SDHQ's 2014+ Tundra Behind-The-Grille LED Light Bar Mount
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Mar 26, 2018.
  1. Mar 26, 2018 at 10:43 AM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    Hey guys! Rolling out another awesome product! We have had these available for the last month or so but I have been slow on getting it onto the forums! Below, will show some on the features of the mount along with fitment, etc. We have fitted these with all the OEM grilles available for the Tundras as of current.
    FEATURES:
    • 3D CAD Designed for a OEM quality fit and finish
    • Bolts directly to the core support
    • 1/8" thick steel plate construction for durability
    • Stainless stell hardware provided for ultimate corrosion resistance
    • Designed for Baja Designs: S8 and Onx6 series light bars
    • Rigid SR series will fit in S8 locations
    • Works with SDHQ winch mount
    • Works with TRD supercharger and Magnuson supercharger (minor modification needed for Magnuson)
    • Difficulty of installation: Medium
    • Install Time: Approx. 2 hours
    • Cutting only required with the TRD Pro Grille when mount S8 "B" location
    • Some lighting options will require center support (SDHQ-53-1110-G3, sold separately)
    VEHICLE FITMENT: (Fitment is based on the year and the grille style being used, NOT on the trucks trim package)
    2014-2017:
    - Does not fit Platinum or Limited Edition
    - TRD Pro Grille: Fits S8 up top (minor trimming required) / Fits either S8 or OnX6 in lower location. Note: S8 in the top and OnX6 in the lower both require SDHQ Center Support Kit. S8 in lower position does not.
    -SR/SR5/1794 Baja Designs S8 or equivalent only. Does NOT require Center Support Kit.
    2018:
    - SR/SR5 requires center support when installing OnX6 when installing a S8 or equalivent in lower location the center support kit is not required
    - Limited/1794 Editions do not not require SDHQ Center Support Kit
    CENTER SUPPORT:
    - Relocates horns and latch spring - Needed for TRD Pro Top location
    - Slim Profile - Needed for Onx6 and equivalent light bars
    - 3D CAD Designed for OEM quality fit and finish. Bolts directly to core support.
    - 14g thick steel plate construction for durability
    - Stainless steel hardware provided for ultimate corrosion resistance
    PRODUCT IMAGES:
    http://store.sdhqoffroad.com/14-18toyotatundrasdhqbuiltbehindthegrilleledlightbarmount.aspx
    4x4_Angel, BlueBottle, Newm and 3 others like this.
  2. Mar 26, 2018 at 10:54 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Have you guys done any figment testing on 2nd gens?
    831Tun likes this.
  3. Mar 26, 2018 at 11:00 AM
    sdhq_offroad
    GILBERT, AZ
    None have been done. But the 2nd gens have the transmission cooler on the passenger side behind the grille so it is doubtful that it will fit. 2nd gen mounts/test fitment are on schedule but we do have some items in front of them.
    zcarpenter92 likes this.
  4. Mar 26, 2018 at 11:06 AM
    Sandbox
    Sandbox New Member
    Canada
    2017 White TRD Pro Crewmax
    ughhhh... so much want... so little money
    4x4_Angel and Baja Mike like this.
  5. Mar 26, 2018 at 11:12 AM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Perfect fitment behind that TRD pro grille! Awesome!
    sdhq_offroad[OP] likes this.
  6. Mar 26, 2018 at 11:30 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  7. Mar 26, 2018 at 11:37 AM
  8. Mar 26, 2018 at 4:00 PM
    boloson
    boloson New Member
    Just curious since I have a 14 platinum. Why would it not fit a platinum? Because of the grill? What if I got the pro grill for my platinum?
  9. Mar 26, 2018 at 4:06 PM
    sdhq_offroad
    GILBERT, AZ
    Its not that it doesn't fit the platinum, it is that the platinum grille doesn't allow for enough light to pass through the grille. Swapping to a pro grille would solve that issue.
    T-Rex266 likes this.
  10. Mar 26, 2018 at 4:19 PM
    boloson
    boloson New Member
    Ok just wanted to make sure thanks
  11. Mar 26, 2018 at 4:27 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Any pics behind the 18 honeycomb grille? Just not sure if lights work behind it, and can’t find anyone that tried it.
