Rubbing sway bar to struts after 3”level
Discussion in '2nd Gen Tundras (2007-2013)' started by WWikkidd, Oct 12, 2018.
  1. Oct 12, 2018 at 9:17 PM
    WWikkidd
    WWikkidd [OP] New Member
    2008 flat white 4.0 tundra
    3” level kit in front tires BA exhaust . Custom tranny build , and custom drive shaft(no aluminum) solid steel
    Hi there all first time posting long time using these threads to help me and friends . I have a 2008 4.0 . Put a 3” level kit just the spacers nothing else on . Now I’m getting a loud grinding slamming noise when I turn hard or bounce . I found out it was the sway bar and it’s left some nasty dents in my brand new strut coilovers I installed . Is it ok to remove sway bar or possibly grind it down so it clears ? Or do I need to buy new A-arms and end links? Thanks
    831Tun likes this.
  2. Oct 12, 2018 at 9:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. I don't run sway bars on my truck. Lots of people who wheel remove their sway bars.
    joonbug likes this.
  3. Oct 12, 2018 at 9:25 PM
    WWikkidd
    Right on , I was wondering that . Does it make for an unstable ride at say 80-90mph? I’m gonna take them off I need the extra flex anyways
    831Tun[QUOTED] likes this.
  4. Oct 12, 2018 at 9:59 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's still plenty stable. All it does is increase body roll when cornering. The suspension is a lot more independent without sways. Example: If you hit a bump/pot hole with the driver front you'll feel it in the pass front too if you have sways. W/O sways you only feel it in the driver side.
    joonbug likes this.
  5. Oct 12, 2018 at 10:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Take it off!!!
  6. Oct 12, 2018 at 10:22 PM
    15whtrd
    15whtrd Mr. Blonde
    Haha in a sense that kind of means if you take it off you’re not going to get what you thought you would LOL
    831Tun and joonbug[QUOTED] like this.
  7. Oct 12, 2018 at 10:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yeah... I didn’t think that through. :p
    831Tun and 15whtrd[QUOTED] like this.
  8. Oct 13, 2018 at 2:42 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    Let's be honest... If something goes wrong at 90mph in a 6000lb brick, you're pretty fucked whether you've got a sway bar or not ...
    831Tun and Grumpy Uncle like this.
  9. Feb 12, 2019 at 5:46 AM
    Depending on what leveling kit you have, it should have came with drop down brackets for the sway bar. The stock sway bar is hollow so IMO I wouldn't grind it.
    Rica25 likes this.
  10. Feb 12, 2019 at 6:20 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Pictures??
  11. Mar 4, 2019 at 2:11 AM
    1BigBadTundra
    1BigBadTundra New Member
    2011 tundra sr5
    I put drop downs on mine n it still gets a stress pop . After doing my leveling kit my truck now creaks like a 1980s Chevy that's been sitting in a field . Lol!
