'm at it I may just replace my belts too since it'd probably be easier than cleaning them.
    Any ideas, info, or recommendations?
  2. Apr 25, 2019 at 5:41 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  3. Apr 25, 2019 at 5:52 AM
    Tundra2
    Noah
    Western Kentucky
    I checked genuine Toyota parts .com, and searched for seat belts. They sell everything. Clips, covers, bolts, nuts... just give me a price for the whole assembly covers, clips, and bolts included. Ridiculous.
  4. Apr 25, 2019 at 6:16 AM
    Professional Hand Model
    Hand Protectors
    Try an easy fix first which worked on mine.
    Clean the entire belt first with degreaser. Purchase PB Blaster Silicone Spray with Teflon ($7) and SOAK the seat belt down the entire length.
    Allow to dry as the Silicone and Teflon work their magic AFTER drying.
    You can also shave a little bit of the plastic from between the seatbelt glide (above your ear) to remove the close tolerance. What happens is the fibers catch there and cause (at least in my case) the problem.
    hammeron, 02goes and Tundra2[OP] like this.
  5. Apr 25, 2019 at 6:40 AM
    Tundra2
    Noah
    Western Kentucky
    I'll have to try that. Thanks fred. I will update with results sometime in the next 5-10 business days :rofl:
  6. Apr 25, 2019 at 8:51 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I can check to see if I can get you some, if you will shoot me your VIN. A lot of those are hazmat and I can't ship them, though.
  7. Apr 27, 2019 at 7:38 AM
    Tundra2
    Noah
    Western Kentucky
    I will get that vin to you in a DM.
  8. Apr 27, 2019 at 7:42 AM
    Tundra2
    Noah
    Western Kentucky
    I got that PB blaster as you suggested, and some Emery cloth from work. I will try this first. Hopefully all goes well.
  9. Apr 27, 2019 at 11:03 AM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    You might also take the covers off the retract mechanism and see if you can lubricate it. If I recall, that’s what I did with my 2001.
  10. Apr 27, 2019 at 11:27 AM
    Hand Protectors
    I did that as well. Good call. Used the same Silicone Spray. Loaded it up with the belt pulled all the way out. Let it retract and repeat with another soaking.
    Tundra2[OP] likes this.
  11. Apr 27, 2019 at 4:24 PM
    Aerindel
    Aerindel New Member
    Montana
    I have the same problem. Thanks for the tips.
  12. May 16, 2019 at 6:18 PM
    oldschoolpl510
    oldschoolpl510 New Member
    Any tips on the buckle? My seatbelt light comes on. When I bottom out the seatbelt in the buckle it goes out. A new one is not available in gray anymore I'm told.
  13. Jun 11, 2019 at 10:53 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    If seen a youtubes video where the guy just sanded the opening on the top plastic part and it works just fine now. Imma try it tommorow
