SAIS bypass via tune
Discussion in 'Performance and Tuning' started by MoTundra, Feb 27, 2025.
  1. Feb 27, 2025 at 12:01 PM
    MoTundra
    MoTundra [OP] New Member
    Nick
    2007 Black 5.7 rcsb work truck
    Stock
    Good afternoon everyone, recently I pulled one of the dreaded codes for the secondary air injection emissions system (P2442) on my 2007 Tundra 5.7. I currently have a second vehicle for daily use, therefore I don’t commute in the tundra anymore. For this reason I’d like to bypass the SAIS system as I’ve read they are prone to repeated failure over time and I don’t have money to replace it. I’ve looked at the bypass kit, although I’m reluctant to trust aftermarket parts to keep my truck running properly. I’ve read about tuning via DAP or hptuners, it seems to be the most reliable way to bypass the codes that keep putting it in limp mode. I know next to nothing about tuning and vehicle electronics, is it feasible to block the codes via tuning as someone who isn’t familiar with tuning? I don’t even know what DAP means, assuming it’s a brand? If anybody could provide a walk-through of what I would need to do and if this would work I would really, really appreciate it! I’m almost at 200k and I don’t want emissions issues to keep this truck continuing to sit and gather dust.
    StegerSex and D4x4TRD like this.
  2. Feb 27, 2025 at 1:18 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    I'm having the same issue and am installing the bypass kit this weekend. everybody seems to gave good luck with the Hewitt Gen 2, so that's what I got. I'd rather throw a $450 part at it than spend thousands on a mechanic
    HulkSmurf14 likes this.
  3. Feb 28, 2025 at 9:53 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The tune will turn the lights off on the dash, but if someone plugs into and scans the truck they will see the SAIS has failed. The limp mode throttle limits can be bypassed in the tune, at least there's tables for it that I always "turn off", but I've never had someone have the SAIS fail to see if the limp mode is ENTIRELY disabled, so take it with a grain of salt.
    If you have to pass emissions and the SAIS will make it fail, then I do not think a tune is able to fix it if the emissions place is thorough. If that is not a concern, then a tune will conceivably be able to fix all drivability and dash light annoyances.
    In regards to the tuner, that may be its own cluster and probably not cheaper than the Hewitt kit. DAP was a tuning company/individual that no longer exists. OTT is the big name but I think they refuse to touch anything related to emissions. If there's a local place/individual with HP Tuners or VF Tuner they could quickly go in and turn it off, but it'll cost at least $200 to unlock the ECU to tune it. You could do it yourself, but then you're in $600 between the $400 flashing hardware and the $200 ECU unlock.
  4. Feb 28, 2025 at 10:16 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    I had p2442. It wasn't permanent yet so I over rode the system check. I did the DIY AIP bypass where it says it a good temp, installed block off plates and disabled the non electrical codes. I already had hpt so based on what @snivilous stated. You need the Hewitt system to totally bypass it (the drivers and front pumps).
  5. Feb 28, 2025 at 10:37 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    this guy SAISes
    HulkSmurf14 and Mdl like this.
  6. Feb 28, 2025 at 10:51 AM
    koditten
    Kirk
    Midland of the Mitten
    I did the diy version a dozen years ago on my 08. It's been fine and trouble free for almost 200k miles. It was at 50k miles when I did the diy version.
    It's pretty simple. If you can solder or crimp wires, you can do the mod for less than $40.
    The only issue you may have is you need to know if the truck ever had the modules reflashed.
    Toyota changed the programming so the pumps would randomly cycle when the truck was parked.
    You need to find out if the truck got the reflash.
    You can check be going to Toyotaowners.com, enter your VIN and you will see all the service that was ever perform at any dealership.
  7. Mar 13, 2026 at 8:18 AM
    StegerSex
    StegerSex New Member
    Ronman
    2007 Red Tundra 5.7 XSP
    Front level, 34's
    Did you ever do anything???? In the same boat....
  8. Mar 13, 2026 at 9:24 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You can do it for the cost of the block off plates and the DIY kit. As long as your valves aren't stuck open.
    This works for 2007-2009:
  9. Mar 13, 2026 at 12:06 PM
    StegerSex
    Ronman
    Front level, 34's
    The P2442 code i have says: Secondary air injection system switching valve stuck open bank 2....
  10. Mar 13, 2026 at 12:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Does it clear after scanning?
  11. Mar 13, 2026 at 12:43 PM
    StegerSex
    Ronman
    Front level, 34's
    Yes, if i clear it, but comes back after 1 to 3 days.
  12. Mar 13, 2026 at 2:04 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    that's fun
  13. Mar 13, 2026 at 3:13 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Did you read post #6? I posted a diy aip bypass that works for 07-09 without the reflash. You need to do either the Hewitt or DIY bypass before it ruins the valve then it'll need to be replaced.
    Wynnded and koditten like this.
