Sealing cargo box
Discussion in '3rd Gen Tundras (2022+)' started by Red2022, Jan 12, 2026.
  1. Jan 12, 2026 at 5:08 PM
    Red2022
    Red2022 [OP] New Member
    Sherwyn
    2022 Red Platinum
    anyone find a good way to seal dust out of the cargo box when using retractable or similar cover?
  2. Jan 13, 2026 at 6:14 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
  3. Jan 13, 2026 at 6:20 AM
    User1776
    User1776 New Member
    26 Lunar SR5 TRDOR TRD Lift
  4. Jan 13, 2026 at 6:52 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    If you're talking about sealing dust from the bed with a tonneau cover, I haven't found a solution, yet. It's been a pet peeve of mine for decades. All the tailgate gasket kits that I've tried only help a little.
    I've never understood why manufactures can't seal the tailgates at least as well as the side doors.
    User1776 likes this.
  5. Jan 13, 2026 at 7:39 AM
    Red2022
    Sherwyn
    2022 Red Platinum
    Yes that is a long term issue for me and looking for a better way. I think the Tundra is sealed a little better than the others but only marginally in the wheel well area. With the tail gate pivots the seals just don't stay in place. It could be worse, the GM multiflip thing doesn't even hold water out at the car wash and double the amount of joint area.
  6. Jan 13, 2026 at 5:41 PM
    TFTJ
    TFTJ New Member
  7. Jan 13, 2026 at 6:48 PM
    ElJefe77
    ElJefe77 New Member
    22 SR5 Premium
    I don’t but I have it in my Amazon saved for later based on positive reviews on this site. People say it pretty much seals it up.
  8. Jan 14, 2026 at 8:18 AM
    Matt2015Tundra
    2023 1794 CrewMax
    That's the gasket kit I'm currently using. It makes very little difference on dust, or water intrusion, and after about 1-1/2 years they are falling off. I wouldn't recommend.
  9. Jan 14, 2026 at 11:38 AM
    TFTJ
    TFTJ New Member
    Thanks.
    My biggest issue is water getting in through the tailgate gaps. Need to figure something out
  10. Jan 14, 2026 at 12:06 PM
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    I ended up getting one a bit bigger for the bottom of the tailgate. The one pictured in the kit still let dust in the bottom of mine. So far so good on the “fatter” one.
  11. Jan 14, 2026 at 12:59 PM
    DRP
    DRP .
    Dave
    MN
    Do you possibly have a link to the "fatter" one? Thanks.
  12. Jan 14, 2026 at 1:31 PM
    donia
    donia New Member
    Miss’ippi
    Turns out it is the bigger one in the ESI kit in a 6’ length. https://extrudedsolutions.com/products/ultimate-tailgate-seal-large-6ft
    Apparently I positioned it lower than I should have, the first time. I removed the old one and put the tape strip higher, this time, and the tailgate lip presses into it better to seal out dust. The side gaps need to be done, too, of course.
  13. Jan 14, 2026 at 2:48 PM
    DRP
    DRP .
    Dave
    MN
    Thanks. I have the seals that others have mentioned previously but knew when I was installing them they probably wouldn't last very long as the sticky bits didn't seem very sticky. If I install something else I'll use some marine sealant to enhance the stickum. It's not affected by water and sticks like crazy.
    https://www.seaviewglobal.com/produ...Tptkhp_sAK_IboJc5UXMv_CLFMM351H3zw9dbTEiWLFVk
  14. Jan 14, 2026 at 3:32 PM
    donia
    donia New Member
    Miss’ippi
    When I initially installed them, I thought the same, but if you press them on well and let them cure according to instructions they hold well. I was surprised how well when removing it to replace it. There’s about a quarter inch of lip sticking up across the bed, now, to get the bulb end far enough up to get good contact with the lip on the bottom of the tailgate (when closed).
    DRP likes this.
  15. Jan 23, 2026 at 6:08 PM
    Rat Fink
    Rat Fink New Member
    Alabama
    25 Silver 1794
    I previously used the ROK Block tailgate seal on my 2014 Tundra and was very pleased. All but stopped dust or anything falling in the gap between bed and tailgate. The gap was much wider than on the third gen though. If you follow install instructions it stuck like crazy! Haven't done anything on this one though. Just been living with the dust so far.
    cartage1 likes this.
