SDHQ 2007+ Tundra Hidden Bedside Support System
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Jan 27, 2017.
  1. Jan 27, 2017 at 1:57 PM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    During extreme off road use factory and fiberglass bed sides are prone to spreading apart. To combat this, SDHQ has designed a unique system that is completely hidden and does not hinder bed space. We use a heimed adjustment rod to pull the bed sides back into proper spec. Keeping true to SDHQ's highest standard of fit and finish this product is a combination of black powder coated mild steel and high grade T6061 aluminum that will withstand the test of time no matter the condition.
    Key Features:
    • Supports factory bedsides, especially if there is no tailgate
    • Completely hidden
    • Prevents premature fatigue and cracks
    • Does not obstruct any bed space
    • Fully adjustable
    • Can even help is bedside is already bent
    • Perfect for trucks with fiberglass bedsides
    What is included:
    • (2) Main Uprights
    • (2) Upper Bolt Pucks
    • (5) Lower Pivot Brackets
    • (5) Lower Mounts
    • (2) Connecting Rods
    • (2) Right Hand Clevis
    • (2) Left Hand Heims
    • (2) Fender Support Replacements
    • (2) Hole Drilling Templates
    VoKjAQq5mrP7sML7-Yjp8hwkZl8zqXzHRiUyEv_V_0df352e6618447707efd1ff72542bd285b2af755.jpg
    Here are a few pictures to show how much bed flex the Tundras actually get.
    Here is a picture of the lower adjustment system
    PM for pricing
    https://sdhqoffroad.com/products/07-current-toyota-tundra-sdhq-built-hidden-bedside-support-system
  2. Mar 23, 2017 at 2:44 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Interested in these. I assume by making the back end more solid it will also quite down the noise of the bed wiggling when going down rough roads or off-road.
  3. Mar 23, 2017 at 3:32 PM
    sdhq_offroad
    GILBERT, AZ
    Definitely helps with the bed looking like a piece of jello as it goes down a fire road, etc. Besides being adjustable, the best part is that it is all hidden!
    jimbrophotodotcom and T-Rex266 like this.
  4. Mar 23, 2017 at 3:33 PM
  5. Mar 31, 2017 at 6:01 AM
    csuviper
    Broomfield, CO
  6. Mar 31, 2017 at 10:20 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Let me know how it goes and how much it helps! I may or may not need these. I'm still not sure how your bed can bend that much inward like in the picture, if the tailgate is closed, but I did remove the OEM bedside supports near the wheel well so my bedsides wobble in the wind a bit. I'd also love to see pics of how the kit mounts to the bedside itself and not just the frame.
  7. Mar 31, 2017 at 3:25 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    I'm curious as well.
  8. Aug 18, 2017 at 12:55 PM
    sdhq_offroad
    GILBERT, AZ
  9. Mar 2, 2018 at 7:45 AM
    sdhq_offroad
    GILBERT, AZ
    Just finished packaging a fresh batch of these!
  10. Mar 2, 2018 at 8:00 AM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    hmm. can you install that with decked drawers already in the bed? i couldn't tell from the instructions if the drawers would be in the way or not.
  11. Mar 2, 2018 at 8:03 AM
    csuviper
    Broomfield, CO
    Yes you could. Only need to pull out the tail lights to install.
  12. Mar 2, 2018 at 8:04 AM
    smslavin
    Hudson Valley
    Some stuff
    sweet. thanks.
    sdhq_offroad[OP] likes this.
  13. Mar 2, 2018 at 8:46 AM
    Sunnier
    Sunny
    San Diego, CA
    Good morning, Brian! Did you install this system last year? If so, can you give us a report about the ease of installation, and any benefits you've observed...? Or post a link if I missed a review you already did. Thanks!
  14. Mar 2, 2018 at 12:55 PM
    csuviper
    Broomfield, CO
  15. Mar 2, 2018 at 1:28 PM
    Sunnier
    Sunny
    San Diego, CA
  16. Jul 13, 2018 at 10:59 AM
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    2016 MGM SR5 4x4 Crewmax
    TC UCA's, King 2.5, Ex-Pelf Bumpers and skids, TRD Pro Grill, 2018 Lights, BD Fogs, FRAC
    Are these bedside supports still available? I cant find them @sdhq_offroad
  17. Jul 13, 2018 at 11:05 AM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    Nice product!
  18. Jul 13, 2018 at 11:08 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
  19. Jul 13, 2018 at 1:07 PM
    sdhq_offroad
    GILBERT, AZ
    Getting them up on the new website as we speak. I will post the link here shortly.
    HornFrog[QUOTED] likes this.
  20. Jul 13, 2018 at 1:12 PM
    sdhq_offroad
    GILBERT, AZ
  21. Jul 13, 2018 at 2:27 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Have you tested these on a vehicle vs a stock bed to see what kind of forces it is able to withstand? I assume that the underlying concept is that the cam/turnbuckle thing pushes one side of the "lever" out which forces the top part IN... In practical terms though, how effective is it? Have you put one on a bed that is already flexed out and seen if you can generate enough force to get it back in at all?
  22. Jul 13, 2018 at 2:36 PM
    sdhq_offroad
    GILBERT, AZ
    The stock bed is very flimsy towards the tail portion so yes it is effective. We were able to get over 3/4" in each direction of correction for a bent bed but it will also hold the stock bed firm in place.
    Sunnier likes this.
  23. Jul 13, 2018 at 2:38 PM
    DividedSky
    Jeff
    Thanks... that's exactly the kind of feedback I was looking for.
    So in other words, I should go put a high-lift between the two bed-sides, push them apart and then tell the wife that I need these to "CORRECT" the issue!!
  24. Jan 6, 2020 at 10:09 AM
    Swatdude1
    Swatdude1 New Member
    Phoenix, AZ
    2008 Tundra Crewmax Limited TRD
    Icon 3.0 Coilover Stage 2, SDHQ Traction Bars, Nitro 4.88 gears, AlphaRex Headlights, Katskin Leather, Method 17" Vex with 35"Toyo M/Ts, Eaton Rear Locker, N-Fab MRDS
    Does the bedside support system do anything to increase load carrying ability or rigidity of the bed rails when it comes to camper shells? I put a deposit on a Vagabond Nomad, which is about 380-400 lbs and has a significant cantilever over the cab. Just curious if these would add additional strength to help support the camper during offroad use? Would obviously still be running with the tailgate on and closed.
