rusty gorilla nuts
Discussion in 'Wheels & Tires' started by scotch, May 23, 2016.
  1. May 23, 2016 at 2:49 PM
    scotch
    scotch [OP] New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    I have Method wheels and gorilla lug nuts (bought from discount tire). The gorilla lug nuts are chrome plated, but after a year they are rusting outside and in on the threads. Discount tire is replacing the set, and I asked for black to not deal with chrome. Any other recommendations on nuts?
  2. May 23, 2016 at 3:52 PM
    15whtrd
    15whtrd Mr. Blonde
    For the threads I like to put a little never seize. I think I've read somewhere where they say not to. But I apply just a small amount and usually don't need to apply again for quite some time through many tire rotations.
    OBXTundra likes this.
  3. May 23, 2016 at 4:16 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    I had the chrome ones from Discount Tire and same problem. Picked up a set of Black ET lugs from Vin at Stealth Custom Series and so far so good.
    OBXTundra and NewImprovedRon like this.
  4. May 23, 2016 at 7:21 PM
    scotch
    Denver, CO
    2010 Tundra
    I'll give them a try. I also put anti-seize on the the thread to help until I find a quality replacement.
  5. May 23, 2016 at 8:08 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    I have Gorilla "black" chrome nuts to match my rims. So far so good but only for a couple of months. I'll update after a few more months to let you know if black nuts are rusty. Nothing worse than rusty nuts. :headbang:
  6. May 23, 2016 at 8:15 PM
    Mike Tread lightly.
    south carolina
    Problem with YOUR NUTS.
    Simple they where made in China. During the process they get away with very alittle plating (electrolysis) as possible on the nuts just enough so when you see opps you have a problem your warranty is out.
    Tho copper sulfate (anti seize) will work on the treads it does nothing for your outside look.
    For outside use a wax to keep rust down or use chrome polish to fan out the spots.
    15whtrd likes this.
  7. May 23, 2016 at 8:24 PM
    Aurora CO
    I paid about 97 cents a piece for my nuts (sounds weird). Cheap to replace. Bottom line, I'm not too worried about my nuts. After all, it's good Chinese crap. Better than the 50 cent ones. heh heh
    (Obviously I'm due for some time off.)
    Hammy68 likes this.
  8. Jun 2, 2016 at 8:58 PM
    scotch
    Denver, CO
    2010 Tundra
    An update on my nuts: Discount Tire replaced my rusty Gorilla nuts (for free!) with a West Coast Wheel brand and I ordered a set from SCS. Here is a photo comparing all three. The SCS nuts are shorter, and the tang part is also shorter, compared to the other two brands. All three brands use the same socket. I haven't mounted the SCS nuts yet to see if the shorter tang and body are an issue.
    TheBeast likes this.
  9. Mar 15, 2019 at 4:50 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Bump, I have Gorilla ET black chrome lugs 26143ETBC. Looks like they're all rusting less than a year on the truck. Scrubbing works a bit, I'm sure if I spent enough time I'd get most of it off without removing them from the wheels. That won't last. Something I should coat with or other solutions if I'm stuck with them? Another brand?
  10. Mar 15, 2019 at 5:00 PM
    TheBeast The Beach
    I run the ones from Camburg. black nutz...
    They are the west coast brand ones I believe. No issues so far. solid nutz
    JoshuaA and smslavin like this.
  11. Mar 16, 2019 at 6:17 AM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I pay about the same and just get a new set every spring before the summer wheels go back on.
  12. Mar 17, 2019 at 9:29 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Are these just the chrome lug nuts from Gorilla? I replaced the chrome ETs from Discount Tire with the black Gorilla acorn nuts. Hoping the rust issue is not with the black ones.
  13. Mar 21, 2019 at 4:40 AM
    VBTundra
    VBTundra New Member
    Looking for Acorn 60 degree taper nuts as well. Anyone else got a good brand they can recommend?
  14. Mar 21, 2019 at 4:51 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Black Gorilla ET's here.
    I always anti-seize the threads, on everything.
    I hit almost anything on my truck that I want to stay rust free with CRC SP-400 and more recently Amsoil MPHD. I hit the lugs with the Amsoil while they're on the truck and then quickly wipe the excess off the wheel. No sign of rust. I don't think I've ever had a set of nuts that haven't rusted in a few years. But my OEM lugs were still spotless after 9 years in use. Aftermarket just seems to skimp on coatings across the board on all products.
    I am a little crazy with the anti-corrosive sprays though. I hit all suspension components, entire frame (inside/out), insides of bumpers, etc....
  15. Mar 21, 2019 at 5:14 AM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like whoever gets your truck when you’re done with it will be a lucky person! Not a spot of rust on this thing! I’ll take it
    OBXTundra[QUOTED] likes this.
  16. Mar 21, 2019 at 5:43 AM
    acsubie
    acsubie New Member
    Jose
    2018 Trd Sport
    Had gorillas on my Durango and they rusted on me, had to replace them and made sure to not use gorillas on my SCS wheels and just ordered a set thru them and they appear well made, but living on the east coast in a shore town doesn’t help anything with all the salt exposure
    equin likes this.
  17. Jan 31, 2024 at 12:35 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I know this post is old but any updates on everyone’s rusty nuts? My SCS nuts are starting to get rusty now after about 2 years and looking for replacements.
  18. Jan 31, 2024 at 2:11 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I just ended up spot spray painting them between tire changes, cardboard with hole to mask the wheel. Functionally the nuts are fine and you have to be close up to notice. What I did replace were the old bulky Method hub caps that became spotty and faded, got these flush ones instead (not my tire, too lazy to go out and pic, same look)
    Nbab23[QUOTED] likes this.