  14. Mar 13, 2026 at 3:42 PM
    StegerSex
    Ronman
    Front level, 34's
    i got it now....thanx (from post #8). i can do it, but then the blockout plates are still necessary....?
  15. Mar 13, 2026 at 3:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    For it to be complete.
    Another option that is supposed to work with ecu's that weren't re-flashed is the
    https://rutechsolutions.com/collections/aip
    It had decent results for the 2007-2009 tundra.
  16. Mar 13, 2026 at 4:58 PM
    koditten
    Kirk
    I'm pretty sure my valves have been inoperatable for the last 14 years.
    I did the DYI version around 2013.
    I forget I even have the mod running. I'm presently 800 miles from home running the truck every day. My un flashed 2nd gen just runs just fine.
    I never did bother with the block off plates. I was pretty sure I had a bad valve, so I thought the point of protecting the valves was useless.
    Going by memory, I thought failed pump(s) sent you into limp, bad valves just triggers a CEL. Been a while since I dove deep into this useless system.
    FWIW, I live in non emission check state, so I don't have the worry about an annual ECU check.
    StegerSex likes this.
  17. Mar 13, 2026 at 5:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    We stopped with the emission checks here too. I thought it was valves were limp mode as I ran with my pump unplugged. But I forget...haha
    StegerSex and koditten[QUOTED] like this.
  18. Mar 13, 2026 at 5:41 PM
    koditten
    Kirk
    I guess I got some testing to do.
    On my '21 I have a code for a failed pump. I'll just run it to see if it goes to limp mode.
    I've been clearing the code every time I get into the truck so I can't be 100% sure it's pumps or valves that cause the limp mode.
    Presently driving the '08 during the winter months. It runs just fine with the DIY bypass.
  19. Mar 13, 2026 at 6:38 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you need a set of pumps...I had them disconnected and finally took them out. A 10000k 5volt resistor tells the ecu they are there and off. I believe the newer ones run randomly. On the ecu wants to see min of 8v less 1ohm or something when on. So that Hewitt kit does it all.
  20. Mar 13, 2026 at 6:59 PM
    koditten
    Kirk
    I removed both my pumps on my '21 and bench tested them. Both spun up just fine when 12 v was applied.
    The code tells me bank 1 pump off. I wanted to test the proving switch, but the cock suckers at Toyota used a security Torx bit, so I couldn't test the switch. My mistake. Reinstalled to have the same code pop the next day.
    I've either got a bad switch or a cut line between the pump and the driver.
    I guess I'm pulling that fender liner again.
    Thankfully I got lots of plastic darts to re secure the liner and mud flap.
    That's a May job.
  21. Mar 14, 2026 at 4:12 AM
    StegerSex
    Ronman
    Front level, 34's
    Yeah, i checked that Rutech out a bit on utube....very simple plug and play....much easier connection than the Hewitt....don't even have to blindly reach down behind the engine to unplug/plug into the secondary air injection pump control valve. cheaper at $190. however, i'll try the DYI you posted first.
  22. Mar 14, 2026 at 4:38 AM
    StegerSex
    Ronman
    Front level, 34's
    Mine triggers a CEL and vsc and 4lo flashing....i don't think it goes into limp mode, but it does cut back on acceleration power....maybe like tow mode?
    i'm glad to read that you went without the block off plates cuz i was worried i might not be able to do it....(and, i don't have them).
  23. Mar 18, 2026 at 4:29 AM
    StegerSex
    Ronman
    Front level, 34's
    Are the 5.7 blockout plates different size than the 4.7? Or are they both like in this attachment?
  24. Mar 18, 2026 at 4:37 AM
    texasrho83
    texasrho83 Ye Olde Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just an FYI, OTT won't tweak tunes to "violate" emissions laws.
    koditten, StegerSex and FrenchToasty like this.
  25. Mar 19, 2026 at 10:26 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Love me a good violation
    Ginsterkev, hagrid, HondaDad and 2 others like this.
  26. Mar 19, 2026 at 10:33 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    hagrid and texoma[QUOTED] like this.
  27. Apr 3, 2026 at 5:12 AM
    StegerSex
    Ronman
    Front level, 34's
    Mdl, koditten and HondaDad like this.
  28. Apr 3, 2026 at 5:16 AM
    koditten
    Kirk
    That's the same one I've been running since 2013.
    StegerSex[QUOTED] and Mdl like this.
  29. Apr 4, 2026 at 3:46 AM
    StegerSex
    Ronman
    Front level, 34's
    Nice! I had the sai valve stuck open code and all the internet 'wisdom' says its necessary to to put the block off plates or the 'valves' will be burnt/ruined....Like you, i'm thinkin the valve is already ruined....
    koditten[QUOTED] likes this.
  30. Apr 4, 2026 at 8:09 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I don't have the plates anymore as I removed my airtubes. If your valves were stuck open the exhaust could ruin the barometric sensor the ecu needs to measure. That is the main reason for a plate. Why you need to know if it's stuck open.
    StegerSex[QUOTED] likes this.