  12. Mar 26, 2018 at 5:06 PM
    sdhq_offroad
    GILBERT, AZ
    2018 Honeycomb:
    _Icsj5K7ZnCddHYO-GIrnEYeewNL2dyC-J5Unom9_4f2290847b8c944cf42a73d95d60eacbf98ae001.jpg
    PyLf9bM-Ft6lJteFRetyLOU_EK5y-0hYxiJY6Z1X_fbe41de02ff34230c541847062caa40ccac4e0f2.jpg
    0hSOoLniG8xzSLMrilFUKTGAVJVZlt30Aea7IxM8_3b71fe1255cb9cead3488425ab35d11780da44df.jpg
    2018 Limited:
    WXXxgCYih9JqTC11uhG23ZMw9pETCKTBt2zWkquv_c449b07fc11363a2425cf434008a7a04f3f4b0f2.jpg
    O83xyvM6lpYjs24ALE39iQilz2VkjfTJiHApAYzv_9192d801b636fbcfa4f5b8e357d382ce89ab3df7.jpg
    14-17 SR5
    - Working on non stretched out pictures
  13. Apr 16, 2018 at 10:26 PM
    fullofbs
    fullofbs Project SnowFlake
    Will the rigid e series lights fit?
  14. Jun 20, 2018 at 9:42 PM
    AZadventurer
    AZadventurer New Member
    Michael
    2018 Tundra Limited Cement
    Flowmaster Outlaw exhaust
    I am a bit late to this chat. But curious if on the pictures above, does the center support bracket have a mount for the TSS sensor? I am thinking that is what I am seeing in the 2018 Limited pictures above. Looks like the sensor is there without the Toyota emblem.
  15. Jun 20, 2018 at 9:46 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Same!
  16. Jun 21, 2018 at 8:01 AM
    sdhq_offroad
    GILBERT, AZ
    Our behind the grille mounts do work with the TSS sensor. There is no relocation bracket needed.
    4x4_Angel likes this.
  17. Jun 21, 2018 at 8:36 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    Any issues with radiator airflow? That's a lot of closed up grill space.
  18. Jun 21, 2018 at 8:42 AM
    sdhq_offroad
    GILBERT, AZ
    Not the slightest. Not even out here in Arizona during the summer. It may look like a lot of frontage, but there is quite a gap for airflow in front of lights to go up and around, etc. We had our scanner plugged in monitoring temps and saw a difference of +/- 5 degrees over a few hours of driving and up hill climbs.
  19. Oct 25, 2018 at 2:33 AM
    Matthewkort
    Matthewkort New Member
    2 questions.
    1. Would a rigid radiance fit on the too of the PRO grilll... I understand light would be less due to the size being a little slim vs the bottom but on a radiance the optics are in the middle vs the actual E series bars.. so had me thinking, OR is the E series bars just to big to fit so thats the reson for an SR..
    2. Does SDHQ have any codes with this page, or any other forums etc?
    Thanks for the time to reply, first question has been in my mind for a while
  20. Oct 25, 2018 at 8:27 AM
    sdhq_offroad
    GILBERT, AZ
    The housing of the the E-Series is too large clearance wise which is why that is designed for the SR/single row series. Feel free to PM me regarding any questions or pricing.
    Matthewkort[QUOTED] likes this.
  21. Apr 18, 2022 at 9:24 AM
    klfrnia22
    klfrnia22 New Member
    Daniel
    Hampton, VA
    2019 Cavalry Blue SR5 CM
    I just got this for my 19 SR5 with an S8 white spot and S8 amber driving combo. Which would you recommend to go on the top/bottom? I was thinking the amber driving combo on the bottom and white spot on top to allow for a better light throw in each application.
    Baja Designs likes this.
  22. Apr 20, 2022 at 9:02 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Good Morning klfrnia22,
    I agree with your conclusion, the best option is to put the amber down low/lower because it will cut through dust, snow, etc.. better than a clear lens. Due to the amber also being a combo it will function better in that location. The spot being higher will minimize potential glare and other reflections than the amber will.
    SoJersey and klfrnia22[QUOTED] like this.
