ScanGauge II users for monitoring transmission temperature
Discussion in 'Towing & Hauling' started by smstoyloy, Jun 21, 2020.
  1. Jun 21, 2020 at 6:31 PM
    smstoyloy
    smstoyloy [OP] New Member
    Stephen
    2020 Cement Tundra SR5 TRD OR 4x4
    None Yet!
    Based on comments I read either here or on AS forum I purchased a ScanGauge II which connects to the truck diagnostics plug. Seems ScanGauge has many predefined things it monitors, but to set up for transmission and engine oil and I think water temps you have to program in some “XGauge” codes relative to your vehicle. I went to their website and honestly cannot make “heads nor tails” about their referenced codes. Of course, I’ll send them email tomorrow seekeing help. Have any of you other recent model Tundra SR5 Tow Package owners had to go to their CS to figure out which codes to use? Thx
  2. Jun 21, 2020 at 6:34 PM
    I have one in my 2013 but never messed with the codes. Their newest firmware has codes for tire pressure monitoring now.
  3. Jun 22, 2020 at 6:04 AM
    Johnders2586
    Johnders2586 New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Interested in this as well. I want to get one of these, but want to make sure I can monitor trans temps..
  4. Jun 22, 2020 at 7:32 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Try these codes for transmission temperatures, worked on my 2015 Tacoma and 2016 and 2018 Tundras
    Transmission Temperature 1 - pan
    TXD: 07E02182
    RXF: 046105820000
    RXD: 2808
    MTH: 00090005FFD8
    NAM: TF1
    Transmission Temperature 2 - Torque Converter output
    TXD: 07E02182
    RXF: 046105820000
    RXD: 3808
    MTH: 00090005FFD8
    NAM: TF2
    Oey12, a_double, SpooledReel and 2 others like this.
  5. Jun 22, 2020 at 9:13 AM
    Is there a "simple" way to program the codes? I have never done it on mine. Thanks.
  6. Jun 22, 2020 at 11:07 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    You can look it up in user manual or the online user manual, I would have cut and pasted it but my internet is ultra slow because of Covid users around me.
  7. Jun 22, 2020 at 11:15 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Can it do tire pressure and AT temps at the same time? OBD Fusion for iOS can't as they are on different communication networks.
  8. Jun 22, 2020 at 1:18 PM
    smstoyloy
    Stephen
    None Yet!
    The ScanGauge allows 4 different measurements in the window at one time.
  9. Jun 22, 2020 at 1:20 PM
    smstoyloy
    Stephen
    None Yet!
    Thanks, exactly what I am looking for. The tech support at ScanGauge said they did not know for my specific truck (although I told them the specifics) and that I would have to try programming each one for the 2010+ Toyotas and see which worked.
  10. Jun 24, 2020 at 6:51 AM
    jstchilln
    jstchilln New Member
    Larry
    Eastern Kansas
    2017 Tundra 4X4 SR5 Double Cab / TRD Off road Package
    TRD Pro Grille
    I was at a loss at first but watched the video's and used the codes posted here on the forum and now I'm watching my trans temps. If you screw it up just reset and do it again.
  11. Jun 24, 2020 at 2:44 PM
    Johnders2586
    Questions for you guys
    So I used these code an they seemed to work okay.. what should I expect for an initial reading? One looks normal on a cold start at about 80 degrees? It's hot her today.. but the other tf1 looks odd is it saying -39? Is that right? What would that be??IMG_20200624_173410.jpg
    I tried the 4 variation s they list online for 2010 plus but the only one that works is the 2808 or the "TF2" listed above
  12. Jun 24, 2020 at 3:28 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    at startup, transmission pan and transmission torque converter and water temperature should all be the same as local outside temperature, my 2018 does. I monitor both transmission temps and engine water temp on my ScanGuageII, so its easy to check. You need to check your inputs into ScanGuage.
    FrenchToasty likes this.
  13. Jun 24, 2020 at 3:32 PM
    Johnders2586
    ** Edit it was my error I had 2802 not 2808. Now it works great.. Thanks HTGreen**
    Yeah so the TF1 based on the code you supplied must not be reading right on my truck.. I tried all the others listed online and none of the others seem to work either.. grr their customer service told me to try them all . They also said I could try the 3.5l ones .. I guess the sensors can vary depending on when and where it was manufactured..
