Rust Conversion
Discussion in '2.5 Gen Tundras (2014-2021)' started by UTAHRTK, Sep 8, 2020.
  1. Sep 8, 2020 at 6:30 PM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    What is a good product to convert rust? Thanks.
  2. Sep 8, 2020 at 6:55 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  3. Sep 9, 2020 at 5:04 AM
    UTAHRTK
    SOCAL
    Thanks- I had that one on my list.
  4. Sep 9, 2020 at 6:33 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Back when I had hot rods and did a lot of restoration I used por15. With anything you choose get as much rust off as you can- grind, sand, wire brush and then clean with something like brake cleaner, follow up with a good wash. Dry fully before starting any treatment.
  5. Sep 10, 2020 at 4:59 AM
    UTAHRTK
    SOCAL
    Thanks.
  6. Sep 10, 2020 at 5:02 AM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    +1 for POR15. Used it on my 68 GTO when I refurb'd it.
  7. Sep 10, 2020 at 5:51 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    On past projects I've used phosphoric acid based cleaners to neutralize rust and then coated with chassis saver/por15/eastwood type encapsulating products with good success.
  8. Sep 10, 2020 at 6:01 AM
    UTAHRTK
    SOCAL
    I appreciate the info
  9. Sep 10, 2020 at 6:50 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
  10. Sep 10, 2020 at 8:41 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I had good luck with Permatex Rust Treatment , which I picked up at Napa.
    All the advice here is pretty good. Prep the area to be treated and spray this stuff on. It turns the rust black during conversion, and creates an ideal surface for priming and painting.
  11. Sep 10, 2020 at 8:51 AM
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    Anyone try Opsho? A couple other rust repair threads on the 2nd gen forum it's been mentioned. I bought some and am planning to use it to fix my bed this weekend.
  12. Sep 11, 2020 at 6:49 AM
    UTAHRTK
    SOCAL
    My Tundra has minor rust about the frame and other hardware. Im going to kill it before it gets worse. I think being around the beach out here has been the cause. Thanks again.\ for the info- gonna order Corroseal and try that first.