  14. Jun 25, 2020 at 2:45 PM
    smstoyloy
    Stephen
    None Yet!
    HTGreen: Where did you find the RXD 3808 for Trans Temp 2 on the website? I only see 3008 under transmissions headings. I’ll try the 3808, but curious. thx, stephen
  15. Jun 25, 2020 at 2:52 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I think scanguage made an error when they pos
    Yeah I noticed the same error myself but the ones posted do work. Probably some lazy ass at scanguage never bothered to correct the mistake.
    smstoyloy[QUOTED][OP] likes this.
  16. Jun 25, 2020 at 4:07 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    I don't recall, I came up with it back in 2015 when I had a Tacoma, probably on the Tacoma Forum.
  17. Jul 10, 2020 at 1:34 PM
    Enzof104
    Enzof104 Have Trailer will Travel
    Paul
    Danbury CT
    2015 SR5 TRD OR DC, because bed size matters...
    Ironman Foam Cell Pro Lift. 2018 retro fit LED headlights, TRD grill, TRD rear sway bar.
    THANK YOU for this! Just set it up for my truck. Took less than 5 minutes and works perfect on my 15 Tundra
  18. Oct 4, 2020 at 10:13 AM
    Cidertom
    Cidertom Chionophile
    Tom
    2017 longbed
    I've been trying the other Toyota codes listed, and found on internet for transmission lock up, but no luck for my 17 Tundra. Anyone have one that works?
  19. Oct 5, 2020 at 10:21 AM
    mass-hole
    mass-hole New Member
    The OBDLink app with the manufacturer specific extended PID's is pretty insane in what it can see. It can see all of the modules in my Lexus GX down to the seats.
    You have to buy one of their OBD bluetooth modules but its worth it.
  20. Oct 7, 2020 at 3:06 PM
    Duhockey
    Duhockey New Member
    2008 Tundra Limited
    BSD lift, Tough Country Deluxe bumper, compustar remote start/security, rino lining, XD wheels,
    Are these the same for 2008?
  21. Oct 7, 2020 at 3:23 PM
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    Try these for pre 2010
    6F936AEC-96C8-44AB-92DF-AFF3FFCE85E5.jpg 34AA7C33-934E-4A4F-9B47-5F59EF34D090.jpg
    Saltyhero13 likes this.
  22. Oct 7, 2020 at 9:43 PM
    Duhockey
    Duhockey New Member
    2008 Tundra Limited
    Thanks @Coffee*8) do you know which ones are pan temp and which are torque converter output? there are 4 there but each looks like its posted twice?
    Thanks,
  23. Oct 7, 2020 at 9:59 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I'll snap a picture of my codes tomorrow..I have PAN and TRQ set up on my scan gauge to monitor temps.
    Duhockey[QUOTED] likes this.
  24. Oct 7, 2020 at 10:00 PM
    Coffee*8)
    Pennsylvania
    + Trans cooler
    Bravohook likes this.
  25. Oct 10, 2020 at 3:48 AM
    Duhockey
    Duhockey New Member
    2008 Tundra Limited
    I tried all 4 codes from the scangauge site. None of them works. Can someone with a pre-2013 that has working codes take some snapshots? I'm about to go over Vail and eisenhower pass and it would be nice to monitor the temps.
  26. Oct 10, 2020 at 10:52 AM
    Bravohook
    Addame
    NY
    2007 RCSB
    Cool Things
    Sent you a PM with my codes that I used.
    BravoDeltaRomeo likes this.
  27. Dec 13, 2020 at 9:29 AM
    AlexJet
    AlexJet New Member
    2021 TRD Offroad CrewMax
    On my 2021 only the 1st XGauge works (2808)
    Desert4673 likes this.
  28. Dec 29, 2020 at 10:40 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    TOYOTA - LEXUS - SCION SPECIFIC CANSF »
    • Gauge
    • TXD
    • RXF
    • RXD
    • MTH
    • Name
    • Notes
    Are these the one's I should try?
  29. Dec 29, 2020 at 10:50 AM
    AlexJet
    AlexJet New Member
    On 2021 only this worked for me:
    Bammer[QUOTED] likes this.
  30. Dec 29, 2020 at 10:56 AM
    Bammer
    Monroe, CT
